Page 13 of 13 FirstFirst ... 3 11 12 13
Results 301 to 321 of 321
Thread: USB Host Ethernet Driver
  1. #301
    Apr 2017
    Florida
    472
    That’s probably the issue, I only have it setup to work with the AX88772B chipset, likely my driver is trying to claim it since I’m only testing for the manufacturer and not the specific device, but each chipset has to be setup a little bit differently. I would have to look through the Linux driver to get some of the specifics and rearrange some stuff in my driver to better support different chipsets.
  2. #302
    Germany NRW
    6,530
    Ok.. was a bad buy, then.
    I've enabled the USB logging on the t4. It says:
    USB Host InputFunctions example
    USB2 PLL running
     reset waited 6
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 20016000
    periodictable = 20016000
    USB Ready
    port change: 10001803
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 FF FF 00 40 95 0B 20 77 01 00 01 02 03 01
        VendorID = 0B95, ProductID = 7720, Version = 0001
        Class/Subclass/Protocol = 255 / 255 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: ASIX Elec. Corp.
    enumeration:
    Product: AX88772A
    enumeration:
    Serial Number: 000544
    enumeration:
    Config data length = 39
    enumeration:
    Configuration Descriptor:
      09 02 27 00 01 01 04 A0 7D
        NumInterfaces = 1
        ConfigurationValue = 1
      09 04 00 00 03 FF FF 00 07
        Interface = 0
        Number of endpoints = 3
      07 05 81 03 08 00 0B
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 8
        Polling Interval = 11
      07 05 82 02 00 02 00
        Endpoint = 2 IN
        Type = Bulk
        Max Size = 512
        Polling Interval = 0
      07 05 03 02 00 02 00
        Endpoint = 3 OUT
        Type = Bulk
        Max Size = 512
    enumeration:
    Descriptor 4 = INTERFACE
    ASIXEthernet claim this=200025A0
    type=1
    vid=B95, pid=7720, bDeviceClass = 255, bDeviceSubClass = 255, bDeviceProtocol = 0
    numEndpoints=3
          interrupt_size = 8
          interrupt_ep = 129
          interrupt_interval = 11
          rx_size = 512
          rx_ep = 130
          rx_interval = 0
          tx_size = 512
          tx_ep = 3
          tx_interval = 0
    new_Pipe
    new_Pipe
    new_Pipe
    allocate_interrupt_pipe_bandwidth
      ep interval = 11
      interval = 256
     best_bandwidth = 3, at offset = 0
    Control - ASIX...
    Descriptor 5 = ENDPOINT
    control callback (asix) 1
    Done
    control callback (asix) 2
    Done
    control callback (asix) 3
    nodeID: 00 0E C6 59 FB D5
    control callback (asix) 4
    Done
    control callback (asix) 5
    Done
    control callback (asix) 6
    Done
    control callback (asix) 7
    Done
    Product: AX88772A
    so, it is chip revision A
  3. #303
    10,922
    Hopefully there is a simple fix? I got two of the same from Amazon - USBDeview:
    Amazon 'Basics' USB 2.0 version
    And another exe - USBView.exe:
    Device Descriptor:
    bcdUSB:             0x0200
    bDeviceClass:         0xFF
    bDeviceSubClass:      0xFF
    bDeviceProtocol:      0x00
    bMaxPacketSize0:      0x40 (64)
    idVendor:           0x0B95 (ASIX Electronics Corp.)
    idProduct:          0x772B
    bcdDevice:          0x0001
    iManufacturer:        0x01
    0x0409: "ASIX Elec. Corp."
    iProduct:             0x02
    0x0409: "AX88772B"
    iSerialNumber:        0x03
    0x0409: "E225AB"
    bNumConfigurations:   0x01
    ConnectionStatus: DeviceConnected
    Current Config Value: 0x01
    Device Bus Speed:     High
    Device Address:       0x2E
    Open Pipes:              3
    Endpoint Descriptor:
    bEndpointAddress:     0x81  IN
    Transfer Type:   Interrupt
    wMaxPacketSize:     0x0008 (8)
    bInterval:            0x0B
    bEndpointAddress:     0x82  IN
    Transfer Type:        Bulk
    wMaxPacketSize:     0x0200 (512)
    bInterval:            0x00
    bEndpointAddress:     0x03  OUT
    Transfer Type:        Bulk
    bInterval:            0x00
    wTotalLength:       0x0027
    bNumInterfaces:       0x01
    bConfigurationValue:  0x01
    iConfiguration:       0x04
    0x0409: "0"
    bmAttributes:         0xA0 (Bus Powered Remote Wakeup)
    MaxPower:             0x64 (200 Ma)
    Interface Descriptor:
    bInterfaceNumber:     0x00
    bAlternateSetting:    0x00
    bNumEndpoints:        0x03
    bInterfaceClass:      0xFF
    bInterfaceSubClass:   0xFF
    bInterfaceProtocol:   0x00
    iInterface:           0x07
    0x0409: "0"
    bInterval:            0x0B
    Transfer Type:        Bulk
    bInterval:            0x00
    Transfer Type:        Bulk
    bInterval:            0x00
  4. #304
    2,383
    It still works for me. Amazon USB ether dongle hooked to T4B2 USB host port. Ethernet hooked to switch -> router/switch
    dongle's yellow and green LED are ON. Built/ran example ASIXEthernet_Test sketch which says:
    USB Ready
    Mutex initialized: 0
    Mutex initialized: 1
    TCP/IP stack initialization is done.
