sid8580
I need to get this simple sketch to use the SDfat library instead of the default SD.
If anyone can tell me what I'm doing wrong I'd greatly appreciate it. I've tried to cut it down to the bare minimum for readability:
bmpDraw is straight out of the spitftbitmap example sketch that is included with the Teensy optimized ST7735 library.
SDfat works fine in a different program where I've used it to load and save settings for the device I'm building, and I have duplicated the way it's initialized into this example, but when I call bmpDraw I get this in the serial monitor:
Loading image 'vui24.bmp'
File size: 2738376002
Image Offset: 2738376002
Header size: 2738376002
BMP format not recognized.
The file is 176k, not 2.xGB like this is showing (and it's a 512mb microSD card...). I don't understand why SDfat works for my primary project but will not for this example. If I use the normal SD library in the example sketch the image will load and display properly so everything else works.
Thanks in advance.
#define USE_FRAME_BUFFER
#define TFT_SCLK 32 // SCLK can also use pin 14
#define TFT_MOSI 0 // MOSI can also use pin 7
#define TFT_CS 30 // CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
#define TFT_DC 31 // but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
#define TFT_RST 29 // RST can use any pin
//#define SD_CS 55 // CS for SD card, can use any pin
#include <Adafruit_GFX.h> // Core graphics library
#include <ST7789_t3.h> // Hardware-specific library
// For 1.54" or other TFT with ST7789, This has worked with some ST7789
// displays without CS pins, for those you can pass in -1 or 0xff for CS
// More notes by the tft.init call
ST7789_t3 tft = ST7789_t3(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
// standard SD library // works
//#include <SD.h>
//const int chipSelect = BUILTIN_SDCARD;
//SdioEX SD library // doesn't work
#include "SDFat.h"
SdFatSdioEX SD;
//File bmpFile; // redundant?
void setup(void) {
//pinMode(SD_CS, INPUT_PULLUP); // don't touch the SD card
Serial.print("hello!");
// SD card init //
// //standard SD library
// if (!SD.begin(chipSelect)) {
// Serial.println("initialization failed!");
// return;
// Serial.println("initialization done.");
// //SdioEX SD library
if (!SD.begin()) {
return;
// Display init
tft.init(240, 240); // initialize a ST7789 chip, 240x240 pixels
Serial.println("init display complete");
// Display test
tft.fillScreen(0x0000);
delay(2000);
tft.setRotation(2);
bmpDraw("vui24.bmp", 0, 0); //vui24.bmp is a 176k, 24 bit, 240x240 bitmap that works with this display
// nothing needed here
#define BUFFPIXEL 20
void bmpDraw(const char *filename, uint8_t x, uint8_t y) {
File bmpFile;
int bmpWidth, bmpHeight; // W+H in pixels
uint8_t bmpDepth; // Bit depth (currently must be 24)
uint32_t bmpImageoffset; // Start of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
uint8_t buffidx = sizeof(sdbuffer); // Current position in sdbuffer
boolean goodBmp = false; // Set to true on valid header parse
boolean flip = true; // BMP is stored bottom-to-top
int w, h, row, col;
uint8_t r, g, b;
uint32_t pos = 0, startTime = millis();
if((x >= tft.width()) || (y >= tft.height())) return;
Serial.print("Loading image '");
Serial.print(filename);
Serial.println('\'');
// Open requested file on SD card
bmpFile = SD.open(filename);
if (!bmpFile) {
Serial.print("File not found");
tft.setCursor(12, tft.height()/2 - 12);
tft.print("Unable to");
tft.setCursor(12, tft.height()/2 - 0);
tft.print("read file: ");
tft.setCursor(12, tft.height()/2 + 12);
tft.setTextColor(0xffff);
tft.print(filename);
return;
// Parse BMP header
if(read16(bmpFile) == 0x4D42) { // BMP signature
Serial.print("File size: "); Serial.println(read32(bmpFile));
(void)read32(bmpFile); // Read & ignore creator bytes
bmpImageoffset = read32(bmpFile); // Start of image data
Serial.print("Image Offset: "); Serial.println(bmpImageoffset, DEC);
// Read DIB header
Serial.print("Header size: "); Serial.println(read32(bmpFile));
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
if(read16(bmpFile) == 1) { // # planes -- must be '1'
bmpDepth = read16(bmpFile); // bits per pixel
Serial.print("Bit Depth: "); Serial.println(bmpDepth);
if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
goodBmp = true; // Supported BMP format -- proceed!
Serial.print("Image size: ");
Serial.print(bmpWidth);
Serial.print('x');
Serial.println(bmpHeight);
// BMP rows are padded (if needed) to 4-byte boundary
rowSize = (bmpWidth * 3 + 3) & ~3;
// If bmpHeight is negative, image is in top-down order.
// This is not canon but has been observed in the wild.
if(bmpHeight < 0) {
bmpHeight = -bmpHeight;
flip = false;
// Crop area to be loaded
w = bmpWidth;
h = bmpHeight;
if((x+w-1) >= tft.width()) w = tft.width() - x;
if((y+h-1) >= tft.height()) h = tft.height() - y;
// Set TFT address window to clipped image bounds
tft.setAddrWindow(x, y, x+w-1, y+h-1);
for (row=0; row<h; row++) { // For each scanline...
// Seek to start of scan line. It might seem labor-
// intensive to be doing this on every line, but this
// method covers a lot of gritty details like cropping
// and scanline padding. Also, the seek only takes
// place if the file position actually needs to change
// (avoids a lot of cluster math in SD library).
if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
else // Bitmap is stored top-to-bottom
pos = bmpImageoffset + row * rowSize;
if(bmpFile.position() != pos) { // Need seek?
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer); // Force buffer reload
for (col=0; col<w; col++) { // For each pixel...
// Time to read more pixel data?
if (buffidx >= sizeof(sdbuffer)) { // Indeed
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0; // Set index to beginning
// Convert pixel from BMP to TFT format, push to display
b = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
r = sdbuffer[buffidx++];
tft.pushColor(tft.Color565(r,g,b));
} // end pixel
} // end scanline
Serial.print("Loaded in ");
Serial.print(millis() - startTime);
Serial.println(" ms");
} // end goodBmp
bmpFile.close();
if(!goodBmp) Serial.println("BMP format not recognized.");
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
uint16_t result;
((uint8_t *)&result)[0] = f.read(); // LSB
((uint8_t *)&result)[1] = f.read(); // MSB
return result;
uint32_t read32(File f) {
uint32_t result;
((uint8_t *)&result)[2] = f.read();
((uint8_t *)&result)[3] = f.read(); // MSB
return result;
Thanks in advance.
