Page 5 of 5 FirstFirst ... 3 4 5
Results 101 to 117 of 117
Thread: Another Teensy 4.0 Breakout Board
  1. #101
    Mar 2015
    5
    I received my boards yesterday, in 1.6mm. No apparent issue.
    I began soldering one today. I had to clean some copper burr, but it went smoothly after that. No trouble with the smallest castellations, a bit of flux paste made quick & easy work of them.
    I'm now stuck for the day as I can't build the USB Host board ; Farnell split my components order in two without me noticing, one of the package is still at the post office...
  2. #102
    May 2015
    San Francisco
    196
    I've updated the design a bit to improve the silkscreen and tweaked the edge cuts to not cut through two pins that didn't need cutting (teensy pins 12 & 13). Updated here:
    https://github.com/blackketter/teensy4_header_breakout
    and here:
    https://oshpark.com/shared_projects/9TplvPXu
  3. #103
    May 2015
    San Francisco
    196
    And some more updates this morning to add additional ground connections and a ground plane, as well as some more silkscreen improvements:
    and here:
    https://oshpark.com/shared_projects/JoIFFIWW
  4. #104
    3,367
    Quote Originally Posted by blackketter View Post
    and here:
    Would it be possible to have pin #'s on the bottom silk screen? At least for the pins > 23? I really don't want to have to refer to an online site when I'm bringing out pins.
  5. #105
    May 2015
    San Francisco
    196
    Good suggestion. I'll see what I can fit in there! How's this?
Name:	Screen Shot 2019-10-21 at 11.40.41 AM.png
  6. #106
    10,091
    That looks very good! So much better to see silk screen refs to prevent confusion in flipping the board.
    Question why are pin #34 and On/Off a square pad?
  7. #107
    May 2015
    San Francisco
    196
    No good reason, they were like that in the original default footprint for the header that I used. Rounded them out:
Name:	Screen Shot 2019-10-21 at 1.21.37 PM.png
  8. #108
    10,091
    Okay - Wasn't sure if GND was normally square so it caught my eye.
  9. #109
    Nov 2017
    Belgium
    161
    I would suggest to also put the pin numbers on the top silk layer for those who want to use a double row header as seen on the first picture you posted.
    Attachment 17638
  10. #110
    They were pretty clear with me that the castellated designs were not guaranteed. Their tips are here: https://docs.oshpark.com/tips+tricks/castellation/
    My guess is that the thinness of the board and the thickness of the traces (2oz vs 1oz) conspire together to make this a little tricky to get right reliably.
    While I'm disappointed that the 0.8mm design didn't work first time, I suspect that it could work reliably with a few iterations.
    For production volumes it would make more sense to work with a board house to dial in the design, production and inspection process to get it right reliably.
    i'm not sure how much control over the content of the shared board page on OSH you have but i noticed you have a note about the .8mm on your github and something similar on the OSH board page would be a plus.
  11. #111
    May 2015
    San Francisco
    196
    Quote Originally Posted by dkryder View Post
    Good point, I've added it to the OSHPark project page for the latest design.
  12. #112
    May 2015
    San Francisco
    196
    Quote Originally Posted by neurofun View Post
    Attachment 17638
    Another good suggestion. I'll add that to my next version!
  13. #113
    May 2015
    USA
    303
    Sounds great - for only $6.30 (shipped in US).
    https://oshpark.com/shared_projects/tZbsjC0v
    Thanks blackketter, for this and the ESP32 and SD cards you made available on oshpark.
  14. #114
    May 2015
    San Francisco
    196
    I've put together a design for a combination USB Host and SD breakout board. The idea is that it straddles atop the teensy and connects via a tall-ish header to the original Teensy 4 breakout board below. It has the SD slot on one side and the USB A connector on the top side. This way you can use the Teensy 4 on a traditional perfboard and still have the SD and USB connectors, which are all at one end.
    Details here: https://github.com/blackketter/teensy4_combo_breakout
    Would love feedback on this approach from anybody who can take a look. Thanks!
  15. #115
    Dec 2019
    USA
    2
    Digi-Key HR1941CT-ND (DM3D-SF) SD Card socket is out of stock.
    But they do have H126097CT-ND (DM3D-SF(41), which appears to be identical.
    Will that one work on the blackketter/teensy4_sd_breakout ?
    Thanks,
    Bill
  16. #116
    May 2015
    San Francisco
    196
    Quote Originally Posted by wrljet View Post
    Thanks,
    Bill
    They do appear to be identical, same datasheet, etc. I can't think of a reason why the new part number wouldn't work exactly the same.
  17. #117
    Dec 2019
    USA
    2
    Thanks,
    Bill
