Results 1 to 2 of 2
Thread: USB Audio Input Not Working
    Hi all, I started messing around with the Audio library again, I'm messing around with USB Audio, basically i just want to check if my T3.6 is reading audio from the USB port, however it doesn't seem to be so im sure i'm missing something.
    It's a Teensy 3.6 with USB Type set to Audio, i took the mono peak meter example sketch and changed the adc1 to be AudioInputUSB (based on the GUI designer), i also added some a few Serial lines to see if it's reading anything, So far i "Launched" printed on the monitor but nothing else. Am I missing something here?? My Mac recognizes the Teensy and shows up as and output, i'm playing music from iTunes.
    If i uncomment the "tick" line it will show up on the monitor as expected, however if i only uncomment the "tock" line it will not print it even with audio playing from my computer
    Here's my sketch
    /* Mono Peak Meter
       Scrolling peak audio level meter in the Arduino Serial Monitor
       Audio input needs to connect to pin 16 (A2).  The signal range is 0 to 1.2V.
       See the documentation in the Audio System Design Tool for the recommended
       circuit to connect an analog signal.
       This example code is in the public domain
    AudioInputUSB            input;           //xy=164,95
    AudioAnalyzePeak         peak1;          //xy=317,123
    AudioConnection          patchCord1(input, peak1);
      Serial.println("Launched");
      AudioMemory(4);
    // for best effect make your terminal/monitor a minimum of 31 chars wide and as high as you can.
    elapsedMillis fps;
      if(fps > 24){
        //Serial.println("tick");
        if(peak1.available()){
          //Serial.println("tock");
          fps = 0;
          int monoPeak = peak1.read() * 30.0;
          Serial.print("|");
          for(int cnt = 0; cnt < monoPeak; cnt++){
            Serial.print(">");
          Serial.println("");
    Last edited by neroroxxx; 09-18-2019 at 06:43 PM. Reason: more specific title for the post
    Feb 2014
    Colmar, France
    2,535
    Apparently, you didn’t read the full documentation of the AudioInputUSB object in the right sidebar of the audio design tool:
    USB input & output does not cause the Teensy Audio Library to update. At least one non-USB input or output object must be present for the entire library to update properly.
