Results 1 to 4 of 4
Thread: Frequency count Teensy 4
    May 2017
    Netherlands
    92
    I did some tests with my Teensy 4 to count the frequency of my transceiver this work till 21MHz, above I get no readings. (0.0)
    I use input 9 as input and use a small interface.
    The count looks like this count= 7001.00 but my transceiver is set on 7001.350 so I miss some digits.
    What can I do ? a bit weird that I must divide by 2 to get the right value too.
    Who can help me with this ....
    if (FreqCount.available()) {
    unsigned long count = FreqCount.read();
    Serial.print("count= ");
    Serial.println(count /2);
    2,193
    can you try the FreqCount example Serial_Output_T4 with pin 9 jumpered to pin 8. maybe change the pin 8 write frequency to 25mhz and see what it reports. if you have a T3*, can you try FreqCount on your T3*. high frequency signals need short jumpers ... (what version of Arduino IDE and Teensyduino are you using?)
    the example schematic you attached (from FreqCount web page) uses 5V -- hopefully, you are using 3.3v. Teensy 4 is NOT 5v tolerant.
    May 2017
    Netherlands
    92
    Used Arduino IDE 1.89 and Teensyduino 1.47
    I connected in the test sketch 8 and 9 together, I adjusted the analogWriteFrequency(8, 30000000); //
    The serial monitor report exactly 30000000 I think for my application ok (> 30000000 give rubbish) so I need a decent interface between Teeny input 9 is that correct ?
    I used code below...
    #include <FreqCount.h>
    Serial.begin(57600);
    delay(2000);
    analogWriteFrequency(8, 30000000); // test jumper 11 to 25
    analogWrite(8, 128);
    FreqCount.begin(1000000); //Time in microseconds
    Serial.println(count);
    May 2017
    Netherlands
    92
    @manitou
    Transceiver on 14000005 gives now with a correction factor 14000006 that's very very good.
    I build a correction factor for 1900= 1916, 3500 = 3530, 7000 = 7060, 14000 = 14120.
    The only thing is that I can go for this moment to 18MHz but that has to do I think with the 74HC14 and the input circuit....
    Thanks for helping.
    Best,
    Johan
