Results 1 to 6 of 6
Thread: Hardware SPI for Teensy 4.0
    Sep 2019
    Japan, Sapporo
    3
    I would like to use the Teensy 4.0 hardware SPI1 orSPI2.
    Are there any articles or Posts that can be helpful?
    Thank you!
    3,145
    Well the display threads tends to have a lot of talk about SPI in general and using both SPI0 and SPI1 to control two separate displays (most notably two of the cheap displays that don't have a CS pin):
    Plus of course the massive T4 beta thread had SPI sub-threads in it:
    Obviously the issue with SPI1 and SPI2 is getting access to the solder pads underneath the Teensy. SPI1 is easier to deal with since it has 0.1"/2.54mm pads, while SPI2 has the much smaller 1mm pads.
    Note the pinout card for the T4 does not mention that pin 0 is the CS pin for SPI1 and pin 1 is the MISO pin.
    Sep 2019
    Japan, Sapporo
    3
    Thank you for informations!
    For example, does the following work?
     SPI2.begin();
     SPI2.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
    5,276
    As mentioned:
    Yes SPI1 and SPI2 work, and the it looks like you have the right syntax.
    As mentioned: SPI1 uses a couple of main IO pins and a couple of the ones on the 2x5 SMT connector below.
    SPI2 works off of the connector setup for SDCard connections. Mainly is spaced out to use a Ribbon connector. But there will hopefully soon be a released breakout board by LogLow which has a flex cable you can solder to it.
    Sep 2019
    Japan, Sapporo
    3
    Thank you!
    I was able to confirm the output of SPI1 and SPI2.
    I want to light the APA102 LED on SPI1.
    I have customized the following libraries for SPI1.
     https://github.com/adafruit/Adafruit_DotStar
    The lighting was confirmed with the software SPI.
      #define DATAPIN
      #define CLOCKPIN   27
      Adafruit_DotStar strip(NUMPIXELS, DATAPIN, CLOCKPIN, DOTSTAR_BRG);
    However, it does not light up with hardware SPI for SPI1.
    The following is a customized library for SPI1.
    #include "Adafruit_DotStar.h"
    #if !defined(__AVR_ATtiny85__)
    #define USE_HW_SPI 255 ///< Assigned to dataPin to indicate 'hard' SPI
      @brief   DotStar constructor for hardware SPI. Must be connected to
               MOSI, SCK pins.
      @param   n  Number of DotStars in strand.
      @param   o  Pixel type -- one of the DOTSTAR_* constants defined in
                  Adafruit_DotStar.h, for example DOTSTAR_BRG for DotStars
                  expecting color bytes expressed in blue, red, green order
                  per pixel. Default if unspecified is DOTSTAR_BRG.
      @return  Adafruit_DotStar object. Call the begin() function before use.
    Adafruit_DotStar::Adafruit_DotStar(uint16_t n, uint8_t o) :
     numLEDs(n), dataPin(USE_HW_SPI), brightness(0), pixels(NULL),
     rOffset(o & 3), gOffset((o >> 2) & 3), bOffset((o >> 4) & 3)
      updateLength(n);
      @brief   DotStar constructor for 'soft' (bitbang) SPI. Any two pins
               can be used.
      @param   data   Arduino pin number for data out.
      @param   clock  Arduino pin number for clock out.
    Adafruit_DotStar::Adafruit_DotStar(uint16_t n, uint8_t data, uint8_t clock,
      uint8_t o) : dataPin(data), clockPin(clock), brightness(0), pixels(NULL),
      updateLength(n);
      @brief   Deallocate Adafruit_DotStar object, set data and clock pins
               back to INPUT.
    Adafruit_DotStar::~Adafruit_DotStar(void) {
      free(pixels);
      if(dataPin == USE_HW_SPI) hw_spi_end();
      else                      sw_spi_end();
      @brief   Initialize Adafruit_DotStar object -- sets data and clock pins
               to outputs and initializes hardware SPI if necessary.
    void Adafruit_DotStar::begin(void) {
      if(dataPin == USE_HW_SPI) hw_spi_init();
      else                      sw_spi_init();
    // Pins may be reassigned post-begin(), so a sketch can store hardware
    // config in flash, SD card, etc. rather than hardcoded. Also permits
    // "recycling" LED ram across multiple strips: set pins to first strip,
    // render & write all data, reassign pins to next strip, render & write,
    // etc. They won't update simultaneously, but usually unnoticeable.
