Page 5 of 5 FirstFirst ... 3 4 5
Results 101 to 121 of 121
Thread: Another Teensy 4.0 Breakout Board
  1. #101
    Mar 2015
    5
    I received my boards yesterday, in 1.6mm. No apparent issue.
    I began soldering one today. I had to clean some copper burr, but it went smoothly after that. No trouble with the smallest castellations, a bit of flux paste made quick & easy work of them.
    I'm now stuck for the day as I can't build the USB Host board ; Farnell split my components order in two without me noticing, one of the package is still at the post office...
  2. #102
    May 2015
    San Francisco
    213
    I've updated the design a bit to improve the silkscreen and tweaked the edge cuts to not cut through two pins that didn't need cutting (teensy pins 12 & 13). Updated here:
    https://github.com/blackketter/teensy4_header_breakout
    and here:
    https://oshpark.com/shared_projects/9TplvPXu
  3. #103
    May 2015
    San Francisco
    213
    And some more updates this morning to add additional ground connections and a ground plane, as well as some more silkscreen improvements:
    and here:
    https://oshpark.com/shared_projects/JoIFFIWW
  4. #104
    3,456
    Quote Originally Posted by blackketter View Post
    and here:
    Would it be possible to have pin #'s on the bottom silk screen? At least for the pins > 23? I really don't want to have to refer to an online site when I'm bringing out pins.
  5. #105
    May 2015
    San Francisco
    213
    Good suggestion. I'll see what I can fit in there! How's this?
Name:	Screen Shot 2019-10-21 at 11.40.41 AM.png
  6. #106
    10,407
    That looks very good! So much better to see silk screen refs to prevent confusion in flipping the board.
    Question why are pin #34 and On/Off a square pad?
  7. #107
    May 2015
    San Francisco
    213
    No good reason, they were like that in the original default footprint for the header that I used. Rounded them out:
Name:	Screen Shot 2019-10-21 at 1.21.37 PM.png
  8. #108
    10,407
    Okay - Wasn't sure if GND was normally square so it caught my eye.
  9. #109
    Nov 2017
    Belgium
    188
    I would suggest to also put the pin numbers on the top silk layer for those who want to use a double row header as seen on the first picture you posted.
    Attachment 17638
  10. #110
    They were pretty clear with me that the castellated designs were not guaranteed. Their tips are here: https://docs.oshpark.com/tips+tricks/castellation/
    My guess is that the thinness of the board and the thickness of the traces (2oz vs 1oz) conspire together to make this a little tricky to get right reliably.
    While I'm disappointed that the 0.8mm design didn't work first time, I suspect that it could work reliably with a few iterations.
    For production volumes it would make more sense to work with a board house to dial in the design, production and inspection process to get it right reliably.
    i'm not sure how much control over the content of the shared board page on OSH you have but i noticed you have a note about the .8mm on your github and something similar on the OSH board page would be a plus.
  11. #111
    May 2015
    San Francisco
    213
    Quote Originally Posted by dkryder View Post
    Good point, I've added it to the OSHPark project page for the latest design.
  12. #112
    May 2015
    San Francisco
    213
    Quote Originally Posted by neurofun View Post
    Attachment 17638
    Another good suggestion. I'll add that to my next version!
  13. #113
    May 2015
    USA
    329
    Sounds great - for only $6.30 (shipped in US).
    https://oshpark.com/shared_projects/tZbsjC0v
    Thanks blackketter, for this and the ESP32 and SD cards you made available on oshpark.
  14. #114
    May 2015
    San Francisco
    213
    I've put together a design for a combination USB Host and SD breakout board. The idea is that it straddles atop the teensy and connects via a tall-ish header to the original Teensy 4 breakout board below. It has the SD slot on one side and the USB A connector on the top side. This way you can use the Teensy 4 on a traditional perfboard and still have the SD and USB connectors, which are all at one end.
    Details here: https://github.com/blackketter/teensy4_combo_breakout
    Would love feedback on this approach from anybody who can take a look. Thanks!
  15. #115
    Dec 2019
    USA
    2
    Digi-Key HR1941CT-ND (DM3D-SF) SD Card socket is out of stock.
    But they do have H126097CT-ND (DM3D-SF(41), which appears to be identical.
    Will that one work on the blackketter/teensy4_sd_breakout ?
    Thanks,
    Bill
  16. #116
    May 2015
    San Francisco
    213
    Quote Originally Posted by wrljet View Post
    Thanks,
    Bill
    They do appear to be identical, same datasheet, etc. I can't think of a reason why the new part number wouldn't work exactly the same.
  17. #117
    Dec 2019
    USA
    2
    Thanks,
    Bill
  18. #118
    Nov 2019
    3
    My (1.6mm) boards arrived earlier this week. I live in Europe, and I had my order in hand a scant 6 calendar days after placement! In my experience, OSH Park has always under-promised and over-delivered.
    I ordered every board in the suite. I doubt I'll ever use a couple of them, but since fast international shipping was already half the total cost, an extra few $$ made sense just in case. My only thoughts are:
    a-1) I doubt I'll ever use the SMD Breakout Boards. Don't want to create the required additional PCB, but also nearly every one of the small castellations require de-burring - a ton of work under a magnifier with all those very small holes.
    a-2) The board router (not trace router) had to leave the mouse-bites intact to keep the boards attached to the large panel, so those holes will require manual-castellation (OUCH! Who knew castellation was even a verb?).
    b) The BOMs with Digikey part numbers... Are they on GitHub somewhere that I just didn't see? I believe I found all the correct parts for my Digikey order. But the inductor and SD connector were a bit confusing, and just finding everything took quite a bit of searching.
    Regarding the thru-hole Breakout Board: Other than the burrs that needed to be cleared in a few of the castellations, it looks perfect! The plating of every castellation is complete top-to-bottom (that is also true for the SMD Breakout). The silkscreen additions are helpful, and I like that there's a date on the board since there've been a few revs so far. I'm looking forward to soldering one up later today after my solder paste arrives.
    Finally, most of my Teensy 4.0 applications won't actually need a Breakout Board. While I can't use every available I/O pin without one, I rarely require more than the stock board provides. I didn't choose the Teensy 4.0 because of all the I/O, but instead because:
    a) It works virtually seamlessly with the Arduino IDE
    b) Its form-factor/small size
    c) Its speed/power
    d) Its cost/value
    It's becoming my go-to embed for those reasons. And now, if I need to access the SD pins or more I/O, no problem.
    Thanks for all your work creating these boards, and then making them available to the community!
  19. #119
    does a breakout board already assembled exist ? where can i puchase one ?
    thanks in advance.
  20. #120
    May 2015
    San Francisco
    213
    Quote Originally Posted by andromeda View Post
    thanks in advance.
    I'm not planning on offering these as a product, but I'd be happy to help out anybody interested in making one.
  21. #121
    May 2015
    San Francisco
    213
    Quote Originally Posted by RDDyer View Post
    c) Its speed/power
    d) Its cost/value
    Glad you like them! The BOMs are available as web pages called "ibom.html" in the "bom" directories in GitHub. You'll need to download the HTML file and open it with a browser.
