Results 1 to 5 of 5
Thread: What pin number for Teensy 3.6 SD card chip select pin?
    Chipping Norton, UK
    271
    Can anyone tell me what the pin number is for the Teensy 3.6 SD card chip select pin?
    20,553
    If you're connecting a SD card to the SPI pins (11, 12, 13), then you can use any other digital pin for CS.
    If you're using the SD socket that's built into Teensy 3.6, use SD.begin(BUILTIN_SDCARD);
    In Arduino, click File > Examples > SD and open any of those examples. The comments explain your options.
    Chipping Norton, UK
    271
    I am using the SD formatter code from https://github.com/greiman/SdFat.git and BUILTIN_SDCARD is coming up as not defined, what actual pin number is it? I do not see a format example in the SD library.
    2,330
    Have a look into
    https://github.com/greiman/SdFat/blo...sySdioDemo.ino
    to see how Bill is handling SDIO (i.e. Teensy3.6 internal sdCard) and adapt other examples from Bill's examples list
    2,191
    Quote Originally Posted by Experimentalist View Post
    edit SdFat/examples/SdFormatter/SdFormatter.ino to read #define USE_SDIO 1
    though i haven't used SdFat lately ...
