HomeMadeGarbage
New member
I would like to use the Teensy 4.0 hardware SPI1 orSPI2.
Are there any articles or Posts that can be helpful?
Thank you!
Thank you!
The lighting was confirmed with the software SPI.
#define DATAPIN
#define CLOCKPIN 27
Adafruit_DotStar strip(NUMPIXELS, DATAPIN, CLOCKPIN, DOTSTAR_BRG);
However, it does not light up with hardware SPI for SPI1.
The following is a customized library for SPI1.
#include "Adafruit_DotStar.h"
#if !defined(__AVR_ATtiny85__)
#define USE_HW_SPI 255 ///< Assigned to dataPin to indicate 'hard' SPI
@brief DotStar constructor for hardware SPI. Must be connected to
MOSI, SCK pins.
@param n Number of DotStars in strand.
@param o Pixel type -- one of the DOTSTAR_* constants defined in
Adafruit_DotStar.h, for example DOTSTAR_BRG for DotStars
expecting color bytes expressed in blue, red, green order
per pixel. Default if unspecified is DOTSTAR_BRG.
@return Adafruit_DotStar object. Call the begin() function before use.
Adafruit_DotStar::Adafruit_DotStar(uint16_t n, uint8_t o) :
numLEDs(n), dataPin(USE_HW_SPI), brightness(0), pixels(NULL),
rOffset(o & 3), gOffset((o >> 2) & 3), bOffset((o >> 4) & 3)
updateLength(n);
@brief DotStar constructor for 'soft' (bitbang) SPI. Any two pins
can be used.
@param data Arduino pin number for data out.
@param clock Arduino pin number for clock out.
Adafruit_DotStar::Adafruit_DotStar(uint16_t n, uint8_t data, uint8_t clock,
uint8_t o) : dataPin(data), clockPin(clock), brightness(0), pixels(NULL),
updateLength(n);
@brief Deallocate Adafruit_DotStar object, set data and clock pins
back to INPUT.
Adafruit_DotStar::~Adafruit_DotStar(void) {
free(pixels);
if(dataPin == USE_HW_SPI) hw_spi_end();
else sw_spi_end();
@brief Initialize Adafruit_DotStar object -- sets data and clock pins
to outputs and initializes hardware SPI if necessary.
void Adafruit_DotStar::begin(void) {
if(dataPin == USE_HW_SPI) hw_spi_init();
else sw_spi_init();
// Pins may be reassigned post-begin(), so a sketch can store hardware
// config in flash, SD card, etc. rather than hardcoded. Also permits
// "recycling" LED ram across multiple strips: set pins to first strip,
// render & write all data, reassign pins to next strip, render & write,
// etc. They won't update simultaneously, but usually unnoticeable.
@brief Switch over to hardware SPI. DotStars must be connected to
MOSI, SCK pins. Data in pixel buffer is unaffected and can
continue to be used.
void Adafruit_DotStar::updatePins(void) {
sw_spi_end();
dataPin = USE_HW_SPI;
hw_spi_init();
@brief Switch over to 'soft' (bitbang) SPI. DotStars can be connected
to any two pins. Data in pixel buffer is unaffected and can
void Adafruit_DotStar::updatePins(uint8_t data, uint8_t clock) {
hw_spi_end();
dataPin = data;
clockPin = clock;
sw_spi_init();
@brief Change the length of a previously-declared Adafruit_DotStar
strip object. Old data is deallocated and new data is cleared.
Pin numbers and pixel format are unchanged.
@param n New length of strip, in pixels.
@note This function is deprecated, here only for old projects that
may still be calling it. New projects should instead use the
'new' keyword.
void Adafruit_DotStar::updateLength(uint16_t n) {
free(pixels);
uint16_t bytes = (rOffset == gOffset) ?
n + ((n + 3) / 4) : // MONO: 10 bits/pixel, round up to next byte
n * 3; // COLOR: 3 bytes/pixel
if((pixels = (uint8_t *)malloc(bytes))) {
numLEDs = n;
clear();
numLEDs = 0;
// SPI STUFF ---------------------------------------------------------------
@brief Initialize hardware SPI.
@note This library is written in pre-SPI-transactions style and needs
some rewriting to correctly share the SPI bus with other devices.
void Adafruit_DotStar::hw_spi_init(void) { // Initialize hardware SPI
#ifdef __AVR_ATtiny85__
PORTB &= ~(_BV(PORTB1) | _BV(PORTB2)); // Outputs
DDRB |= _BV(PORTB1) | _BV(PORTB2); // DO (NOT MOSI) + SCK
#elif (SPI_INTERFACES_COUNT > 0) || !defined(SPI_INTERFACES_COUNT)
SPI1.begin();
// Hardware SPI clock speeds are chosen to run at roughly 1-8 MHz for most
// boards, providing a slower but more reliable experience by default. If
// you want faster LED updates, experiment with the clock speeds to find
// what works best with your particular setup.
