Page 5 of 13 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 101 to 125 of 321
Thread: USB Host Ethernet Driver
  1. #101
    10,914
    Windows 10 'Dos Box' cmd line from : ping 192.168.0.23 -n 1000 -l 465
    Only saw it as first noted above today. All instances are always : MISCOMPARE at offset 22
    Reply from 192.168.0.23: bytes=465 time=1ms TTL=64
    Reply from 192.168.0.23: bytes=465 - MISCOMPARE at offset 22 - time=1ms TTL=64
    Reply from 192.168.0.23: bytes=465 time<1ms TTL=64
  2. #102
    Apr 2017
    Florida
    472
    Offset 22 seems to be the TTL number, not sure why that says its wrong.
  3. #103
    10,914
    Quote Originally Posted by vjmuzik View Post
    Odd, it doesn't show what was received - and it hasn't ever shown on the 1465 long ping - but after using that here and before it suddenly is seeing that bad byte coming back?
  4. #104
    Apr 2017
    Florida
    472
    I use Wireshark to view what’s received at the same time, and on Wireshark I went to byte 22 and it shows as the TTL value so maybe that can help diagnose the issue? I know on the MacOS terminal if ping receives something it doesn’t expect, it shows the original message and what was received, I’ve only had this happen once in the beginning because the code was wrong, but I fixed it. Now I only either drop a frame or receive it, I myself haven’t had any issues with any not matching up since the one time my code was wrong.
  5. #105
    10,914
    Found MS SysInternals tool PsPing here : https://docs.microsoft.com/en-us/sys...wnloads/psping
    Does a FAST ping for 10 seconds here and completed 7,127 with I loss, and then 9680.
    Two sets below - one had another ping running and was slow and this came out SerMon:
    Message Recieve Error
    T:\T_Downloads\PSTools>psping -n 10s -q -i 0 192.168.0.23
    PsPing v2.10 - PsPing - ping, latency, bandwidth measurement utility
    Copyright (C) 2012-2016 Mark Russinovich
    Sysinternals - www.sysinternals.com
    Pinging 192.168.0.23 with 32 bytes of data:
    10 seconds (1 warmup pings) connecting test: 100%
    Ping statistics for 192.168.0.23:
      Sent = 7127, Received = 7126, Lost = 1 (0% loss),
      Minimum = 0.40ms, Maximum = 10.29ms, Average = 1.01ms
      Sent = 9680, Received = 9680, Lost = 0 (0% loss),
      Minimum = 0.32ms, Maximum = 10.18ms, Average = 0.99ms
    Here is a histogram of 10,000 pings:
    T:\T_Downloads\PSTools>psping -n 10000 -h 20 -q -i 0 192.168.0.23
    10001 iterations (warmup 1) ping test: 100%
      Sent = 10000, Received = 10000, Lost = 0 (0% loss),
      Minimum = 0.35ms, Maximum = 11.19ms, Average = 1.00ms
    Latency Count
    0.35    1944
    0.92    7907
    1.49    52
    2.06    17
    2.63    23
    3.20    8
    3.77    7
    4.34    6
    4.91    11
    5.48    5
    6.05    5
    6.62    7
    7.19    2
    7.76    2
    8.34    0
    8.91    3
    9.48    0
    10.05   0
    10.62   0
    11.19   1
  6. #106
    Apr 2017
    Florida
    472
    I’m not sure what’s causing the message receive errors, I looked at one before and it was basically empty, a lot of zeros where there should’ve been data. So rather than lock up because it’s all zeros it just does nothing and prints the error to the serial monitor.
  7. #107
    10,914
    I trusted that as a tool to grab from MSFT - I don't seem to be able to control buffer size. Wasn't sure if it would - and if it would show error data.
    Doing that FAST PING and then fBench {100*10@32767} caused some issues and long strings of the 'Message Receive Error'
    where fBench had one bad group - and had to close?:
    2.608	3,276,700	10,051.169
    0.403	589,806	11,695.460
    2.611	3,276,700	10,040.443
    But PsPing gave - two LONG lost packets and 9998 FAST ones:
    Sent = 10000, Received = 9998, Lost = 2 (0% loss),
    Minimum = 0.40ms, Maximum = 5.79ms, Average = 1.10ms
    Latency Count
    0.40 9998
    259.29 0
    518.17 0
    777.06 0
    1035.95 0
    1294.84 0
    1553.72 0
    1812.61 0
    2071.50 0
    2330.39 0
    2589.27 0
    2848.16 0
    3107.05 0
    3365.94 0
    3624.82 0
    3883.71 0
    4142.60 0
    4401.49 0
    4660.37 1
    4919.26 1
  8. #108
    Apr 2017
    Florida
    472
    I wonder if there’s a way to see how full the buffer of the ASIX ram is, I’ll look into it and see if maybe that correlates with bad messages being received.