      @brief   Switch over to hardware SPI. DotStars must be connected to
               MOSI, SCK pins. Data in pixel buffer is unaffected and can
               continue to be used.
    void Adafruit_DotStar::updatePins(void) {
      sw_spi_end();
      dataPin = USE_HW_SPI;
      hw_spi_init();
      @brief   Switch over to 'soft' (bitbang) SPI. DotStars can be connected
               to any two pins. Data in pixel buffer is unaffected and can
    void Adafruit_DotStar::updatePins(uint8_t data, uint8_t clock) {
      hw_spi_end();
      dataPin  = data;
      clockPin = clock;
      sw_spi_init();
      @brief   Change the length of a previously-declared Adafruit_DotStar
               strip object. Old data is deallocated and new data is cleared.
               Pin numbers and pixel format are unchanged.
      @param   n  New length of strip, in pixels.
      @note    This function is deprecated, here only for old projects that
               may still be calling it. New projects should instead use the
               'new' keyword.
    void Adafruit_DotStar::updateLength(uint16_t n) {
      free(pixels);
      uint16_t bytes = (rOffset == gOffset) ?
        n + ((n + 3) / 4) : // MONO: 10 bits/pixel, round up to next byte
        n * 3;              // COLOR: 3 bytes/pixel
      if((pixels = (uint8_t *)malloc(bytes))) {
        numLEDs = n;
        clear();
        numLEDs = 0;
    // SPI STUFF ---------------------------------------------------------------
      @brief   Initialize hardware SPI.
      @note    This library is written in pre-SPI-transactions style and needs
               some rewriting to correctly share the SPI bus with other devices.
    void Adafruit_DotStar::hw_spi_init(void) { // Initialize hardware SPI
    #ifdef __AVR_ATtiny85__
      PORTB &= ~(_BV(PORTB1) | _BV(PORTB2)); // Outputs
      DDRB  |=   _BV(PORTB1) | _BV(PORTB2);  // DO (NOT MOSI) + SCK
    #elif (SPI_INTERFACES_COUNT > 0) || !defined(SPI_INTERFACES_COUNT)
      SPI1.begin();
      // Hardware SPI clock speeds are chosen to run at roughly 1-8 MHz for most
      // boards, providing a slower but more reliable experience by default.  If
      // you want faster LED updates, experiment with the clock speeds to find
      // what works best with your particular setup.
     #if defined(__AVR__) || defined(CORE_TEENSY) || defined(__ARDUINO_ARC__) || defined(__ARDUINO_X86__)
      SPI1.setClockDivider(SPI_CLOCK_DIV2); // 8 MHz (6 MHz on Pro Trinket 3V)
     #else
      #ifdef ESP8266
        SPI1.setFrequency(8000000L);
      #elif defined(PIC32)
        // Use begin/end transaction to set SPI clock rate
        SPI1.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
        SPI1.endTransaction();
      #else
        SPI1.setClockDivider((F_CPU + 4000000L) / 8000000L); // 8-ish MHz on Due
      SPI1.setBitOrder(MSBFIRST);
      SPI1.setDataMode(SPI_MODE0);
      @brief   Stop hardware SPI.
    void Adafruit_DotStar::hw_spi_end(void) {
      DDRB &= ~(_BV(PORTB1) | _BV(PORTB2)); // Inputs
      SPI1.end();
      @brief   Initialize 'soft' (bitbang) SPI. Data and clock pins are set
               to outputs.
    void Adafruit_DotStar::sw_spi_init(void) {
      pinMode(dataPin , OUTPUT);
      pinMode(clockPin, OUTPUT);
    #ifdef __AVR__
      dataPort     =  portOutputRegister(digitalPinToPort(dataPin));
      clockPort    =  portOutputRegister(digitalPinToPort(clockPin));
      dataPinMask  =  digitalPinToBitMask(dataPin);
      clockPinMask =  digitalPinToBitMask(clockPin);
      *dataPort   &= ~dataPinMask;
      *clockPort  &= ~clockPinMask;
    #else
      digitalWrite(dataPin , LOW);
      digitalWrite(clockPin, LOW);
      @brief   Stop 'soft' (bitbang) SPI. Data and clock pins are set to inputs.
