Results 1 to 3 of 3
Thread: Need help writing a library
    Apr 2017
    187
    All,
    I have a neat graphing function that plots stuff like temperatures or voltages over time. The problem is a big ugly function and is hard to update to draw say 2 variables. I can re-code it for 2 variables, but maybe I want more. Ultimately I would like a library to make plotting data easier. I've made my function available (shown in a YouTube vid) and I'd like to make this lib publicly available as well. Maybe something such as:
    create a MyGraph object (pass in display)
    create Plot1 object (pass in graph object)
    create Plot2 object (pass in graph object)
    then in setup ()
    MyGraph.draw() // draws graph, scale, title on the display
    then in loop()
    Getdata()
    Plot1.draw(temperature)
    Plot2.draw(humidity)
    Here's the start of my class but complier errors out when I try to pass the graph object into the plot objects.
    How do I pass the graph object to other objects? so the plot objects writes lines and such to the graph object?
    .h
    #ifndef GRAPH_H
    #define GRAPH_H
    #if ARDUINO >= 100
     #include "Arduino.h"
     #include "Print.h"
    #else
     #include "WProgram.h"
    #include <ILI9341_t3.h>
    class Graph {
     public:
    	Graph(ILI9341_t3 *disp);
    	void init(float scaleLow = 100.0, float scaleHi = 100.0, float scale = 0.0, float snap = 0.0);
    	void draw();
    private:
    	ILI9341_t3 *_d;
    	float _sl;
    	float _sh;
    	float _sc;
    	float _sn;
    	uint16_t _sColor;
    	uint16_t _bColor;
    	uint16_t _hColor;
    class Plot {
    public:
    // here's where it fails to compile but I don't know how to pass an object to an object
    	Plot(Graph *g);
    	void draw(float x, float y);
    private:
    	Graph *_g;
    	float _x;
    	float _y;
    .cpp
    #include "Graph.h"
    #include <ILI9341_t3.h>     // fast display driver lib
    Graph::Graph(ILI9341_t3 *disp) {
    		_d = disp;
    void Graph::init(float scaleLow, float scaleHi, float scale, float snap) {
       	_sl = scaleLow;
    	_sh = scaleHi;
    	_sc = scale;
    	_sn = snap;
    void Graph::draw() {
    	_d->fillScreen(0x255);
    	//draw grid, scales, etc.
    void Plot::Plot(Graph *g) {
    	_g = g;
    void Plot::draw(float x, float y) {
    	_x = x;
    	_y = y;
    	// _g->drawLine(_x, _y, x + 10, _y + 10);
    possible .ino code implementation
    #include "UTouch.h"       // touchscreen lib
    #include <Graph.h>        // custom control define file
    // create display and DS objects
    ILI9341_t3 Display = ILI9341_t3(10, 9, 240, 320);
    // create the touch screen object
    UTouch  Touch( 6, 5, 4, 3, 2);
    // create the graph object
    Graph TheGraph(&Display);
    // create plot objects to be drawn on TheGraph (need to be flexible so n plots can be drawn
    Plot Temp(&TheGraph);
    Plot Humidity(&TheGraph);
    Plot Pressure(&TheGraph);
      Display.begin();
      // fire up the touch display
      Touch.InitTouch(PORTRAIT);
      Touch.setPrecision(PREC_EXTREME);
      TheGraph.init(); // function or functions to draw the cartesian coordinate system (omitted are arguments for the scales colors, etc)
    // get temp
    Temp.draw(TheTemperature);
    // get Humidity
    Temp.draw(TheHumidity);
    // get pressure
    Temp.draw(ThePressure);
    New York
    4,101
    @KrisKasprzak
    I think you are talking about this one on you tube: https://www.youtube.com/watch?v=YejRbIKe6e0&t=4s
    Really nice had it running on the ILI9488 with the T4 as a test.
    Would love to help but right in middle of another test site - a day or two. But just a couple of notes. That one is almost a library in and unto itself and probably more flexible for different graphs. Think the biggest challenge is going to be supporting different displays like the 9341 and 9488.
    Apr 2017
    187
    Yep, that's my graphing function. I think supporting other displays is relatively easy. Just as long as the lib leverages Adafruit_GFX, only the display data type in the object creation needs to be changed.
