Page 5 of 5 FirstFirst ... 3 4 5
Results 101 to 110 of 110
Thread: Teensyduino 1.48 Beta #1
  1. #101
    New York
    5,893
    @defragster
    I have seen the same thing when I do a verbose compile. From reading the IDE release notes I think that is intentional with the latest IDE.
  2. #102
    In relation to posts #78 and #99 in this thread, I thought I found a bug in the Arduino CLI or possibly the builder, which I reported here
    I don't yet know the ultimate source of that bug. Because I was running Teensyduino 1.48 b1 at the time it may generate a few red herrings. Sorry about that. This post is just an effort to tie all the information together as I am no longer able to edit the previous posts.
  3. #103
    12,685
    @defragster
    @Paul - others? Re message posted here : pjrc.com/threads/57701-USB-Host-Ethernet-Driver
    Anyone seeing extra stuff rebuilding on Rebuild with IDE 1.8.10 and TD 1.48.b1?
    Or added new messages or library during build::
    Alternatives for USBHost_t36.h: [USBHost_t36@0.1]
    ResolveLibrary(USBHost_t36.h)
      -> candidates: [USBHost_t36@0.1]
    Or indications of "Multiple libraries" where there is only a single present and no 2nd indicated::
    Multiple libraries were found for "ASIXEthernet.h"
     Used: T:\tCode\libraries\TeensyASIXEthernet
    Indeed some fuzzy notes in change logs, they meant to do some changes - problem is indications are:
    > Paul's "Multiple libraries were found" work is compromised to give annoying FALSE positives.
    > No longer doing Fast Rebuild without redoing stable objects on each rebuild as the added logic is perhaps unclear on non-existent "Alternatives for "
  4. #104
    Oct 2019
    5
    Hi all.
    Just to confirm that T4 SPI is now working much better for me with the changes to the SPI pin drive strength in this beta. I am using a 1.8V SPI device through level translator and was experiencing some problems.
  5. #105
    7,901
    NOTE: Today it looks like @Paul has/is releasing Beta2 and it should have these changes now built in.
    Along with some other changes, like I believe the change to SPI to work with applications that did not use SPI.beginTransaction on T4...
  6. #106
    3,881
    Talking about SPI, I noticed the SPI page needs to be updated for Teensy 4.0:
    I don't know if spi4teensy3 is still usefu fpr Teensy 3.x (this is listed on the SPI page)l. It was last updated 2+ years ago to support the T3.5/3.6.
  7. #107
    Oct 2019
    4
    Hey folks!
    I got my teensy 4.0 hooked up to a rev C audio board. I followed the directions on the schematic page. I didn't hook up any of the Volume Pot, SD Card or Memory Chip wires, because I don't have any of those in use.
    I am using arduino 1.8.10, with the teensyloader 1.48-beta1.
    Things are working fine (not experiencing any audio clock jitter as far as I can tell) - however, I cannot get any audio code to work _unless_ I run analogRead during the setup function:
    AudioSynthWaveform       waveform1;      //xy=294,323
    AudioEffectFreeverbStereo freeverbs1;     //xy=592,499
    AudioOutputI2S           i2s1;           //xy=756,481
    AudioConnection          patchCord1(waveform1, freeverbs1);
    AudioConnection          patchCord2(freeverbs1, 0, i2s1, 0);
    AudioConnection          patchCord3(freeverbs1, 1, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=805,363
    int count=1;
    int a1history=0;
      // this is the offending line, and I'm not sure why it is necessary
      // it can be placed anywhere within setup, it doesn't seem to matter
      a1history = analogRead(A1);
      AudioMemory(10);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.3);
      Serial.print("Beep #");
      Serial.println(count);
      Serial.println(AudioProcessorUsageMax());
      AudioProcessorUsageMaxReset();
      count = count + 1;
      waveform1.frequency(440);
      waveform1.amplitude(0.9);
      wait(250);
      waveform1.amplitude(0);
      wait(1750);
    void wait(unsigned int milliseconds)
      delay(milliseconds);
    I tested this with the guitar sample as well, and got the same results (no functioning unless I added analogRead).
    When I don't include the analogRead line, and the audio isn't working, the serial monitor fails to work as well, and I can't write new programs without pressing the reset button.
    attached shows my setup, which is admittedly a little rough, but just as long as everything is seated right, these results are reproducible.
  8. #108
    2,593
    Quote Originally Posted by jbrodsky View Post
    1.48-beta1 is haunted by evil spirits. upgrade to 1.48-beta2 or beta3
    https://forum.pjrc.com/threads/57894...no-1-48-Beta-3
  9. #109
    Oct 2019
    4
    Issue resolved in beta3! thanks for the quick response.
  10. #110
    Sep 2019
    19
    Moved to beta 3 thread.
