Hello.
I've searched high and low for an answer - please let me know if I've overlooked something.
I'm using a Wiznet820io on a Teensy 3.2 with a PJRC adaptor shield to connect the two.
When I interrogate the network using Wireshark, Fing etc. the adaptor name shows up as PjrcCom. Where is this set and is it possible to change it?
I've looked through the Ethernet libraries but can't find anything. This seems to be listed as a to-do item during the release of v.2 (https://www.pjrc.com/arduino-ethernet-library-2-0-0/). I imagine that it must be set as hard coded into a library somewhere - perhaps as a buffer rather than a string - but searching hasn't turned anything up. I'm wondering whether this is read from EEPROM somewhere in the same was as the MAC is.
I'm happy editing a library directly if I could be pointed in the right direction.
Very many thanks in advance of any help.
David
David
