Page 2 of 2 FirstFirst 1 2
Results 26 to 29 of 29
Thread: What applications truly need both Teensy 3.5 / 3.6 built in DACs?
  1. #26
    For controlling analogue B4 lense 3 DAC's would be great (focus, zoom, aperture) , but filtered PWM works too. Additional electronics is needed anyway as the control voltage is up to 7.5V
  2. #27
    Apr 2019
    152
    I use them to read the output of weight scales
  3. #28
    Oct 2014
    8
    One for audio (osc) out, the other for multiplexed CV control of external analog components. I didn't want to multiplex the osc out as I wanted to keep that at a high samplerate and free of potential noise.
  4. #29
    Aug 2019
    southwest USA
    50
    Mostly thinking about a future Teensy.
    The main question here is whether one 12 bit DAC is sufficient? If not, what compelling applications truly require more than one built in DAC?
    one or more dac rather than none comes in handy for creating pseudo sin waves for modulating a radio. will work over a wide frequency range and
    compared to square waves requires far less external filtering to keep modulated bandwidth under control. it is nice if it is internal or on the board
    for those applications where small and less expensive win. have not needed two yet.
