Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 76 to 100 of 110
Thread: Teensyduino 1.48 Beta #1
  1. #76
    9,923
    Thanks - going to give it a go - it was this line :: PIT_MCR = 0;
    I didn't see in post #61 that was letting me know the pieces were not all in one place ...
  2. #77
    9,923
    With this PIT code in place it starts up:
    	set_arm_clock(600000000);
    	//set_arm_clock(984000000); Ludicrous Speed
    	// Undo PIT timer usage by ROM startup
    	CCM_CCGR1 |= CCM_CCGR1_PIT(CCM_CCGR_ON);
    	PIT_MCR = 0;
    	PIT_TCTRL0 = 0;
    	PIT_TCTRL1 = 0;
    	PIT_TCTRL2 = 0;
    	PIT_TCTRL3 = 0;
    Indeed the T4 starts up with uncanny eyes sketch now- but I must need pin and SPI mode adjustments ? as one screen white pulsing under black - the other no signs - but SerMon scrolling data.
  3. #78
    If you get any messages in red, especially any Java exceptions, please report them on this thread.
    This was red. Arduino 1.8.10 TD 1.48 B1 on a Jetson Nano Ubuntu 18.04 AARCH64 first compile after install and reboot.
    Sketch was the example for XPT2046_Touchscreen. The next compile attempt worked.
    Arduino: 1.8.10 (Linux), TD: 1.48-beta1, Board: "Teensy 4.0, Serial, Faster, US English"
    Opening Teensy Loader...
    Teensy Loader could not find the directory /tmp/arduino_build_278085
    Multiple libraries were found for "ILI9341_t3.h"
    Used: /home/slo/arduino-1.8.10/hardware/teensy/avr/libraries/ILI9341_t3
    Multiple libraries were found for "SPI.h"
    Used: /home/slo/arduino-1.8.10/hardware/teensy/avr/libraries/SPI
    Multiple libraries were found for "XPT2046_Touchscreen.h"
    Used: /home/slo/Arduino/libraries/XPT2046_Touchscreen
    Not used: /home/slo/arduino-1.8.10/hardware/teensy/avr/libraries/XPT2046_Touchscreen
    quitexit status 1
  4. #79
    4,197
    Created pull request #394 to move PIT timer code block to after set_arm_clock
  5. #80
    Oct 2017
    11
    does the Teensy 4.0 not support fast (hardware) CRC calculation like the Teensy 3.x?
    With Teensy 3.x I was using Frank Boesings FastCRC implementation ( https://github.com/FrankBoesing/FastCRC ) which makes use of the FastCRC libraries for AVR.
    When I try to compile my code, it seems to switch to the code for software CRC calculation but this compilation terminates due to a missing file in teensy/avr/libraries/FastCRC. The console output is:
    Arduino: 1.8.9 (Windows 10), TD: 1.48-beta1, Board: "Teensy 4.0, Serial, Faster, US English"
    In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FastCRC\FastCRCsw.cpp:38:0:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FastCRC\FastCRC_tables.h:38:23: fatal error: pgmspace.h: No such file or directory
    compilation terminated.
  6. #81
    2,231
    Quote Originally Posted by Hacky View Post
    Looks like Teensyduino doesn't have the latest FastCRC. Fetch the latest from https://github.com/FrankBoesing/FastCRC
    or change FastCRC_tables.h to read
    #if defined(__AVR__ ) || defined(__IMXRT1052__) || defined(__IMXRT1062__)
    T4 does have hardware CRC, but it is a fixed polynomial, not as fancy as T3*. FastCRC doesn't support the T4 hardware CRC so will use table-driven CRCs. see
    https://forum.pjrc.com/threads/54711...l=1#post197722
  7. #82
    Oct 2017
    11
    Thank you Manitou. After replacing the FastCRC library in Teensyduino with the latest version from FrankBoesing, the code compiles.
    But when the library gets loaded and initialized, it freezes my T4. So even the table driven software CRCs seems not usable at the moment.
  8. #83
    2,231
    Sigh, that must be the 1.48-beta1 PIT initialization problem discussed earlier in this thread. Try commenting out PIT_MCR = 0 in hardware/teensy/avr/cores/teensy4/startup.c
  9. #84
    Oct 2017
    11
    Thanks. After commenting out PIT_MCR = 0 in startup.c it does not freeze anymore.