    void Adafruit_DotStar::sw_spi_end() {
      pinMode(dataPin , INPUT);
      pinMode(clockPin, INPUT);
    // Teensy/Gemma-specific stuff for hardware-half-assisted SPI
    #define SPIBIT                                  \
      USICR = ((1<<USIWM0)|(1<<USITC));             \
      USICR = ((1<<USIWM0)|(1<<USITC)|(1<<USICLK)); // Clock bit tick, tock
    static void spi_out(uint8_t n) { // Clock out one byte
      USIDR = n;
      SPIBIT SPIBIT SPIBIT SPIBIT SPIBIT SPIBIT SPIBIT SPIBIT
    // All other boards have full-featured hardware support for SPI
    #define spi_out(n) (void)SPI1.transfer(n) ///< Call hardware SPI function
    // Pipelining reads next byte while current byte is clocked out
    #if (defined(__AVR__) && !defined(__AVR_ATtiny85__)) || defined(CORE_TEENSY)
     #define SPI_PIPELINE
    #else // no hardware spi
    #define spi_out(n) sw_spi_out(n)
      @brief   Soft (bitbang) SPI write.
      @param   n  8-bit value to transfer.
    void Adafruit_DotStar::sw_spi_out(uint8_t n) {
      for(uint8_t i=8; i--; n <<= 1) {
    #ifdef __AVR__
        if(n & 0x80) *dataPort |=  dataPinMask;
        else         *dataPort &= ~dataPinMask;
        *clockPort |=  clockPinMask;
    #else
        if(n & 0x80) digitalWrite(dataPin, HIGH);
        else         digitalWrite(dataPin, LOW);
        digitalWrite(clockPin, HIGH);
    #if F_CPU >= 48000000
        __asm__ volatile(
        "nop \n nop"
        __asm__ volatile(
        "nop \n nop"
    /* ISSUE DATA TO LED STRIP -------------------------------------------------
      Although the LED driver has an additional per-pixel 5-bit brightness
      setting, it is NOT used or supported here. On APA102, the normally
      very fast PWM is gated through a much slower PWM (about 400 Hz),
      rendering it useless for POV or other high-speed things that are
      probably why one is using DotStars instead of NeoPixels in the first
      place. I'm told that some APA102 clones use current control rather than
      PWM for this, which would be much more worthwhile. Still, no support
      here, no plans for it. If you really can't live without it, you can fork
      the library and add it for your own use, but any pull requests for this
      are unlikely be merged for the foreseeable future.
      @brief   Transmit pixel data in RAM to DotStars.
    void Adafruit_DotStar::show(void) {
      if(!pixels) return;
      uint8_t *ptr = pixels, i;            // -> LED data
      uint16_t n   = numLEDs;              // Counter
      uint16_t b16 = (uint16_t)brightness; // Type-convert for fixed-point math
      if(dataPin == USE_HW_SPI) {
        // TO DO: modernize this for SPI transactions
    #ifdef SPI_PIPELINE
        uint8_t next;
        for(i=0; i<3; i++) spi_out(0x00);    // First 3 start-frame bytes
        SPDR = 0x00;                         // 4th is pipelined
        do {                                 // For each pixel...
          while(!(SPSR & _BV(SPIF)));        //  Wait for prior byte out
          SPDR = 0xFF;                       //  Pixel start
          for(i=0; i<3; i++) {               //  For R,G,B...