#if defined(__AVR__) || defined(CORE_TEENSY) || defined(__ARDUINO_ARC__) || defined(__ARDUINO_X86__)
SPI1.setClockDivider(SPI_CLOCK_DIV2); // 8 MHz (6 MHz on Pro Trinket 3V)
#else
#ifdef ESP8266
SPI1.setFrequency(8000000L);
#elif defined(PIC32)
// Use begin/end transaction to set SPI clock rate
SPI1.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
SPI1.endTransaction();
#else
SPI1.setClockDivider((F_CPU + 4000000L) / 8000000L); // 8-ish MHz on Due
SPI1.setBitOrder(MSBFIRST);
SPI1.setDataMode(SPI_MODE0);
@brief Stop hardware SPI.
void Adafruit_DotStar::hw_spi_end(void) {
DDRB &= ~(_BV(PORTB1) | _BV(PORTB2)); // Inputs
SPI1.end();
@brief Initialize 'soft' (bitbang) SPI. Data and clock pins are set
to outputs.
void Adafruit_DotStar::sw_spi_init(void) {
pinMode(dataPin , OUTPUT);
pinMode(clockPin, OUTPUT);
#ifdef __AVR__
dataPort = portOutputRegister(digitalPinToPort(dataPin));
clockPort = portOutputRegister(digitalPinToPort(clockPin));
dataPinMask = digitalPinToBitMask(dataPin);
clockPinMask = digitalPinToBitMask(clockPin);
*dataPort &= ~dataPinMask;
*clockPort &= ~clockPinMask;
#else
digitalWrite(dataPin , LOW);
digitalWrite(clockPin, LOW);
@brief Stop 'soft' (bitbang) SPI. Data and clock pins are set to inputs.
void Adafruit_DotStar::sw_spi_end() {
pinMode(dataPin , INPUT);
pinMode(clockPin, INPUT);
// Teensy/Gemma-specific stuff for hardware-half-assisted SPI
#define SPIBIT \
USICR = ((1<<USIWM0)|(1<<USITC)); \
USICR = ((1<<USIWM0)|(1<<USITC)|(1<<USICLK)); // Clock bit tick, tock
static void spi_out(uint8_t n) { // Clock out one byte
USIDR = n;
SPIBIT SPIBIT SPIBIT SPIBIT SPIBIT SPIBIT SPIBIT SPIBIT
// All other boards have full-featured hardware support for SPI
#define spi_out(n) (void)SPI1.transfer(n) ///< Call hardware SPI function
// Pipelining reads next byte while current byte is clocked out
#if (defined(__AVR__) && !defined(__AVR_ATtiny85__)) || defined(CORE_TEENSY)
#define SPI_PIPELINE
#else // no hardware spi
#define spi_out(n) sw_spi_out(n)
@brief Soft (bitbang) SPI write.
@param n 8-bit value to transfer.
void Adafruit_DotStar::sw_spi_out(uint8_t n) {
for(uint8_t i=8; i--; n <<= 1) {
#ifdef __AVR__
if(n & 0x80) *dataPort |= dataPinMask;
else *dataPort &= ~dataPinMask;
*clockPort |= clockPinMask;
#else
if(n & 0x80) digitalWrite(dataPin, HIGH);
else digitalWrite(dataPin, LOW);
digitalWrite(clockPin, HIGH);
#if F_CPU >= 48000000
__asm__ volatile(
"nop \n nop"
__asm__ volatile(
"nop \n nop"
/* ISSUE DATA TO LED STRIP -------------------------------------------------
Although the LED driver has an additional per-pixel 5-bit brightness
setting, it is NOT used or supported here. On APA102, the normally
very fast PWM is gated through a much slower PWM (about 400 Hz),
rendering it useless for POV or other high-speed things that are
probably why one is using DotStars instead of NeoPixels in the first
place. I'm told that some APA102 clones use current control rather than
PWM for this, which would be much more worthwhile. Still, no support
here, no plans for it. If you really can't live without it, you can fork
the library and add it for your own use, but any pull requests for this
are unlikely be merged for the foreseeable future.