    Which side effects may it cause, when it is not set to 0?
  10. #85
    2,231
    Another strangeness with 1.48-beta1. Exhibited on 1.8.10 on ubuntu 32-bit and 64-bit running FastCRC benchmark example. Sometimes when running the sketch the last few lines are not printed ?? may happen after a rebuild, or after pushing program button, or after unplug/plug USB ???? Adding while(!Serial) after Serial.begin() seems to cure it.
    can anyone else reproduce the problem??
  11. #86
    Oct 2017
    11
    I also had this effect one time (last three lines missing) - but with Teensy 3.2 connected.
    A FastCRC benchmark comparison between Teensy 3.2 (with hardware CRC) and Teensy 4.0 (table based CRC) is quite interesting:
    Teensy 3.2:
    CRC Benchmark
    F_CPU: 96 MHz, length: 57344 Bytes.
    Maxim (iButton) FastCRC:	Value:0xD2, Time: 1052 us (436.08 mbs)
    Maxim (iButton) builtin:	Value:0xD2, Time: 43718 us (10.49 mbs)
    MODBUS FastCRC:	Value:0x25F1, Time: 1053 us (435.66 mbs)
    MODBUS builtin: 	Value:0x25F1, Time: 47308 us (9.70 mbs)
    XMODEM FastCRC:	Value:0xB217, Time: 1051 us (436.49 mbs)
    XMODEM builtin: 	Value:0xB217, Time: 47311 us (9.70 mbs)
    MCRF4XX FastCRC:	Value:0x4BE4, Time: 1049 us (437.32 mbs)
    MCRF4XX builtin:	Value:0x4BE4, Time: 8392 us (54.67 mbs)
    KERMIT FastCRC:	Value:0x9137, Time: 1050 us (436.91 mbs)
    Ethernet FastCRC:	Value:0x29C6653B, Time: 1052 us (436.08 mbs)
    Teensy 4.0 (with buffersize set to the same size as for T3.2 for better comparison and uncommented PIT_MCR = 0 in the startup.c):
    CRC Benchmark
    F_CPU: 600 MHz, length: 57344 Bytes.
    Maxim (iButton) FastCRC:	Value:0xD2, Time: 674 us (680.64 mbs)
    Maxim (iButton) builtin:	Value:0xD2, Time: 4111 us (111.59 mbs)
    MODBUS FastCRC:	Value:0x25F1, Time: 487 us (942.00 mbs)
    MODBUS builtin: 	Value:0x25F1, Time: 5791 us (79.22 mbs)
    XMODEM FastCRC:	Value:0xB217, Time: 527 us (870.50 mbs)
    XMODEM builtin: 	Value:0xB217, Time: 6507 us (70.50 mbs)
    MCRF4XX FastCRC:	Value:0x4BE4, Time: 463 us (990.83 mbs)
    MCRF4XX builtin:	Value:0x4BE4, Time: 957 us (479.36 mbs)
    KERMIT FastCRC:	Value:0x9137, Time: 300 us (1529.17 mbs)
    Ethernet FastCRC:	Value:0x29C6653B, Time: 727 us (631.02 mbs)
    But I recognized another problem:
    The Teensy 4.0 is getting VERY hot and seems to shutdown after some time (serial monitor switches into "disconnected"). The benchmark only runs once in the setup() - is the empty loop() of the benchmark a problem for T4?
    The Teensy 3.2 stays cool.
  12. #87
    2,231
    That shouldn't happen, can you print out chip temperature float tmpc = tempmonGetTemp() in a loop ...
  13. #88
    9,923
    Have made the PIT change locally ...
    Not sure which example? I pulled the github fastcrc and ran FastCRC_Benchmark and it works. Reduced delay in setup to 50ms
    Then made a function of the benchmark and called from setup and then loop() each 1.5 secs. It runs once and then repeatedly.
  14. #89
    2,231
    I can confirm missing FastCRC lines problem occurred with T3.2 with 1.48-beta1. Also seems to be fixed with while(!Serial). I turned on LED at end of benchmark tests to confirm sketch wasn't hanging, and LED is on at end, even though last few lines may not be printed.
  15. #90
    2,231
    you need to read the earlier posts in this thread to learn more about PIT initialization.
  16. #91
    9,923
    I do see something of this - it is buffering of some initial USB print before Serial is online - and the test is complete before Serial is online and the last print doesn't get buffered.