  9. #109
    10,914
    installing Wireshark ...
  10. #110
    10,914
    Running PING 465 and the large transfers I created this - then stopped wireshark capture and found this entry that seems applicable to : Reply from 192.168.0.23: bytes=465 - MISCOMPARE at offset 22 - time<1ms TTL=64
    7769	22.676066	192.168.0.22	192.168.0.23	ICMP	507	Echo (ping) request  id=0x0002, seq=60941/3566, ttl=128 (no response found!)
    Not sure if this shows right info usably?
    The same happened 12 pings before and couting up 12 pairs in wireshark log for messages that size I see the same thing
    This goes out::
    0000   00 50 b6 e2 25 ab 18 66 da 36 cc fd 08 00 45 00   .P..%..f.6....E.
    0010   01 ed 8e aa 00 00 80 01 00 00 c0 a8 00 16 c0 a8   ................
    0020   00 17 08 00 76 bf 00 02 ee 0d 61 62 63 64 65 66   ....v.....abcdef
    0030   67 68 69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76   ghijklmnopqrstuv
    0040   77 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f   wabcdefghijklmno
    0050   70 71 72 73 74 75 76 77 61 62 63 64 65 66 67 68   pqrstuvwabcdefgh
    0060   69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77 61   ijklmnopqrstuvwa
    0070   62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71   bcdefghijklmnopq
    0080   72 73 74 75 76 77 61 62 63 64 65 66 67 68 69 6a   rstuvwabcdefghij
    0090   6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77 61 62 63   klmnopqrstuvwabc
    00a0   64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72 73   defghijklmnopqrs
    00b0   74 75 76 77 61 62 63 64 65 66 67 68 69 6a 6b 6c   tuvwabcdefghijkl
    00c0   6d 6e 6f 70 71 72 73 74 75 76 77 61 62 63 64 65   mnopqrstuvwabcde
    00d0   66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75   fghijklmnopqrstu
    00e0   76 77 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e   vwabcdefghijklmn
    00f0   6f 70 71 72 73 74 75 76 77 61 62 63 64 65 66 67   opqrstuvwabcdefg
    0100   68 69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77   hijklmnopqrstuvw
    0110   61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70   abcdefghijklmnop
    0120   71 72 73 74 75 76 77 61 62 63 64 65 66 67 68 69   qrstuvwabcdefghi
    0130   6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77 61 62   jklmnopqrstuvwab
    0140   63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72   cdefghijklmnopqr
    0150   73 74 75 76 77 61 62 63 64 65 66 67 68 69 6a 6b   stuvwabcdefghijk
    0160   6c 6d 6e 6f 70 71 72 73 74 75 76 77 61 62 63 64   lmnopqrstuvwabcd
    0170   65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72 73 74   efghijklmnopqrst
    0180   75 76 77 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d   uvwabcdefghijklm
    0190   6e 6f 70 71 72 73 74 75 76 77 61 62 63 64 65 66   nopqrstuvwabcdef
    01a0   67 68 69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76   ghijklmnopqrstuv
    01b0   77 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f   wabcdefghijklmno
    01c0   70 71 72 73 74 75 76 77 61 62 63 64 65 66 67 68   pqrstuvwabcdefgh
    01d0   69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77 61   ijklmnopqrstuvwa
    01e0   62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71   bcdefghijklmnopq
    01f0   72 73 74 75 76 77 61 62 63 64 65                  rstuvwabcde
    And this is received - that header repeat is not right?::
    0000   18 66 da 36 cc fd 00 50 b6 e2 25 ab 08 00 45 00   .f.6...P..%...E.
    0010   01 ed 32 cf 00 00 40 01 c4 c3 c0 a8 00 17 c0 a8   ..2...@.........
    0020   00 16 00 00 3a 41 00 02 ee 0d 61 62 63 64 65 66   ....:A....abcdef
    0040   70 71 72 73 74 75 76 77 61 62 63 64 65 66 67 68   pqrstuvwabcdefgh
    0050   69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77 61   ijklmnopqrstuvwa
    0060   62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71   bcdefghijklmnopq
    0070   72 73 74 75 76 77 61 62 63 64 65 64 fb 01 04 f6   rstuvwabcded....
    0080   18 66 da 36 cc fd 00 50 b6 e2 25 ab 08 00 45 00   .f.6...P..%...E.
    0090   01 ed 32 cf 00 00 40 01 c4 c3 c0 a8 00 17 c0 a8   ..2...@.........
