Results 1 to 3 of 3
Thread: Teensy 4.0 3.3v maximum current?
    May 2015
    San Francisco
    166
    I can't seem to find a reference to the maximum capacity of the 3.3v regulator in Teensy 4.0.
    What's the maximum current that should be drawn by external circuitry on the 3.3v pins on Teensy 4.0?
    I see that the TLV75733P is rated up to 1 amp, but there may be thermal limitations with the Teensy board, not to mention its own current draw.
    Thanks in advance.
    9,770
    The T4 card shows a 250 mA max indication on 3.3V pin : https://www.pjrc.com/teensy/pinout.html
    Paul noted somewhere that more only works up to the point the heat can be dissipated - and when the fuse triggers. Can you see parts specs on the fuse is this showing 500 mA: https://www.pjrc.com/teensy/schematic.html
    May 2015
    San Francisco
    166
    Awesome, thanks!
