Results 1 to 2 of 2
Thread: Teensy 3.2 + octows2811 + module ethernet w5500 + Jinx + ws2812
    I need help. It does not work! I read too much post but I did not find the solution to this combination of devices.
    9,730
    T_3.2 should probably have posts here about working with all of them individually, but doubtful they have been combined in this fashion.
    Have you tried them each individually to see them work and build them together stepwise?
    More info would be needed to know where the problem develops. What parts worked to what extent and when did it stop.
    Without more information to that effect and what "It does not work!" means any help would require lots of speculation.