    IIRC some beta testing - doing that early print without Serial online delays the arrival of Serial - and buffereing is selective and limited.
    Did a quick mod and it indeed gets to loop() before Serial prints at the end - the @437ms was called last as setup() ended and the test was complete.
    This is typical behavior when doing .print before Serial is online. Test here is on T4
    CRC Benchmark
    F_CPU: 600 MHz, length: 1024 Bytes.
    Maxim (iButton) FastCRC:	Value:0x78, Time: 17 us (481.88 mbs)
    Maxim (iButton) builtin:	Value:0x78, Time: 74 us (110.70 mbs)
    MODBUS FastCRC:	Value:0x2487, Time: 160 us (51.20 mbs)
    MODBUS builtin: 	Value:0x2487, Time: 105 us (78.02 mbs)
    XMODEM FastCRC:	Value:0x190E, Time: 192 us (42.67 mbs)
    XMODEM builtin: 	Value:0x190E, Time: 121 us (67.70 mbs)
    MCRF4XX FastCRC:	Value:0xF5F5, Time: 191 us (42.89 mbs)
    MCRF4XX builtin:	Value:0xF5F5, Time: 17 us (481.88 mbs)
    KERMIT FastCRC:	Value:0x318, Time: 5 us (1638.40 mbs)
    IN LOOP() Serial online @741
    prior Serial NOT online @437
  17. #92
    2,231
    Ah, a feature. I'm familiar with losing the first few lines when not using while(!Serial), but i don't think i've seen it print the first few lines and then lose later ones. whatever.
    thanks
  18. #93
    4,197
    Teensy 3.2:
    CRC Benchmark
    CRC Benchmark
    Just ran the benchmark on my T4 and its actually cooler to the touch than most of the sketches I test. The only way you are going to temperature shutdown is if the internal temperature of the T4 goes over 90degC. As @manitou said can you print out the temperatures during the test.
  19. #94
    Oct 2017
    11
    I replaced the empty loop() of the benchmark with the following code to get the temperature printed once a second:
    long nextTime = millis() + 1000;
      if (millis() > nextTime) {
         float tmpc = tempmonGetTemp();
         Serial.println("Temp.: " + String(tmpc));
    It goes up to about 53C (about 127F).
    EDIT: Same with "Blink.ino", when I just add printing the temperature in the loop. Room temperature is about 23C (about 73F).
    Is there something wrong with my T4 or do you get the same temperatures?
  20. #95
    9,923
    My room temp is about 70F. Using a call to p#94 loop() code::
    >> One T4 on a breakout is now hitting 50.45C and 51.09C seems near the peak.
    >>Another bare board started at 38.7C - and now is into 53.79C
    With your ambient 3F warmer it seems that seems consistent/normal.
    The external won't measure that hot - that is internal where the localized sensor is placed.
    Thermal shutdown PANIC is at 90C.
  21. #96
    2,231
    i get about the same temperatures. all is well.
  22. #97
    Sep 2019
    14
    Strange behaviour with Teensy 4.0 1.48-beta1 on 1.8.10 MacOS 10.13. I can't get the Adafruit SSD1306 (1.3.0) library to work unless I set optimise to 'Debug' or 'Smallest Code'. This is using the included demo program ssd1306_128x64_i2c.
    Any other setting hangs the usb serial console during initialisation of the Adafruit_SSD1306 class, and no display output occurs.
    Any ideas? Thought originally it was Wire/i2c related, but the same noname i2c oled display works just fine with u8g2.
    Any suggestions on how to debug this?
  23. #98
    4,197
    Yeah. this is probably related to an issued discussed here: https://forum.pjrc.com/threads/57609...l=1#post216441. A PR has been issued but you can fix it yourself by moving this block of code:
    	PIT_MCR = 0;
    	PIT_TCTRL0 = 0;
    	PIT_TCTRL1 = 0;
    	PIT_TCTRL2 = 0;
    	PIT_TCTRL3 = 0;
    to after this
    in startup.c in the teensy4 core files.
  24. #99
    Same machine as prior post, Jetson Nano, reveals java exceptions when run from terminal.
    Its long, hope it helps.
    First compile failed because default arduino board was selected.