            next = brightness ? (*ptr++ * b16) >> 8 : *ptr++; // Read, scale
            SPDR = next;                     //   Write scaled color
        } while(--n);
        while(!(SPSR & _BV(SPIF)));          // Wait for last byte out
    #else
        for(i=0; i<4; i++) spi_out(0x00);    // 4 byte start-frame marker
        if(brightness) {                     // Scale pixel brightness on output
            spi_out(0xFF);                   //  Pixel start
            for(i=0; i<3; i++) spi_out((*ptr++ * b16) >> 8); // Scale, write RGB
          } while(--n);
        } else {                             // Full brightness (no scaling)
            for(i=0; i<3; i++) spi_out(*ptr++); // Write R,G,B
          } while(--n);
        // Four end-frame bytes are seemingly indistinguishable from a white
        // pixel, and empirical testing suggests it can be left out...but it's
        // always a good idea to follow the datasheet, in case future hardware
        // revisions are more strict (e.g. might mandate use of end-frame
        // before start-frame marker). i.e. let's not remove this. But after
        // testing a bit more the suggestion is to use at least (numLeds+1)/2
        // high values (1) or (numLeds+15)/16 full bytes as EndFrame. For details see also:
        // https://cpldcpu.wordpress.com/2014/1...a102-superled/
        for(i=0; i<((numLEDs + 15) / 16); i++) spi_out(0xFF);
      } else {                               // Soft (bitbang) SPI
        for(i=0; i<4; i++) sw_spi_out(0);    // Start-frame marker
            sw_spi_out(0xFF);                //  Pixel start
            for(i=0; i<3; i++) sw_spi_out((*ptr++ * b16) >> 8); // Scale, write
          } while(--n);
            for(i=0; i<3; i++) sw_spi_out(*ptr++); // R,G,B
          } while(--n);
        for(i=0; i<((numLEDs + 15) / 16); i++) sw_spi_out(0xFF); // End-frame marker (see note above)
      @brief   Fill the whole DotStar strip with 0 / black / off.
    void Adafruit_DotStar::clear() {
      memset(pixels, 0, (rOffset == gOffset) ?
        numLEDs + ((numLEDs + 3) / 4) : // MONO: 10 bits/pixel
        numLEDs * 3);                   // COLOR: 3 bytes/pixel
      @brief   Set a pixel's color using separate red, green and blue components.
      @param   n  Pixel index, starting from 0.
      @param   r  Red brightness, 0 = minimum (off), 255 = maximum.
      @param   g  Green brightness, 0 = minimum (off), 255 = maximum.
      @param   b  Blue brightness, 0 = minimum (off), 255 = maximum.
    void Adafruit_DotStar::setPixelColor(
     uint16_t n, uint8_t r, uint8_t g, uint8_t b) {
      if(n < numLEDs) {
        uint8_t *p = &pixels[n * 3];
        p[rOffset] = r;
        p[gOffset] = g;
        p[bOffset] = b;
      @brief   Set a pixel's color using a 32-bit 'packed' RGB value.
      @param   c  32-bit color value. Most significant byte is 0, second is
                  red, then green, and least significant byte is blue.
                  e.g. 0x00RRGGBB
    void Adafruit_DotStar::setPixelColor(uint16_t n, uint32_t c) {
      if(n < numLEDs) {
        p[rOffset] = (uint8_t)(c >> 16);
        p[gOffset] = (uint8_t)(c >>  8);
        p[bOffset] = (uint8_t)c;
      @brief   Fill all or part of the DotStar strip with a color.
                      is red, then green, and least significant byte is blue.
                      e.g. 0x00RRGGBB. If all arguments are unspecified, this
                      will be 0 (off).
      @param   first  Index of first pixel to fill, starting from 0. Must be
                      in-bounds, no clipping is performed. 0 if unspecified.
      @param   count  Number of pixels to fill, as a positive value. Passing
                      0 or leaving unspecified will fill to end of strip.
    void Adafruit_DotStar::fill(uint32_t c, uint16_t first, uint16_t count) {
      uint16_t i, end;
      if(first >= numLEDs) {
        return; // If first LED is past end of strip, nothing to do
      // Calculate the index ONE AFTER the last pixel to fill
      if(count == 0) {
        // Fill to end of strip
        end = numLEDs;
        // Ensure that the loop won't go past the last pixel
        end = first + count;
        if(end > numLEDs) end = numLEDs;
      for(i = first; i < end; i++) {
        this->setPixelColor(i, c);
      @brief   Convert hue, saturation and value into a packed 32-bit RGB color
               that can be passed to setPixelColor() or other RGB-compatible
               functions.
      @param   hue  An unsigned 16-bit value, 0 to 65535, representing one full
                    loop of the color wheel, which allows 16-bit hues to "roll
                    over" while still doing the expected thing (and allowing
                    more precision than the wheel() function that was common to
                    prior DotStar and NeoPixel examples).
