Results 1 to 4 of 4
Thread: Teensysuino examples won't compile
    I'm having trouble compiling examples for the Teensy 4 using Arduino 1.8.10/Teensyduino 1.48.beta 1.
    None of the sketches in the Entropy folder compile. The error print for Generate_Random_Bytes is listed below. Could someone provide some guidance on what to do next?
    Thanks,
    Michael
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Entrop y\Entropy.cpp: In member function 'void EntropyClass::Initialize()':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Entrop y\Entropy.cpp:67:3: error: 'SIM_SCGC5' was not declared in this scope
    SIM_SCGC5 |= SIM_SCGC5_LPTIMER;
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Entrop y\Entropy.cpp:67:16: error: 'SIM_SCGC5_LPTIMER' was not declared in this scope
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Entrop y\Entropy.cpp:68:3: error: 'LPTMR0_CSR' was not declared in this scope
    LPTMR0_CSR = 0b10000100;
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Entrop y\Entropy.cpp:69:3: error: 'LPTMR0_PSR' was not declared in this scope
    LPTMR0_PSR = 0b00000101; // PCS=01 : 1 kHz clock
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Entrop y\Entropy.cpp:70:3: error: 'LPTMR0_CMR' was not declared in this scope
    LPTMR0_CMR = 0x0006; // smaller number = faster random numbers...
    In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/core_pins.h:32:0,
    from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:38,
    from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/WProgram.h:45,
    from C:\Users\mob\AppData\Local\Temp\arduino_build_4423 85\pch\Arduino.h:6:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Entrop y\Entropy.cpp:72:19: error: 'IRQ_LPTMR' was not declared in this scope
    NVIC_ENABLE_IRQ(IRQ_LPTMR);
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/imxrt.h:8296:52: note: in definition of macro 'NVIC_ENABLE_IRQ'
    #define NVIC_ENABLE_IRQ(n) (*(&NVIC_ISER0 + ((n) >> 5)) = (1 << ((n) & 31)))
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Entrop y\Entropy.cpp: In function 'void lptmr_isr()':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Entrop y\Entropy.cpp:326:3: error: 'LPTMR0_CSR' was not declared in this scope
    Multiple libraries were found for "Entropy.h"
    Used: C:\Program
    Error compiling for board Teensy 4.0.
    9,770
    Those sketches have likely not been updated for Teensy 4 hardware registers. Have to check the Beta Teensy 4 thread to see if there is a note
    Thanks. I wasn't sure whether it was a problem on my end on with the Example sketches.
    There's a note from Paul in the Teensy 4 First Beta Test thread at 12-29-2018, 10:26 AM, #83. I don't know how to link to a message properly here.
    Best regards,
    Michael
    9,770
    Quote Originally Posted by aaaxon View Post
    Best regards,
    Michael
    Yes, there it is - it has a link to TRNG :: https://forum.pjrc.com/threads/54711...l=1#post195000
    To link to a specific post - right click on the post # - in this case post #4 - then 'Copy Link' or whatever your browser calls it to get :: https://forum.pjrc.com/threads/54711...l=1#post193717
    Then paste a link with Ctrl+L :: forum.pjrc.com/threads/54711-Teensy-4-0-First-Beta-Test?p=193717