    Not shown: at second slo@sloNano:~$ arduino I opened gui and selected Teensy 4
    Command 'arduino' not found, but can be installed with:
    sudo apt install arduino
    slo@sloNano:~$ export PATH="$PATH:/home/slo/bin/arduino-1.8.10"
    slo@sloNano:~$ source ~/.profile
    Picked up JAVA_TOOL_OPTIONS:
    Set log4j store directory /home/slo/.arduino15
    [JmDNS(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).Timer] WARN javax.jmdns.impl.tasks.resolver.DNSResolverTask - ServiceResolver(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).run() exception
    java.io.IOException: Cannot assign requested address (sendto failed)
    	at java.net.PlainDatagramSocketImpl.send(Native Method)
    	at java.net.DatagramSocket.send(DatagramSocket.java:693)
    	at javax.jmdns.impl.JmDNSImpl.send(JmDNSImpl.java:1618)
    	at javax.jmdns.impl.tasks.resolver.DNSResolverTask.run(DNSResolverTask.java:73)
    	at java.util.TimerThread.mainLoop(Timer.java:555)
    	at java.util.TimerThread.run(Timer.java:505)
    [fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover()] WARN javax.jmdns.impl.JmDNSImpl - RECOVERING
    [JmDNS(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).State.Timer] WARN javax.jmdns.impl.tasks.state.DNSStateTask - Canceler(fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local.).run() exception
    	at javax.jmdns.impl.tasks.state.DNSStateTask.run(DNSStateTask.java:131)
    [fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover()] WARN javax.jmdns.impl.DNSStatefulObject$DefaultImplementation - Wait for canceled timed out: DNS: fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local. [fe80:0:0:0:5de6:8665:7fcd:96fe%wlan0/fe80:0:0:0:5de6:8665:7fcd:96fe%wlan0] state: canceling 1 task: null
    [fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover()] WARN javax.jmdns.impl.JmDNSImpl - fe80-0-0-0-5de6-8665-7fcd-96fe-wlan0.local..recover() Could not recover we are Down!
    2019-09-29T07:53:42.383Z INFO c.a.c.p.ContributionInstaller:305 [Timer-0] Start download and signature check of=[https://downloads.arduino.cc/packages/package_index.json]
    2019-09-29T07:53:42.444Z INFO c.a.u.n.FileDownloaderCache:92 [Timer-0] Cache folder /home/slo/.arduino15/cache
    2019-09-29T07:53:42.609Z INFO c.a.u.n.FileDownloaderCache:112 [Timer-0] Number of file already in the cache 4
    2019-09-29T07:53:42.708Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='e5333ff208bec8f067589a99b43a1285', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json', md5='MD5:e5333ff208bec8f067589a99b43a1285', createdAt='2019-09-29T02:40:21.973', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
    2019-09-29T07:53:42.734Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='e5333ff208bec8f067589a99b43a1285', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json', md5='MD5:e5333ff208bec8f067589a99b43a1285', createdAt='2019-09-29T02:40:21.973', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
    2019-09-29T07:53:42.737Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json]
    2019-09-29T07:53:42.742Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='330f326540998b47fa4d733ed5f6eef9', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json.sig', md5='MD5:330f326540998b47fa4d733ed5f6eef9', createdAt='2019-09-29T02:40:22.49', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
    2019-09-29T07:53:42.748Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='330f326540998b47fa4d733ed5f6eef9', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json.sig', md5='MD5:330f326540998b47fa4d733ed5f6eef9', createdAt='2019-09-29T02:40:22.49', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
    2019-09-29T07:53:42.750Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/packages/package_index.json.sig]
    2019-09-29T07:53:42.774Z INFO c.a.c.DownloadableContributionsDownloader:222 [Timer-0] Signature verified. url=https://downloads.arduino.cc/packages/package_index.json.sig, signature url=https://downloads.arduino.cc/packages/package_index.json.sig, file to verify=/tmp/package_index.json8311399446740338176.tmp, signature file=/tmp/package_index.json.sig4580471798081923638.tmp
