Senior Member+
Very cool looking! Wasn't sure the SDIO spacing would work that well
OSH doesn't show pin map but github.com/blackketter/teensy4_header_breakout does.
Looking at :
Right Side Pinout:
VUSB
USB Host D-
USB Host D+
NC
NC
If the two NC's were GND - it would fit this connector for USB Host given the other pins in place.
pjrc.com/store/cable_usb_host_t36.html
Originally Posted by
defragster
And that's a brilliant observation on the header connector. I'll make the change to the design now.
Senior Member+
Just ordered. Added 2 purple Teensy4.0 and got free shipping to France
Planning to solder the default T4 pins from the bottom side to keep it breadboard compatible, and the outer pin rows from the top to ease DuPont wire connections.
Senior Member+
@blackketter - hope getting GND over works out - looking forward to order.
Theremingenieur
... perhaps ordered too quickly - new and improved version pending
I was going to do that ordering as well - but not to France.
QUESTION:
On these sandwiched boards what soldering order/process works to assure the pins (with header strip in the way) gets soldered properly to both boards?
Senior Member+
I don’t plan to use the USB host for the moment, thus a non-issue for me...
Senior Member+
blackketter
Yes, I was about to put in an order for a Teensy 4 + boards (I've sort of wrecked some of the pads underneath one Teensy). Let us know when it is uploaded (or, I can just manually connect the pins to ground).
defragster
QUESTION:
The idea is that you solder from the top of the sandwiched boards. The inner pins are soldered directly to the Teensy, the outer row is soldered directly to the breakout board. which connects to the soldered pads on the bottom.
There are two exceptions:
- The VUSB pin needs to be soldered on both sides with a bit of wire in the middle.
- Your suggestion about the ground pins means that soldering from the top will depend on capillary action to move the solder to the bottom board.
Similarly, if you want to solder from the bottom, then you'll need to make sure that you give it plenty of solder, heat and time to make it to the other side. And make sure you test the connection.
Senior Member+
Theremingenieur
Also that direct connect method will be missing some electronic support for proper function - a buffer cap and a power surge protector chip? So for proper safe function would require some added parts somewhere. At least the needed pins will be present in order.
@blackketter - reading the github is says "Don't forget to cut the VIN to VUSB trace before attaching board." - that would assume external power expected - or a jumper on top to get the VUSB back to VIN?
Senior Member+
As mentioned looks interesting. A few days ago I started playing with some ideas for a castellated setup. At the time I was think two different ones. One for front and one for rear.
But did not get around to finishing it.
I was afraid of the SDCard pins area. At the time I was playing with the idea of maybe trying do have two cutouts, one at each end and alternate the logical pin connections, for each end, wondering if that might reduce the chance of solder bridges. But it started to feel like it was more trouble than it was worth.
But may have to try one of yours and see how it feels. Is there any indication of which pins if any of the exterior Teensy IO pins connect up to your board?
As for USB host, I am assuming that you have no place on your board to put the USB Power chip and Caps, So even if you added the GND like connections to match up to an USB Host connector, you might want/need to run them to different board to handle this... Although you can probably get away with having the USB device plugged in when the Teensy boots...
But again will be fun to see how well they work.
defragster
That's right. I'm adding a note to this effect on the Github page.
defragster
Right. Only cut it if you need it cut. And do it before you solder the thing together and can't anymore. Like I did.
KurtE
Just the GND pin with the change suggested by @defragster.
KurtE
That's right. There's no ESD or power protection there. @loglow's board would be better in this situation.
KurtE
Great, please post your experience if you end up giving it a try.
MichaelMeissner
I'm not sure when I'll be uploading another order, but you can grab the latest version here and upload it to OSHPark to order it directly.
Otherwise, hooking up the ground pins should be pretty straightforward.
Senior Member+
blackketter
OSH took 'teensy4_header_breakout.kicad_pcb' from github and it looks right. Looking at the 0.8mm board with 2oz copper - you noted thinner board 'next time' …
defragster
That's what I'd do. Should be easier to solder and standard pin headers should protrude though the Teensy holes a bit more.
Senior Member+
blackketter
Done! 3 boards at $6.30 per batch of three 2 oz copper, 0.8mm thickness
Senior Member+
Done, 2 Teensy 4.0s, plus the 3x breakout pcb's. I wonder how many of today's layout are of this board (and adding on Teensy 4.0's).
that is what I was looking for.
A longer version with the uSD Card would be great.
Senior Member+
WMXZ
I was wondering about another level daughter card. It would be 9 pins wide to pickup both edge signals with open 0.7" inside to place SD socket and USB connect cable pins or female USB, and the needed caps and USB power/esd. It could fit top or bottom and need to be 8 pins long to get the SDIO pins, USB only uses 4 or 5 on the other side. Could mount above or below depending on layout.
Left Side Pinout:
34/SD DAT1
35/SD DAT0
GND
36/SD CLK
3.3V
37/SD CMD
38/SD DAT3
39/SD DAT2
defragster
another valid option.
Wow, great minds think alike! I started working on just this kind of thing and then read your message, @defragster!
The idea is that it would stack on the existing board with a header connecting. You could even use longer pins and flip it or rotate it to be over or under the Teensy.
Senior Member+
blackketter
Indeed just like that - Nice image, is an onboard cap called for? Now I see how that detect switch works.
My non-image was 3 wider to the second side adding cap/chip pads for USB and 5 holes for that connector - or standard female USB off the end. Ideally WiFi dongle support will work out so that is an option.
defragster
I was thinking about doing another similar board for the other side with a USB A host connector and TPD3S014 current limit switch.
BTW: I've ordered the SD breakout and posted it here.
Senior Member+
blackketter
here.
Good work - fast. So a CAP isn't called for to support the SD power needs? Loglow breakout has 3 caps - one for USB - I assumed one was for SD.
- You may not post replies
- You may not edit your posts
Forum Rules