@brief Transmit pixel data in RAM to DotStars.
void Adafruit_DotStar::show(void) {
if(!pixels) return;
uint8_t *ptr = pixels, i; // -> LED data
uint16_t n = numLEDs; // Counter
uint16_t b16 = (uint16_t)brightness; // Type-convert for fixed-point math
if(dataPin == USE_HW_SPI) {
// TO DO: modernize this for SPI transactions
#ifdef SPI_PIPELINE
uint8_t next;
for(i=0; i<3; i++) spi_out(0x00); // First 3 start-frame bytes
SPDR = 0x00; // 4th is pipelined
do { // For each pixel...
while(!(SPSR & _BV(SPIF))); // Wait for prior byte out
SPDR = 0xFF; // Pixel start
for(i=0; i<3; i++) { // For R,G,B...
next = brightness ? (*ptr++ * b16) >> 8 : *ptr++; // Read, scale
SPDR = next; // Write scaled color
} while(--n);
while(!(SPSR & _BV(SPIF))); // Wait for last byte out
#else
for(i=0; i<4; i++) spi_out(0x00); // 4 byte start-frame marker
if(brightness) { // Scale pixel brightness on output
spi_out(0xFF); // Pixel start
for(i=0; i<3; i++) spi_out((*ptr++ * b16) >> 8); // Scale, write RGB
} while(--n);
} else { // Full brightness (no scaling)
for(i=0; i<3; i++) spi_out(*ptr++); // Write R,G,B
} while(--n);
// Four end-frame bytes are seemingly indistinguishable from a white
// pixel, and empirical testing suggests it can be left out...but it's
// always a good idea to follow the datasheet, in case future hardware
// revisions are more strict (e.g. might mandate use of end-frame
// before start-frame marker). i.e. let's not remove this. But after
// testing a bit more the suggestion is to use at least (numLeds+1)/2
// high values (1) or (numLeds+15)/16 full bytes as EndFrame. For details see also:
// [url]https://cpldcpu.wordpress.com/2014/11/30/understanding-the-apa102-superled/[/url]
for(i=0; i<((numLEDs + 15) / 16); i++) spi_out(0xFF);
} else { // Soft (bitbang) SPI
for(i=0; i<4; i++) sw_spi_out(0); // Start-frame marker
sw_spi_out(0xFF); // Pixel start
for(i=0; i<3; i++) sw_spi_out((*ptr++ * b16) >> 8); // Scale, write
} while(--n);
for(i=0; i<3; i++) sw_spi_out(*ptr++); // R,G,B
} while(--n);
for(i=0; i<((numLEDs + 15) / 16); i++) sw_spi_out(0xFF); // End-frame marker (see note above)
@brief Fill the whole DotStar strip with 0 / black / off.
void Adafruit_DotStar::clear() {
memset(pixels, 0, (rOffset == gOffset) ?
numLEDs + ((numLEDs + 3) / 4) : // MONO: 10 bits/pixel
numLEDs * 3); // COLOR: 3 bytes/pixel
@brief Set a pixel's color using separate red, green and blue components.
@param n Pixel index, starting from 0.
@param r Red brightness, 0 = minimum (off), 255 = maximum.
@param g Green brightness, 0 = minimum (off), 255 = maximum.
@param b Blue brightness, 0 = minimum (off), 255 = maximum.
void Adafruit_DotStar::setPixelColor(
uint16_t n, uint8_t r, uint8_t g, uint8_t b) {
if(n < numLEDs) {
uint8_t *p = &pixels[n * 3];
p[rOffset] = r;
p[gOffset] = g;
p[bOffset] = b;
@brief Set a pixel's color using a 32-bit 'packed' RGB value.
@param c 32-bit color value. Most significant byte is 0, second is
red, then green, and least significant byte is blue.
e.g. 0x00RRGGBB
void Adafruit_DotStar::setPixelColor(uint16_t n, uint32_t c) {
if(n < numLEDs) {
p[rOffset] = (uint8_t)(c >> 16);
p[gOffset] = (uint8_t)(c >> 8);
p[bOffset] = (uint8_t)c;
@brief Fill all or part of the DotStar strip with a color.
is red, then green, and least significant byte is blue.
e.g. 0x00RRGGBB. If all arguments are unspecified, this
will be 0 (off).
@param first Index of first pixel to fill, starting from 0. Must be
in-bounds, no clipping is performed. 0 if unspecified.