    2019-09-29T07:53:42.779Z INFO c.a.c.p.ContributionInstaller:314 [Timer-0] Downloaded package index URL=[https://downloads.arduino.cc/packages/package_index.json]
    2019-09-29T07:53:42.787Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='6cbd521329168ca1a68348286a8c1bb5', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz', md5='MD5:6cbd521329168ca1a68348286a8c1bb5', createdAt='2019-09-29T02:40:24.296', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
    2019-09-29T07:53:42.809Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='6cbd521329168ca1a68348286a8c1bb5', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz', md5='MD5:6cbd521329168ca1a68348286a8c1bb5', createdAt='2019-09-29T02:40:24.296', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
    2019-09-29T07:53:42.811Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz]
    2019-09-29T07:53:42.932Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire false, exist true, info FileCached{eTag='3e68f102a17273a8c3bab174740c9d9d', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.sig', md5='MD5:3e68f102a17273a8c3bab174740c9d9d', createdAt='2019-09-29T02:40:25.449', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
    2019-09-29T07:53:42.944Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='3e68f102a17273a8c3bab174740c9d9d', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.sig', localPath='/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.sig', md5='MD5:3e68f102a17273a8c3bab174740c9d9d', createdAt='2019-09-29T02:40:25.449', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
    2019-09-29T07:53:42.947Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[/home/slo/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.sig]
    2019-09-29T07:53:43.155Z INFO c.a.c.DownloadableContributionsDownloader:222 [Timer-0] Signature verified. url=https://downloads.arduino.cc/libraries/library_index.json.sig, signature url=https://downloads.arduino.cc/libraries/library_index.json.sig, file to verify=/tmp/library_index.json6198172837891228961.tmp, signature file=/tmp/library_index.json.sig7258483909988041405.tmp
    slo@sloNano:~$ arduino --verify '/home/slo/Arduino/touchscreemTest/touchscreemTest.ino'
    Loading configuration...
    Initializing packages...
    Preparing boards...
    Verifying...
    touchscreemTest:1:10: error: ILI9341_t3.h: No such file or directory
     #include <ILI9341_t3.h>
    exit status 1
    java.io.IOException: Stream closed
    	at java.io.BufferedInputStream.getBufIfOpen(BufferedInputStream.java:170)
    	at java.io.BufferedInputStream.read(BufferedInputStream.java:336)
    	at com.fasterxml.jackson.core.json.ByteSourceJsonBootstrapper.ensureLoaded(ByteSourceJsonBootstrapper.java:522)
    	at com.fasterxml.jackson.core.json.ByteSourceJsonBootstrapper.detectEncoding(ByteSourceJsonBootstrapper.java:150)
    	at com.fasterxml.jackson.core.json.ByteSourceJsonBootstrapper.constructParser(ByteSourceJsonBootstrapper.java:246)
    	at com.fasterxml.jackson.core.JsonFactory._createParser(JsonFactory.java:1315)
    	at com.fasterxml.jackson.core.JsonFactory.createParser(JsonFactory.java:820)
    	at cc.arduino.packages.discoverers.PluggableDiscovery.run(PluggableDiscovery.java:80)
    	at java.lang.Thread.run(Thread.java:748)
    slo@sloNano:~$ arduino --verify touchscreemTest.ino
    Preparing boards...
    Verifying...
    java.io.IOException: No valid code files found
    	at processing.app.Sketch.listSketchFiles(Sketch.java:117)
    	at processing.app.Sketch.<init>(Sketch.java:54)
    	at processing.app.Base.<init>(Base.java:415)
    	at processing.app.Base.main(Base.java:150)
    Preparing boards...
    Verifying...
    Preparing boards...
    Verifying...
    Sketch uses 59488 bytes (2%) of program storage space. Maximum is 2031616 bytes.
    Global variables use 66096 bytes (6%) of dynamic memory, leaving 982480 bytes for local variables. Maximum is 1048576 bytes.
    slo@sloNano:~$ arduino --get-pref
    Preparing boards...