    SetMACAddress: 0050B6BE8BB4
    MulticastJoin: 333300000001
    MulticastTable:
    0
    0
    10000000
    0
    0
    0
    0
    0
    MulticastJoin: 3333FFBEAAE2
    MulticastTable:
    0
    1
    10000000
    0
    0
    0
    0
    0
    netif Initialized
    Initializing DHCP
    DHCP initialization done!
    IPAddress: 0.0.0.0
    SubnetMask: 0.0.0.0
    Gateway: 0.0.0.0
    DHCPServer: 0.0.0.0
    State: 2
    IPAddress: 192.168.1.132
    SubnetMask: 255.255.255.0
    Gateway: 192.168.1.1
    DHCPServer: 192.168.1.1
    State: 5
    MAC address matches sticker on dongle.
    T4 is listening for TCP on port 7007, on my linux box I do
    ttcp -t -s -p 7007 192.168.1.132
    ttcp-t: buflen=8192, nbuf=2048, align=16384/0, port=7007  tcp  -> 192.168.1.132
    ttcp-t: socket
    ttcp-t: connect
    ttcp-t: 16777216 bytes in 5.95 real seconds = 2755.87 KB/sec +++
    ttcp-t: 2048 I/O calls, msec/call = 2.97, calls/sec = 344.48
    ttcp-t: 0.0user 0.0sys 0:05real 0% 0i+0d 740maxrss 0+2pf 280+0csw
    and serial monitor reports
    Megabytes: 16.777216  Seconds: 5.9730  KBits/Sec: 22470.7397
    if i plug dongle into linux, lsusb says: Bus 001 Device 004: ID 0b95:772b ASIX Electronics Corp. AX88772B
  5. #305
    Germany NRW
    6,530
    Yes I had no luck with my buy.
    None of these dongles have their exact chipset published. I just hoped it was okay - the description said AX88772<- no "B" or "A" - and i did not expect a real difference.
    So, I just put it away and do other things. I try it again later, in a few weeks.
  6. #306
    10,922
    Wondering if you got the USB2 or USB3? As linked above the 'Basics' version USB 2.0 has 'black' insert block in the USB connector - as pictured on the U.S. Amazon site. I ordered two at different times - and both arrived with the same compatible chipset on them. I wanted an extra for my Surface laptop with no built in Ethernet and it worked well there too.
  7. #307
    Germany NRW
    6,530
    USB 2.0 - it's not the "Basics" version, it is "Amazon's choice", and looks identical from the outside. It has a "UGREEN" printing on it.
    Amazon's choice was wrong
    https://www.amazon.de/gp/product/B00...?ie=UTF8&psc=1
    I'll send it back.
  8. #308
    10,922
    so close … not choice but indeed 'basics' > https://www.amazon.de/dp/B00M77HLII
  9. #309
    Germany NRW
    6,530
    Ok, the Amazon Basics USB2.0 adapter works.
    USB Ready
    MulticastJoin: 3333FFE776CB
    netif Initialized
    Initializing DHCP
    IPAddress: 0.0.0.0
    SubnetMask: 0.0.0.0
    Gateway: 0.0.0.0
    DHCPServer: 0.0.0.0
    State: 2
    DHCP Released
    Mutex released
    Mutex released
    SetMACAddress: 0050B6E776CB
    netif Initialized
    Initializing DHCP
    IPAddress: 0.0.0.0
    SubnetMask: 0.0.0.0
    Gateway: 0.0.0.0
    DHCPServer: 0.0.0.0
    State: 2
    IPAddress: 192.168.178.46
    Gateway: 192.168.178.1
    DHCPServer: 192.168.178.1
    State: 5
    Thanks Good work!