      @param   sat  Saturation, 8-bit value, 0 (min or pure grayscale) to 255
                    (max or pure hue). Default of 255 if unspecified.
      @param   val  Value (brightness), 8-bit value, 0 (min / black / off) to
                    255 (max or full brightness). Default of 255 if unspecified.
      @return  Packed 32-bit RGB color. Result is linearly but not perceptually
               correct, so you may want to pass the result through the gamma32()
               function (or your own gamma-correction operation) else colors may
               appear washed out. This is not done automatically by this
               function because coders may desire a more refined gamma-
               correction function than the simplified one-size-fits-all
               operation of gamma32(). Diffusing the LEDs also really seems to
               help when using low-saturation colors.
    uint32_t Adafruit_DotStar::ColorHSV(uint16_t hue, uint8_t sat, uint8_t val) {
      uint8_t r, g, b;
      // Remap 0-65535 to 0-1529. Pure red is CENTERED on the 64K rollover;
      // 0 is not the start of pure red, but the midpoint...a few values above
      // zero and a few below 65536 all yield pure red (similarly, 32768 is the
      // midpoint, not start, of pure cyan). The 8-bit RGB hexcone (256 values
      // each for red, green, blue) really only allows for 1530 distinct hues
      // (not 1536, more on that below), but the full unsigned 16-bit type was
      // chosen for hue so that one's code can easily handle a contiguous color
      // wheel by allowing hue to roll over in either direction.
      hue = (hue * 1530L + 32768) / 65536;
      // Because red is centered on the rollover point (the +32768 above,
      // essentially a fixed-point +0.5), the above actually yields 0 to 1530,
      // where 0 and 1530 would yield the same thing. Rather than apply a
      // costly modulo operator, 1530 is handled as a special case below.
      // So you'd think that the color "hexcone" (the thing that ramps from
      // pure red, to pure yellow, to pure green and so forth back to red,
      // yielding six slices), and with each color component having 256
      // possible values (0-255), might have 1536 possible items (6*256),
      // but in reality there's 1530. This is because the last element in
      // each 256-element slice is equal to the first element of the next
      // slice, and keeping those in there this would create small
      // discontinuities in the color wheel. So the last element of each
      // slice is dropped...we regard only elements 0-254, with item 255
      // being picked up as element 0 of the next slice. Like this:
      // Red to not-quite-pure-yellow is:        255,   0, 0 to 255, 254,   0
      // Pure yellow to not-quite-pure-green is: 255, 255, 0 to   1, 255,   0
      // Pure green to not-quite-pure-cyan is:     0, 255, 0 to   0, 255, 254
      // and so forth. Hence, 1530 distinct hues (0 to 1529), and hence why
      // the constants below are not the multiples of 256 you might expect.
      // Convert hue to R,G,B (nested ifs faster than divide+mod+switch):
      if(hue < 510) {         // Red to Green-1
        b = 0;
        if(hue < 255) {       //   Red to Yellow-1
          r = 255;
          g = hue;            //     g = 0 to 254
        } else {              //   Yellow to Green-1
          r = 510 - hue;      //     r = 255 to 1
          g = 255;
      } else if(hue < 1020) { // Green to Blue-1
        r = 0;
        if(hue <  765) {      //   Green to Cyan-1
          g = 255;
          b = hue - 510;      //     b = 0 to 254
        } else {              //   Cyan to Blue-1
          g = 1020 - hue;     //     g = 255 to 1
          b = 255;
      } else if(hue < 1530) { // Blue to Red-1
        g = 0;
        if(hue < 1275) {      //   Blue to Magenta-1
          r = hue - 1020;     //     r = 0 to 254
          b = 255;
        } else {              //   Magenta to Red-1
          r = 255;
          b = 1530 - hue;     //     b = 255 to 1
      } else {                // Last 0.5 Red (quicker than % operator)
        r = 255;
        g = b = 0;
      // Apply saturation and value to R,G,B, pack into 32-bit result:
      uint32_t v1 =   1 + val; // 1 to 256; allows >>8 instead of /255
      uint16_t s1 =   1 + sat; // 1 to 256; same reason
      uint8_t  s2 = 255 - sat; // 255 to 0
      return ((((((r * s1) >> 8) + s2) * v1) & 0xff00) << 8) |
              (((((g * s1) >> 8) + s2) * v1) & 0xff00)       |
             ( ((((b * s1) >> 8) + s2) * v1)           >> 8);
      @brief   Query the color of a previously-set pixel.