@param count Number of pixels to fill, as a positive value. Passing
0 or leaving unspecified will fill to end of strip.
void Adafruit_DotStar::fill(uint32_t c, uint16_t first, uint16_t count) {
uint16_t i, end;
if(first >= numLEDs) {
return; // If first LED is past end of strip, nothing to do
// Calculate the index ONE AFTER the last pixel to fill
if(count == 0) {
// Fill to end of strip
end = numLEDs;
// Ensure that the loop won't go past the last pixel
end = first + count;
if(end > numLEDs) end = numLEDs;
for(i = first; i < end; i++) {
this->setPixelColor(i, c);
@brief Convert hue, saturation and value into a packed 32-bit RGB color
that can be passed to setPixelColor() or other RGB-compatible
functions.
@param hue An unsigned 16-bit value, 0 to 65535, representing one full
loop of the color wheel, which allows 16-bit hues to "roll
over" while still doing the expected thing (and allowing
more precision than the wheel() function that was common to
prior DotStar and NeoPixel examples).
@param sat Saturation, 8-bit value, 0 (min or pure grayscale) to 255
(max or pure hue). Default of 255 if unspecified.
@param val Value (brightness), 8-bit value, 0 (min / black / off) to
255 (max or full brightness). Default of 255 if unspecified.
@return Packed 32-bit RGB color. Result is linearly but not perceptually
correct, so you may want to pass the result through the gamma32()
function (or your own gamma-correction operation) else colors may
appear washed out. This is not done automatically by this
function because coders may desire a more refined gamma-
correction function than the simplified one-size-fits-all
operation of gamma32(). Diffusing the LEDs also really seems to
help when using low-saturation colors.
uint32_t Adafruit_DotStar::ColorHSV(uint16_t hue, uint8_t sat, uint8_t val) {
uint8_t r, g, b;
// Remap 0-65535 to 0-1529. Pure red is CENTERED on the 64K rollover;
// 0 is not the start of pure red, but the midpoint...a few values above
// zero and a few below 65536 all yield pure red (similarly, 32768 is the
// midpoint, not start, of pure cyan). The 8-bit RGB hexcone (256 values
// each for red, green, blue) really only allows for 1530 distinct hues
// (not 1536, more on that below), but the full unsigned 16-bit type was
// chosen for hue so that one's code can easily handle a contiguous color
// wheel by allowing hue to roll over in either direction.
hue = (hue * 1530L + 32768) / 65536;
// Because red is centered on the rollover point (the +32768 above,
// essentially a fixed-point +0.5), the above actually yields 0 to 1530,
// where 0 and 1530 would yield the same thing. Rather than apply a
// costly modulo operator, 1530 is handled as a special case below.
// So you'd think that the color "hexcone" (the thing that ramps from
// pure red, to pure yellow, to pure green and so forth back to red,
// yielding six slices), and with each color component having 256
// possible values (0-255), might have 1536 possible items (6*256),
// but in reality there's 1530. This is because the last element in
// each 256-element slice is equal to the first element of the next
// slice, and keeping those in there this would create small
// discontinuities in the color wheel. So the last element of each
// slice is dropped...we regard only elements 0-254, with item 255
// being picked up as element 0 of the next slice. Like this:
// Red to not-quite-pure-yellow is: 255, 0, 0 to 255, 254, 0
// Pure yellow to not-quite-pure-green is: 255, 255, 0 to 1, 255, 0
// Pure green to not-quite-pure-cyan is: 0, 255, 0 to 0, 255, 254
// and so forth. Hence, 1530 distinct hues (0 to 1529), and hence why
// the constants below are not the multiples of 256 you might expect.
// Convert hue to R,G,B (nested ifs faster than divide+mod+switch):
if(hue < 510) { // Red to Green-1
b = 0;
if(hue < 255) { // Red to Yellow-1
r = 255;
g = hue; // g = 0 to 254
} else { // Yellow to Green-1
r = 510 - hue; // r = 255 to 1
g = 255;
} else if(hue < 1020) { // Green to Blue-1
r = 0;
if(hue < 765) { // Green to Cyan-1
g = 255;
b = hue - 510; // b = 0 to 254
} else { // Cyan to Blue-1
g = 1020 - hue; // g = 255 to 1
b = 255;
} else if(hue < 1530) { // Blue to Red-1
g = 0;
if(hue < 1275) { // Blue to Magenta-1
r = hue - 1020; // r = 0 to 254
b = 255;
} else { // Magenta to Red-1
r = 255;
b = 1530 - hue; // b = 255 to 1
} else { // Last 0.5 Red (quicker than % operator)
r = 255;
g = b = 0;
// Apply saturation and value to R,G,B, pack into 32-bit result:
uint32_t v1 = 1 + val; // 1 to 256; allows >>8 instead of /255
uint16_t s1 = 1 + sat; // 1 to 256; same reason
uint8_t s2 = 255 - sat; // 255 to 0
return ((((((r * s1) >> 8) + s2) * v1) & 0xff00) << 8) |
(((((g * s1) >> 8) + s2) * v1) & 0xff00) |
( ((((b * s1) >> 8) + s2) * v1) >> 8);
@brief Query the color of a previously-set pixel.
