Results 1 to 5 of 5
Thread: PCF8574P Port Expander and Teensy 3.2
    Member dimitre's Avatar
    Aug 2016
    São Paulo
    75
    I'm trying to use the PCF8574P port expander with Teensy 3.2 but I can't receive the transmission yet.
    I'm posting the wiring and the code.
    interrupt seems to be working, but no transmission yet.
    If I use pullup resistors in i2c ports the interrupt stops working.
    I've tried different chips, different teensies and checked continuity for all connections.
    Tried a i2c port scanner too and it doesn't find i2c device in any address.
    Ideas are very welcome
    //PCF8574P
    //Thanks for your help, my IC is a PCF8574AF, so the correct address was 0x38 (decimal 56)
    //B00100000 //B00111000
    #define EXPANDER 0x20  //expander address
      Wire.begin();
      delay(300);
      expanderWrite(B11111111);
      attachInterrupt(5, expanderInterrupt, CHANGE);
      Serial.println("begin ");
      Serial.println(EXPANDER);
      Wire.requestFrom(EXPANDER, 1);
      if (Wire.available()) {
        byte _data = Wire.read();
        Serial.print("DATA :: ");
        Serial.println(_data, BIN);
        Serial.println(_data);
        byte inpBuff = _data & 0x01;
        Serial.println(inpBuff, HEX);
    void expanderInterrupt() {
      Serial.print("interrupt :: ");
        byte _data = 0;
      Serial.println("------------------------");
    void expanderWrite(byte _data ) {
      Wire.beginTransmission(EXPANDER);
      Wire.write(_data);
      Wire.endTransmission();
    //byte expanderRead() {
    //  byte _data = 0;
    //  Wire.requestFrom(EXPANDER, 1);
    //  if (Wire.available()) {
    //    _data = Wire.read();
    //    Serial.println(_data, BIN);
    //  return _data;
    and scanner code
    // i2c_scanner
    // Version 1
    //    This program (or code that looks like it)
    //    can be found in many places.
    //    For example on the Arduino.cc forum.
    //    The original author is not known.
    // Version 2, Juni 2012, Using Arduino 1.0.1
    //     Adapted to be as simple as possible by Arduino.cc user Krodal
    // Version 3, Feb 26  2013
    //    V3 by louarnold
    // Version 4, March 3, 2013, Using Arduino 1.0.3
    //    by Arduino.cc user Krodal.
    //    Changes by louarnold removed.
    //    Scanning addresses changed from 0...127 to 1...119,
    //    according to the i2c scanner by Nick Gammon
    //    http://www.gammon.com.au/forum/?id=10896
    // Version 5, March 28, 2013
    //    As version 4, but address scans now to 127.
    //    A sensor seems to use address 120.
    // This sketch tests the standard 7-bit addresses
    // Devices with higher bit address might not be seen properly.
      Wire.begin();
      Serial.println("\nI2C Scanner");
      byte error, address;
      int nDevices;
      Serial.println("Scanning...");
      nDevices = 0;
      for(address = 1; address < 127; address++ )
        // The i2c_scanner uses the return value of
        // the Write.endTransmisstion to see if
        // a device did acknowledge to the address.
        Wire.beginTransmission(address);
        error = Wire.endTransmission();
        if (error == 0)
          Serial.print("I2C device found at address 0x");
          if (address<16)
            Serial.print("0");
          Serial.print(address,HEX);
          Serial.println("  !");
          nDevices++;
        else if (error==4)
          Serial.print("Unknow error at address 0x");
          if (address<16)
            Serial.print("0");
          Serial.println(address,HEX);
      if (nDevices == 0)
        Serial.println("No I2C devices found\n");
        Serial.println("done\n");
      delay(5000);           // wait 5 seconds for next scan
    Dec 2016
    Montreal, Canada
    3,117
    I don’t see any pullups on I2C. You absolutely need them
    Aug 2016
    São Paulo
    75
    Thanks @tonton81.
    I've updated with some pullups and data is transmitting but interrupt pin stopped working. should I do something in that pin too?
    I've changed IC VCC to 3.3v now so I use pullups on the protoboard.
    which range of resistors should I use for i2c pullup?
    Nov 2017
    Belgium
    140
    @dimitre
    The PCF8574 INT pin is open drain, so it also needs a pullup resistor. Any value between 4k7 & 10k should do it.
    Aug 2016
    São Paulo
    75
    outstanding. everything working now