      @param   n  Index of pixel to read (0 = first).
      @return  'Packed' 32-bit RGB value. Most significant byte is 0, second is
    uint32_t Adafruit_DotStar::getPixelColor(uint16_t n) const {
      if(n >= numLEDs) return 0;
      return ((uint32_t)p[rOffset] << 16) |
             ((uint32_t)p[gOffset] <<  8) |
              (uint32_t)p[bOffset];
      @brief   Adjust output brightness. Does not immediately affect what's
               currently displayed on the LEDs. The next call to show() will
               refresh the LEDs at this level.
      @param   b  Brightness setting, 0=minimum (off), 255=brightest.
      @note    For various reasons I think brightness is better handled in
               one's sketch, but it's here for parity with the NeoPixel
               library. Good news is that brightness setting in this library
               is 'non destructive' -- it's applied as color data is being
               issued to the strip, not during setPixelColor(), and also
               means that getPixelColor() returns the exact value originally
               stored.
    void Adafruit_DotStar::setBrightness(uint8_t b) {
      // Stored brightness value is different than what's passed. This
      // optimizes the actual scaling math later, allowing a fast 8x8-bit
      // multiply and taking the MSB. 'brightness' is a uint8_t, adding 1
      // here may (intentionally) roll over...so 0 = max brightness (color
      // values are interpreted literally; no scaling), 1 = min brightness
      // (off), 255 = just below max brightness.
      brightness = b + 1;
      @brief   Retrieve the last-set brightness value for the strip.
      @return  Brightness value: 0 = minimum (off), 255 = maximum.
    uint8_t Adafruit_DotStar::getBrightness(void) const {
      return brightness - 1; // Reverse above operation
      @brief   A gamma-correction function for 32-bit packed RGB colors.
               Makes color transitions appear more perceptially correct.
      @param   x  32-bit packed RGB color.
      @return  Gamma-adjusted packed color, can then be passed in one of the
               setPixelColor() functions. Like gamma8(), this uses a fixed
               gamma correction exponent of 2.6, which seems reasonably okay
               for average DotStars in average tasks. If you need finer
               control you'll need to provide your own gamma-correction
               function instead.
    uint32_t Adafruit_DotStar::gamma32(uint32_t x) {
      uint8_t *y = (uint8_t *)&x;
      // All four bytes of a 32-bit value are filtered to avoid a bunch of
      // shifting and masking that would be necessary for properly handling
      // different endianisms (and each byte is a fairly trivial operation,
      // so it might not even be wasting cycles vs a check and branch.
      // In theory this might cause trouble *if* someone's storing information
      // in the unused most significant byte of an RGB value, but this seems
      // exceedingly rare and if it's encountered in reality they can mask
      // values going in or coming out.
      for(uint8_t i=0; i<4; i++) y[i] = gamma8(y[i]);
      return x; // Packed 32-bit return
    5,276
    @HomeMadeGarbage - What I could not tell from your last post, is did the changes work for you? Or do you still have some issues?
    The reason I ask, is I am not sure how well we tested the actual speeds generated when you do something like:
      SPI.begin();
      SPI.setClockDivider(SPI_CLOCK_DIV2); // 8 MHz (6 MHz on Pro Trinket 3V)
     #else
      #ifdef ESP8266
        SPI.setFrequency(8000000L);
        SPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
        SPI.endTransaction();
      #else
        SPI.setClockDivider((F_CPU + 4000000L) / 8000000L); // 8-ish MHz on Due
      SPI.setBitOrder(MSBFIRST);
      SPI.setDataMode(SPI_MODE0);
    That is what the setClockDivider actually setup. I mostly have have done my testing using the newer way like what is doen in the above for PIC32.
    If you are still having issues, you might try something like:
      SPI.begin();
    #if defined(SPI_HAS_TRANSACTION)
     #elif defined(__AVR__) || defined(CORE_TEENSY) || defined(__ARDUINO_ARC__) || defined(__ARDUINO_X86__)
     #else
      #ifdef ESP8266
      #else
    Obviously if using SPI1, need to change all of the SPI to SPI1...