    00a0   00 16 00 00 7e bf 00 02 ee 0d 61 62 63 64 65 66   ....~.....abcdef
    00b0   67 68 69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76   ghijklmnopqrstuv
    00c0   77 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f   wabcdefghijklmno
    00d0   70 71 72 73 74 75 76 77 61 62 63 64 65 66 67 68   pqrstuvwabcdefgh
    00e0   69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77 61   ijklmnopqrstuvwa
    00f0   62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71   bcdefghijklmnopq
    0100   72 73 74 75 76 77 61 62 63 64 65 66 67 68 69 6a   rstuvwabcdefghij
    0110   6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77 61 62 63   klmnopqrstuvwabc
    0120   64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72 73   defghijklmnopqrs
    0130   74 75 76 77 61 62 63 64 65 66 67 68 69 6a 6b 6c   tuvwabcdefghijkl
    0140   6d 6e 6f 70 71 72 73 74 75 76 77 61 62 63 64 65   mnopqrstuvwabcde
    0150   66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75   fghijklmnopqrstu
    0160   76 77 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e   vwabcdefghijklmn
    0170   6f 70 71 72 73 74 75 76 77 61 62 63 64 65 66 67   opqrstuvwabcdefg
    0180   68 69 6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77   hijklmnopqrstuvw
    0190   61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70   abcdefghijklmnop
    01a0   71 72 73 74 75 76 77 61 62 63 64 65 66 67 68 69   qrstuvwabcdefghi
    01b0   6a 6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77 61 62   jklmnopqrstuvwab
    01c0   63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72   cdefghijklmnopqr
    01d0   73 74 75 76 77 61 62 63 64 65 66 67 68 69 6a 6b   stuvwabcdefghijk
    01e0   6c 6d 6e 6f 70 71 72 73 74 75 76 77 61 62 63 64   lmnopqrstuvwabcd
    01f0   65 66 67 68 69 6a 6b 6c 6d 6e 6f                  efghijklmno
  11. #111
    Apr 2017
    Florida
    472
    I can see the ttl doesn't match, which would be offset 22 if that is what it was complaining about.
  12. #112
    Apr 2017
    Florida
    472
    Looks like halfway through that message it starts from the beginning of the buffer again. I'm working on a fix for the receive errors so it can get the rest of the messages that are in there instead of discarding them all, it may fix that?
  13. #113
    Apr 2017
    Florida
    472
    Alright I changed the error case so it looks for a new header in the error message and uses it if it finds one so not all the messages are lost now.
  14. #114
    10,914
    First was this before WS_capt
    Then this - but I hit my finger too soon on stop
    >> Reply from 192.168.0.23: bytes=465 - MISCOMPARE at offset 82 - time<1ms TTL=64
    22 looks the same - will wait for an #88 or other again ...
    Here is another #22 OUT>>
    0010   01 ed 44 91 00 00 80 01 00 00 c0 a8 00 16 c0 a8   ..D.............
    0020   00 17 08 00 75 a9 00 02 ef 23 61 62 63 64 65 66   ....u....#abcdef
    And failed IN - looks similar::
    0010   01 ed 88 a6 00 00 40 01 6e ec c0 a8 00 17 c0 a8   ......@.n.......
    0020   00 16 00 00 4f 3f 00 02 ef 23 61 62 63 64 65 66   ....O?...#abcdef
    0040   63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72   cdefghijklmnopqr
    0050   73 74 75 76 77 61 62 63 64 65 66 67 68 69 6a 6b   stuvwabcdefghijk
    0060   6c 6d 6e 6f 70 71 72 73 74 75 76 77 61 62 63 64   lmnopqrstuvwabcd
    0070   65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 fb 01 04 f6   efghijklmnop....
    0090   01 ed 88 a6 00 00 40 01 6e ec c0 a8 00 17 c0 a8   ......@.n.......
    00a0   00 16 00 00 7d a9 00 02 ef 23 61 62 63 64 65 66   ....}....#abcdef
  15. #115
    Apr 2017
    Florida
    472
    I don’t know what would be causing that, if it was consistent I would at least have an idea.
  16. #116
    10,914
    I only saw update for FNET-master after last change?
    Fail report of :: Reply from 192.168.0.23: bytes=465 - MISCOMPARE at offset 82 - time<1ms TTL=64
    Is just the other end of the prior fail for #22.
    Out ping: 19609 50.442781 192.168.0.22 192.168.0.23 ICMP 507 Echo (ping) request id=0x0002, seq=61461/5616, ttl=128 (no response found!)
    0010   01 ed 44 6a 00 00 80 01 00 00 c0 a8 00 16 c0 a8   ..Dj............