    #PREFDUMP#
    last.sketch.count=0
    update.check=true
    platform.auto_file_type_associations=true
    gui.scale=auto
    editor.window.width.default=500
    editor.window.height.default=600
    editor.window.width.min=400
    editor.window.height.min=290
    editor.code_folding=true
    editor.font=Monospaced,plain,12
    editor.antialias=true
    editor.external=false
    editor.caret.blink=true
    editor.invalid=false
    editor.linenumbers=true
    editor.keys.alternative_cut_copy_paste=true
    editor.keys.shift_backspace_is_delete=true
    editor.keys.home_and_end_beginning_end_of_doc=false
    console=true
    console.output.file=stdout.txt
    console.error.file=stderr.txt
    console.lines=4
    console.auto_clear=true
    console.length=500
    editor.tabs.expand=true
    editor.tabs.size=2
    editor.indent=true
    editor.auto_close_braces=true
    editor.divider.size=0
    editor.save_on_verify=true
    run.options=
    run.options.memory=false
    run.options.memory.initial=64
    run.options.memory.maximum=256
    run.display=1
    export.application.platform=true
    export.application.fullscreen=false
    export.application.stop=true
    export.applet.separate_jar_files=false
    export.delete_target_folder=true
    preproc.save_build_files=false
    preproc.color_datatype=true
    preproc.web_colors=true
    preproc.enhanced_casting=true
    preproc.substitute_floats=true
    preproc.substitute_unicode=true
    preproc.output_parse_tree=false
    preproc.imports.list=java.applet.*,java.awt.Dimension,java.awt.Frame,java.awt.event.MouseEvent,java.awt.event.KeyEvent,java.awt.event.FocusEvent,java.awt.Image,java.io.*,java.net.*,java.text.*,java.util.*,java.util.zip.*,java.util.regex.*
    browser=mozilla
    run.present.bgcolor=#666666
    run.present.stop.color=#cccccc
    run.present.exclusive=false
    target_package=teensy
    target_platform=avr
    board=teensy40
    software=ARDUINO
    build.warn_data_percentage=75
    programmer=arduino:avrispmkii
    upload.using=bootloader
    upload.verify=true
    serial.databits=8
    serial.stopbits=1
    serial.parity=N
    serial.debug_rate=9600
    serial.line_ending=1
    editor.languages.current=
    preferences.readonly=false
    runtime.ide.path=/home/slo/bin/arduino-1.8.10
    runtime.ide.version=10810
    boardsmanager.additional.urls=
    build.verbose=true
    cache.enable=true
    compiler.cache_core=true
    compiler.warning_level=none
    custom_keys=teensy40_en-us
    custom_opt=teensy40_o2std
    custom_usb=teensy40_serial
    editor.update_extension=true
    ide.accessible=false
    last.ide.1.8.10.daterun=1569744468
    last.ide.1.8.10.hardwarepath=/home/slo/bin/arduino-1.8.10/hardware
    last.screen.height=768
    last.screen.width=1366
    last.sketch.default.location=433,84,500,600,404,0
    last.sketch.default.path=/tmp/untitled183572571.tmp/sketch_sep29a/sketch_sep29a.ino
    launcher=xdg-open
    proxy.manual.hostname=
    proxy.manual.password=
    proxy.manual.port=
    proxy.manual.type=HTTP
    proxy.manual.username=
    proxy.pac.url=
    proxy.type=auto
    sketchbook.path=/home/slo/Arduino
    theme.file=
    update.id=7771706390682478081
    update.last=1569742762268
    upload.verbose=true
    runtime.os=linux
    runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
    runtime.tools.arduino-avr-gcc-7.3.0-atmel3.6.1-arduino5.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
    runtime.tools.avr-gcc.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
    runtime.tools.avrdude-6.3.0-arduino17.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
    runtime.tools.arduino-avrdude-6.3.0-arduino17.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
    runtime.tools.avrdude.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
    runtime.tools.arduinoOTA-1.3.0.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
    runtime.tools.arduino-arduinoOTA-1.3.0.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
    runtime.tools.arduinoOTA.path=/home/slo/bin/arduino-1.8.10/hardware/tools/avr
    runtime.platform.path=/home/slo/bin/arduino-1.8.10/hardware/teensy/avr
    runtime.hardware.path=/home/slo/bin/arduino-1.8.10/hardware/teensy
    teensy: Invalid json message
    slo@sloNano:~$
  25. #100
    9,923
    @Paul - others? Re message posted here : pjrc.com/threads/57701-USB-Host-Ethernet-Driver
    Anyone seeing extra stuff rebuilding on Rebuild with IDE 1.8.10 and TD 1.48.b1?
    Or added new messages or library during build::
    Alternatives for USBHost_t36.h: [USBHost_t36@0.1]
    ResolveLibrary(USBHost_t36.h)
      -> candidates: [USBHost_t36@0.1]
    Or indications of "Multiple libraries" where there is only a single present and no 2nd indicated::
    Multiple libraries were found for "ASIXEthernet.h"
     Used: T:\tCode\libraries\TeensyASIXEthernet
