slo@sloNano:~$ arduino
Command 'arduino' not found, but can be installed with:
sudo apt install arduino
slo@sloNano:~$ export PATH="$PATH:/home/slo/bin/arduino-1.8.10"
slo@sloNano:~$ source ~/.profile
Picked up JAVA_TOOL_OPTIONS:
Set log4j store directory /home/slo/.arduino15
[JmDNS(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).Timer] WARN javax.jmdns.impl.tasks.resolver.DNSResolverTask - ServiceResolver(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).run() exception
java.io.IOException: Cannot assign requested address (sendto failed)
at java.net.PlainDatagramSocketImpl.send(Native Method)
at java.net.DatagramSocket.send(DatagramSocket.java:693)
at javax.jmdns.impl.JmDNSImpl.send(JmDNSImpl.java:1618)
at javax.jmdns.impl.tasks.resolver.DNSResolverTask.run(DNSResolverTask.java:73)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
[fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover()] WARN javax.jmdns.impl.JmDNSImpl - RECOVERING
[JmDNS(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).State.Timer] WARN javax.jmdns.impl.tasks.state.DNSStateTask - Canceler(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).run() exception
at javax.jmdns.impl.tasks.state.DNSStateTask.run(DNSStateTask.java:131)
[fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover()] WARN javax.jmdns.impl.DNSStatefulObject$DefaultImplementation - Wait for canceled timed out: DNS: fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local. [fe80:0:0:0:5de6:8665:7fcd:96fe%wlan0/fe80:0:0:0:5de6:8665:7fcd:96fe%wlan0] state: canceling 1 task: null
[fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover()] WARN javax.jmdns.impl.JmDNSImpl - fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover() Could not recover we are Down!
2019-09-29T07:53:42.383Z INFO c.a.c.p.ContributionInstaller:305 [Timer-0] Start download and signature check of=[https://downloads.arduino.cc/packages/package_index.json]
2019-09-29T07:53:42.444Z INFO c.a.u.n.FileDownloaderCache:92 [Timer-0] Cache folder /home/slo/.arduino15/cache
2019-09-29T07:53:42.609Z INFO c.a.u.n.FileDownloaderCache:112 [Timer-0] Number of file already in the cache 4
2019-09-29T07:53:42.708Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='e5333ff208bec8f067589a99b43a1285', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json', md5='MD5:e5333ff208bec8f067589a99b43a1285', createdAt='2019-09-29T02:40:21.973', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.734Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='e5333ff208bec8f067589a99b43a1285', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json', md5='MD5:e5333ff208bec8f067589a99b43a1285', createdAt='2019-09-29T02:40:21.973', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.737Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json]
2019-09-29T07:53:42.742Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='330f326540998b47fa4d733ed5f6eef9', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json.sig', md5='MD5:330f326540998b47fa4d733ed5f6eef9', createdAt='2019-09-29T02:40:22.49', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.748Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='330f326540998b47fa4d733ed5f6eef9', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json.sig', md5='MD5:330f326540998b47fa4d733ed5f6eef9', createdAt='2019-09-29T02:40:22.49', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.750Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json.sig]
2019-09-29T07:53:42.774Z INFO c.a.c.DownloadableContributionsDownloader:222 [Timer-0] Signature verified. url=https://downloads.arduino.cc/packages/package_index.json.sig, signature url=https://downloads.arduino.cc/packages/package_index.json.sig, file to verify=/tmp/package_index.json8311399446740338176.tmp, signature file=/tmp/package_index.json.sig4580471798081923638.tmp
2019-09-29T07:53:42.779Z INFO c.a.c.p.ContributionInstaller:314 [Timer-0] Downloaded package index URL=[https://downloads.arduino.cc/packages/package_index.json]
2019-09-29T07:53:42.787Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='6cbd521329168ca1a68348286a8c1bb5', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz', md5='MD5:6cbd521329168ca1a68348286a8c1bb5', createdAt='2019-09-29T02:40:24.296', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.809Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='6cbd521329168ca1a68348286a8c1bb5', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz', md5='MD5:6cbd521329168ca1a68348286a8c1bb5', createdAt='2019-09-29T02:40:24.296', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.811Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz]
2019-09-29T07:53:42.932Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='3e68f102a17273a8c3bab174740c9d9d', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.sig', md5='MD5:3e68f102a17273a8c3bab174740c9d9d', createdAt='2019-09-29T02:40:25.449', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.944Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='3e68f102a17273a8c3bab174740c9d9d', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.sig', md5='MD5:3e68f102a17273a8c3bab174740c9d9d', createdAt='2019-09-29T02:40:25.449', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2019-09-29T07:53:42.947Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.sig]
2019-09-29T07:53:43.155Z INFO c.a.c.DownloadableContributionsDownloader:222 [Timer-0] Signature verified. url=https://downloads.arduino.cc/libraries/library_index.json.sig, signature url=https://downloads.arduino.cc/libraries/library_index.json.sig, file to verify=/tmp/library_index.json6198172837891228961.tmp, signature file=/tmp/library_index.json.sig7258483909988041405.tmp
slo@sloNano:~$ arduino --verify '/home/slo/Arduino/touchscreemTest/touchscreemTest.ino'
Loading configuration...
Initializing packages...
Preparing boards...