    0020   00 17 08 00 74 b7 00 02 f0 15 61 62 63 64 65 66   ....t.....abcdef
    And other unmatched :: 19610 50.443599 192.168.0.23 192.168.0.22 ICMP 507 Echo (ping) reply id=0x0002, seq=61461/5616, ttl=64
    0010   01 ed bd a6 00 00 40 01 39 ec c0 a8 00 17 c0 a8   ......@.9.......
    0020   00 16 00 00 4c 62 00 02 f0 15 61 62 63 64 65 66   ....Lb....abcdef
    0070   62 63 64 65 66 67 68 69 6a 6b 6c 6d fb 01 04 f6   bcdefghijklm....
    0090   01 ed bd a6 00 00 40 01 39 ec c0 a8 00 17 c0 a8   ......@.9.......
    00a0   00 16 00 00 7c b7 00 02 f0 15 61 62 63 64 65 66   ....|.....abcdef
    SerMon has this added text:
    Benchmark results:
    Megabytes: 3.275800
    Seconds: 2.7480
    Bytes/Sec: 1192066.9578
    KBytes/Sec: 1192.0670
    KBits/Sec: 9536.5357
    Message Recieve Error, searching for next header
    Error: No new header found
    Benchmark results:
    Megabytes: 3.275800
    Seconds: 2.7660
    Bytes/Sec: 1184309.4722
    KBytes/Sec: 1184.3095
    KBits/Sec: 9474.4758
    Benchmark results:
    Megabytes: 3.275800
    Seconds: 2.7000
    Bytes/Sec: 1213259.2593
    KBytes/Sec: 1213.2593
    KBits/Sec: 9706.0741
  17. #117
    10,914
    Note before said some PING sizes acted odd? Maybe 465 is triggering one of those? It happens with regularity when doing the fBench. Size 32758 now instead of 32768 - but it showed initially with smaller sizes IIRC.
  18. #118
    Apr 2017
    Florida
    472
    Yeah the added text is to let you know if there was any extra information in the error packet that gets flagged. For some reason some messages get padded with extra 0’s so it throws the length off which wouldn’t be a problem if there weren’t multiple messages in some usb packets. So the error loops through the extra zeros to see if there is another message header or not and proceeds to process the message if it’s found.
  19. #119
    Apr 2017
    Florida
    472
    As far as 465 bytes causing an error, I know that is the first ping size that was being split into multiple usb packets when I had the buffer set to 512 bytes originally, but now the buffer is bigger so it shouldn’t be getting split apart. Even if it did get split apart it should be reconstructed properly.
  20. #120
    10,914
    That is odd that I found a combo that is hitting errors with regularity. Let me know if there is anything else I can get from Wireshark logging to give info.
    Just looked and the USB/LAN is "Hi-Speed Full 10/100 Mbps Ethernet " - is it connecting in 10 or 100 I wonder. Seeing speeds of 9-11 Mbps is either maxing out 10 or barely touching 100 Mbps?
  21. #121
    Apr 2017
    Florida
    472
    Thatís a good point about connection speed, Iíll make a function to print that when it connects to to a network and find out.
  22. #122
    Apr 2017
    Florida
    472
    Scratch that, it is operating at 100BASE-T so there is a bottleneck somewhere.
  23. #123
    Apr 2017
    Florida
    472
    So interesting results...
    10:48:56.546 -> Benchmark results:
    10:48:56.546 -> Megabytes: 0.32767
    10:48:56.546 -> Seconds: 0.0060
    10:48:56.546 -> Bytes/Sec: 5461166.5000
    10:48:56.546 -> KBytes/Sec: 5461.1665
    10:48:56.546 -> KBits/Sec: 43689.3320
  24. #124
    10,914
    @vjmuzik - T4 sitting IDLE here - and spitting these out. About 40 times - thought I saw them so cleared SerMon and left it last night
    Of course Wireshark shows tons of local net traffic - queries from Router etc - so likely just something not understood.? Turned on WS_capture with filter 'ip.src == 192.168.0.23 || ip.dst == 192.168.0.23' to see if there is a net event. Seems another occurred while typing this and setting up WS. Of course the LAN switch might direct that traffic to the T4's port without desktop seeing it? I see another of those in SerMon and nothing on WireShark capture.
    Good it is setting up for 100BASE-T - my switch light does show 'Yellow' suggesting 100 - but wasn't sure it has a color for 10Mbps. Shows room for speed increase.
    The "10:48:56.546 -> KBits/Sec: 43689.3320" above looks good - but wondering if it is just an anomoly with time calc across the multipart message? Not yet seen T4 system here not over 14Mbps?
  25. #125
    Apr 2017
    Florida
    472
    Yeah the value seems inconsistent at best, I’ve hit around the same number a couple of times but it’s definitely an anomaly. Most of my tests come back ranging from 5-10Mbit/sec so it’s still an improvement over a w5500, but not quite as much as I was hoping for.