  10. #310
    Germany NRW
    6,530
    Do you have a simple http-request example ?
  11. #311
    Apr 2017
    Florida
    472
    I haven’t done much work with it outside of TCP, this whole project was just because I needed faster TCP than I could get with a w5500 for a custom euphonix controller.
  12. #312
    2,383
    if you look in sketchbook/libraries/FNET/src/service, you'll see a collection of client/server folders:
    autoip/  dns/			 fnet_service.h*      link/   serial/  tftp/
    azure/	 flash/			 fnet_service_prv.h*  llmnr/  shell/   tls/
    bench/	 fnet_service.c*	 fs/		      mdns/   sntp/
    dhcp/	 fnet_service_config.h*  http/		      ping/   telnet/
    You'll need to create a sketch that initializes various parameters and provides callbacks for your client/server of choice. you see there is an http/ folder that has both client and server code. Study the lib examples > ASIXEthernet_Test sketch. it uses the service/bench/ folder to create the simple benchmarks sketch that you can run against fbench.exe. I managed to use the sntp/ client to create an SNTP test sketch.
  13. #313
    Germany NRW
    6,530
    Ah, great, thank you.
    Would you mind to post your SNTP sketch?
  14. #314
    2,383
    see attached tmp.zip. I had tried different things with this sketch (like not using threads), but i think this is a working version. you'll need to provide an IP for an NTP server
    Attached Files Attached Files
  15. #315
    Germany NRW
    6,530
    "tmp" is a nice name for that Thank You!!
    But It does not work for me.. i updated the IP fo my ntp-server (my router) - but it happens nothing.
  16. #316
    2,383
    I just tried it on T3.6 and T4.0, works for me. Sketch prints the usual startup stuff for DHCP etc, then
    ntp 3791047716 887142411 utc 20:48:36  RTT 896 us
    ntp 3791047717 891406643 utc 20:48:37  RTT 893 us
    ntp 3791047718 895724579 utc 20:48:38  RTT 890 us
    It's not very robust, if reply never comes it never tries to send again (needs a retry timer?). Maybe sniff with wireshark and see if you see NTP packets on the wire. i have an NTP server running on one of my local linux boxes.
    EDIT: ooops, I actually altered fnet_sntp.c in the FNET lib to capture RTT with micros(), so it's a bit of a hack.
    diff fnet_sntp.c.0 fnet_sntp.c
    256a257
    > 	static uint32_t us;
    263a265
    > 			us = micros();
    281a284
    > 			us = micros()-us;
    328a332
    > 			if (sntp_if->callback_cookie) *(uint32_t *)(sntp_if->callback_cookie) = us;
  17. #317
    2,383
    Playing with the numbers for Udp 3000 messages of 32000 bytes in 1 fBench second?
    0.990 96,000,000 775,465.875
    1.038 96,000,000 739,825.806
    1.019 96,000,000 753,759.301
    1.011 96,000,000 760,004.148
    0.999 96,000,000 769,068.005
    1.000 96,000,000 768,217.790
    I'm trying to make sense of these "unbelievably" fast UDP data rates. The amazon USB Ethernet dongle is only good for 10/100 mbs Ethernet? So what does 760 mbs mean? Even the USB is only 480 mbs? A 32768 byte UDP "message" will require IP fragmentation to break the message into MSS (1460)- byte packets. UDP data rates are best measured at the receiver.
    In my tests (post #264), I measure about 95 mbs for UDP transmits (1000-byte UDP packets), rate measured at receiver, no drops.
  18. #318
    Apr 2017
    Florida
    472
    FNET already handles separating messages into the correct max size, my guess is it’s exceeding the number of USB buffers that I have set without waiting for them to free up. I believe I put in something to stop that from happening though, can you verify that all messages are making it to the receiver? If all aren’t making it then somewhere they are being discarded before USB gets it so that would explain the speed discrepancy.
  19. #319
    10,922
    All the others had net throughput under 100K bits/sec. Have to find a table showing the column labels - it shows total bytes in test period - not sure of the others just now.
    These are UDP, any chance some were not even received or processed on the Teensy end?
    @manitou - looking at post#22 on some test thread:
    Attachment 19185
    TCP is where it should be - UDP is just flooding and counted as good?
  20. #320
    Apr 2017
    Florida
    472
    If the UDP messages are being sent from fbench to the Teensy then the throughput can very well show 750 mbps if your computer is on a gigabit connection to your router since the connection speed of the Teensy would have little to no effect for UDP messages wether they are being lost or not.
  21. #321
    2,383
    Quote Originally Posted by vjmuzik View Post
    ah, that makes sense. I don't have GigE on my home setup.