Verifying...
touchscreemTest:1:10: error: ILI9341_t3.h: No such file or directory
#include <ILI9341_t3.h>
compilation terminated.
exit status 1
java.io.IOException: Stream closed
at java.io.BufferedInputStream.getBufIfOpen(BufferedInputStream.java:170)
at java.io.BufferedInputStream.read(BufferedInputStream.java:336)
at com.fasterxml.jackson.core.json.ByteSourceJsonBootstrapper.ensureLoaded(ByteSourceJsonBootstrapper.java:522)
at com.fasterxml.jackson.core.json.ByteSourceJsonBootstrapper.detectEncoding(ByteSourceJsonBootstrapper.java:150)
at com.fasterxml.jackson.core.json.ByteSourceJsonBootstrapper.constructParser(ByteSourceJsonBootstrapper.java:246)
at com.fasterxml.jackson.core.JsonFactory._createParser(JsonFactory.java:1315)
at com.fasterxml.jackson.core.JsonFactory.createParser(JsonFactory.java:820)
at cc.arduino.packages.discoverers.PluggableDiscovery.run(PluggableDiscovery.java:80)
at java.lang.Thread.run(Thread.java:748)
slo@sloNano:~$ arduino --verify touchscreemTest.ino
Preparing boards...
Verifying...
java.io.IOException: No valid code files found
at processing.app.Sketch.listSketchFiles(Sketch.java:117)
at processing.app.Sketch.<init>(Sketch.java:54)
at processing.app.Base.<init>(Base.java:415)
at processing.app.Base.main(Base.java:150)
Preparing boards...
Verifying...
Preparing boards...
Verifying...
Opening Teensy Loader...
Sketch uses 59488 bytes (2%) of program storage space. Maximum is 2031616 bytes.
Global variables use 66096 bytes (6%) of dynamic memory, leaving 982480 bytes for local variables. Maximum is 1048576 bytes.
slo@sloNano:~$ arduino --get-pref
Preparing boards...
#PREFDUMP#
last.sketch.count=0
update.check=true
platform.auto_file_type_associations=true
gui.scale=auto
editor.window.width.default=500
editor.window.height.default=600
editor.window.width.min=400
editor.window.height.min=290
editor.code_folding=true
editor.font=Monospaced,plain,12
editor.antialias=true
editor.external=false
editor.caret.blink=true
editor.invalid=false
editor.linenumbers=true
editor.keys.alternative_cut_copy_paste=true
editor.keys.shift_backspace_is_delete=true
editor.keys.home_and_end_beginning_end_of_doc=false
console=true
console.output.file=stdout.txt
console.error.file=stderr.txt
console.lines=4
console.auto_clear=true
console.length=500
editor.tabs.expand=true
editor.tabs.size=2
editor.indent=true
editor.auto_close_braces=true
editor.divider.size=0
editor.save_on_verify=true
run.options=
run.options.memory=false
run.options.memory.initial=64
run.options.memory.maximum=256
run.display=1
export.application.platform=true
export.application.fullscreen=false
export.application.stop=true
export.applet.separate_jar_files=false
export.delete_target_folder=true
preproc.save_build_files=false
preproc.color_datatype=true
preproc.web_colors=true
preproc.enhanced_casting=true
preproc.substitute_floats=true
preproc.substitute_unicode=true
preproc.output_parse_tree=false
preproc.imports.list=java.applet.*,java.awt.Dimension,java.awt.Frame,java.awt.event.MouseEvent,java.awt.event.KeyEvent,java.awt.event.FocusEvent,java.awt.Image,java.io.*,java.net.*,java.text.*,java.util.*,java.util.zip.*,java.util.regex.*
browser=mozilla
run.present.bgcolor=#666666
run.present.stop.color=#cccccc
run.present.exclusive=false
target_package=teensy
target_platform=avr
board=teensy40
software=ARDUINO
build.warn_data_percentage=75
programmer=arduino:avrispmkii
upload.using=bootloader
upload.verify=true
serial.databits=8
serial.stopbits=1
serial.parity=N
serial.debug_rate=9600
serial.line_ending=1
editor.languages.current=
preferences.readonly=false
runtime.ide.path=/home/slo/bin/arduino-1.8.10
runtime.ide.version=10810
boardsmanager.additional.urls=
build.verbose=true
cache.enable=true
compiler.cache_core=true
compiler.warning_level=none
custom_keys=teensy40_en-us
custom_opt=teensy40_o2std
custom_usb=teensy40_serial
editor.update_extension=true
ide.accessible=false
last.ide.1.8.10.daterun=1569744468
last.ide.1.8.10.hardwarepath=/home/slo/bin/arduino-1.8.10/hardware
last.screen.height=768
last.screen.width=1366
last.sketch.default.location=433,84,500,600,404,0
last.sketch.default.path=/tmp/untitled183572571.tmp/sketch_sep29a/sketch_sep29a.ino
launcher=xdg-open
proxy.manual.hostname=
proxy.manual.password=
proxy.manual.port=
proxy.manual.type=HTTP
proxy.manual.username=
proxy.pac.url=
proxy.type=auto
sketchbook.path=/home/slo/Arduino
theme.file=
update.id=7771706390682478081
update.last=1569742762268
upload.verbose=true
runtime.os=linux
runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.arduino-avr-gcc-7.3.0-atmel3.6.1-arduino5.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.avr-gcc.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.avrdude-6.3.0-arduino17.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.arduino-avrdude-6.3.0-arduino17.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.avrdude.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.arduinoOTA-1.3.0.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.arduino-arduinoOTA-1.3.0.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.tools.arduinoOTA.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
runtime.platform.path=/home/slo/bin/arduino-1.8.10/hardware/teensy/avr
runtime.hardware.path=/home/slo/bin/arduino-1.8.10/hardware/teensy
teensy: Invalid json message
slo@sloNano:~$
