Results 1 to 5 of 5
Thread: fast delay question 3.6
    Sep 2019
    11
    dear reader,
    Using a Teensy 3.6.
    For a a project I need to have a very short delay shorter then 1Ás should be near 0.05ÁS (followed by a interrupt).
    Is it possible?
    I checked out :
    https://github.com/PaulStoffregen/FreqCount
    But this is driven by an external clock( the freq to measure) Can I some how set the LPTMR_CSR, PSR, CMR, CNR and / or the MCG_IRCLK to use an internal clock to make a fast delay?
    Thanks hanz
    from the headerfile:
    static inline void counter_init(void)
    SIM_SCGC5 |= SIM_SCGC5_LPTIMER;
    LPTMR0_CSR = 0;
    LPTMR0_PSR = 0b00000100; // bypass prescaler/filter
    LPTMR0_CMR = 0xFFFF;
    LPTMR0_CSR = 0b00100110; // counter, input=alt2, free running mode
    CORE_PIN13_CONFIG = PORT_PCR_MUX(3);
    Feb 2014
    Colmar, France
    2,530
    Perhaps use a PIT timer in one-shot mode? If F_BUS is 60MHz on a Teensy 3.6 @180MHz, letting it count to 3 would give 0.05uS before launching an interrupt.
    Sep 2019
    11
    Thank you vy much, i'm going to deep in right a way.
    hanz
    2,189
    Beware. If you are trying to continuously interrupt at a 20mhz rate, you won't succeed. Depending on what you are doing in your ISR, you typically can't expect more than a 1 to 3 mhz interrupt rate.
    also consider https://forum.pjrc.com/threads/29105...-Second-Pulses
    here is a sketch toggling pin 12 in the isr
    // PIT timer ISR toggle pin 12, use scope or analyzer
    //https://forum.pjrc.com/threads/42643-Timer-1-cycle-problems?p=136712&viewfull=1#post136712
    const uint8_t out_pin = 12;
    #define OUT_PIN_PTOR GPIOC_PTOR
    #define OUT_PIN_BMASK CORE_PIN12_BITMASK
      pinMode(out_pin, OUTPUT);
      SIM_SCGC6 |= SIM_SCGC6_PIT;
      __asm__ volatile("nop");   //timing problem on T3.5
      PIT_MCR = 0x00;
      NVIC_ENABLE_IRQ(IRQ_PIT_CH1);
      PIT_LDVAL1 = 1; // count to 1
      PIT_TCTRL1 |= 0x00000003; // enable Timer 1 interrupts (TIE = 1) & start Timer 1 (TEN = 0)
    void pit1_isr(void) {
      PIT_TFLG1 = 1;  // clear interrupt  first
      OUT_PIN_PTOR = OUT_PIN_BMASK;
    void loop() {}
    On T3.6, scope shows pin changing every 200 ns, with LDVAL of 1
    Reference: https://forum.pjrc.com/threads/42643...cycle-problems
    Sep 2019
    11
    Thank you very much Manitou, and tahnk you for the code.
    regards hanz