@param n Index of pixel to read (0 = first).
@return 'Packed' 32-bit RGB value. Most significant byte is 0, second is
uint32_t Adafruit_DotStar::getPixelColor(uint16_t n) const {
if(n >= numLEDs) return 0;
return ((uint32_t)p[rOffset] << 16) |
((uint32_t)p[gOffset] << 8) |
(uint32_t)p[bOffset];
@brief Adjust output brightness. Does not immediately affect what's
currently displayed on the LEDs. The next call to show() will
refresh the LEDs at this level.
@param b Brightness setting, 0=minimum (off), 255=brightest.
@note For various reasons I think brightness is better handled in
one's sketch, but it's here for parity with the NeoPixel
library. Good news is that brightness setting in this library
is 'non destructive' -- it's applied as color data is being
issued to the strip, not during setPixelColor(), and also
means that getPixelColor() returns the exact value originally
stored.
void Adafruit_DotStar::setBrightness(uint8_t b) {
// Stored brightness value is different than what's passed. This
// optimizes the actual scaling math later, allowing a fast 8x8-bit
// multiply and taking the MSB. 'brightness' is a uint8_t, adding 1
// here may (intentionally) roll over...so 0 = max brightness (color
// values are interpreted literally; no scaling), 1 = min brightness
// (off), 255 = just below max brightness.
brightness = b + 1;
@brief Retrieve the last-set brightness value for the strip.
@return Brightness value: 0 = minimum (off), 255 = maximum.
uint8_t Adafruit_DotStar::getBrightness(void) const {
return brightness - 1; // Reverse above operation
@brief A gamma-correction function for 32-bit packed RGB colors.
Makes color transitions appear more perceptially correct.
@param x 32-bit packed RGB color.
@return Gamma-adjusted packed color, can then be passed in one of the
setPixelColor() functions. Like gamma8(), this uses a fixed
gamma correction exponent of 2.6, which seems reasonably okay
for average DotStars in average tasks. If you need finer
control you'll need to provide your own gamma-correction
function instead.
uint32_t Adafruit_DotStar::gamma32(uint32_t x) {
uint8_t *y = (uint8_t *)&x;
// All four bytes of a 32-bit value are filtered to avoid a bunch of
// shifting and masking that would be necessary for properly handling
// different endianisms (and each byte is a fairly trivial operation,
// so it might not even be wasting cycles vs a check and branch.
// In theory this might cause trouble *if* someone's storing information
// in the unused most significant byte of an RGB value, but this seems
// exceedingly rare and if it's encountered in reality they can mask
// values going in or coming out.
for(uint8_t i=0; i<4; i++) y[i] = gamma8(y[i]);
return x; // Packed 32-bit return
SPI.begin();
[COLOR="#FF0000"]#if defined(__AVR__) || defined(CORE_TEENSY) || defined(__ARDUINO_ARC__) || defined(__ARDUINO_X86__)
SPI.setClockDivider(SPI_CLOCK_DIV2); // 8 MHz (6 MHz on Pro Trinket 3V)
#else[/COLOR]
#ifdef ESP8266
SPI.setFrequency(8000000L);
SPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
SPI.endTransaction();
#else
SPI.setClockDivider((F_CPU + 4000000L) / 8000000L); // 8-ish MHz on Due
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
SPI.begin();
[COLOR="#FF0000"]#if defined(SPI_HAS_TRANSACTION)
#elif defined(__AVR__) || defined(CORE_TEENSY) || defined(__ARDUINO_ARC__) || defined(__ARDUINO_X86__)
[/COLOR] SPI.setClockDivider(SPI_CLOCK_DIV2); // 8 MHz (6 MHz on Pro Trinket 3V)
#else
#ifdef ESP8266
#else
Note the pinout card for the T4 does not mention that pin 0 is the CS pin for SPI1 and pin 1 is the MISO pin.
I'm new to Teensy 4 and this forum as of tonight, and MichaelMeissner's comment above from 2019 was precisely the answer I was looking for after noticing that not all of the advertised [3-SPI Port] pins were identified on the T4 pinout card. Hopefully my comment here might help others find this answer more quickly.
Quick note: The website: https://www.pjrc.com/store/teensy40.html#pins
Now at mentions pins 0 and 1 in the pins section. Wish it was on the real card, but ...
