Audio over Serial
Hi all - this is more of a would this be possible/what are my first steps question;
I want to send audio between A and B digitally using two Teensy (bidirectional).
Is there a serial node available that I could use to send the bit stream over one wire from one teensy to the other, and another wire in the opposing direction. I understand that Teensy has the capability to send and receive data serially at these rates, Just need a pointer as to how I can go about implementing this. The follow on question would be could I then have multiple (6) teensy's sending and receiving data from a central teensy that hosts a matrix internally.
The Teensy 4.0 chip supports SPDIF which is exactly what you want for point to point as that is what it was designed for. But I believe you'd have to write your own drivers for now for the Teensy.
The second question is a bit more complicated as SPDIF isn't multidrop so you'd probably need to add one of these, or something similar
https://www.cirrus.com/products/cs8416/
The Teensy Audio Board/Audio Library supports SPDIF IO, and multi-channel TDM (time-division-multiplex) through the CS42448 chip...
Originally Posted by
DerekR
From Paul himself last month :
There is the small matter of (so far) no software support for Teensy 4.0's S/PDIF peripheral in the audio library.
Given the power of the Teensy4.0 for audio, I wouldn't think it a good idea to start from the lower power modules for anything serious, which the OP's description sounds like.
bi-directional causes problems if you need synchronised audio. even though the two clocks are crystal locked, they will drift over time. the usual solution is to use a master clock, usually generated by one of the sources, or as a studio standard signal.
unfortunately, synchronised external audio isn't in the library yet. there was a series of posts by MikeDB over the past few days that discusses the issues.
if you want Uni-directional, then the I2S master/slave will do quite nicely over short distances - as it needs multiple signals.
over longer distances the DS90UA101 serialiser / deserialiser allows all the I2s signals to be carried on a single twisted pair.
serial can work, probably using RS485 as a physical layer, as the teensy so can sustain 3Mbits or more. however, the audio library does not have a widget for this.
I hope this helps your thinking.
Hi all - if there was no need for them to be synced how would you achieve this?
Tried to use the queue command and got no sound.
Did you get this to work?
I have this working by adding Serial1 read and write to this example using usb and queues.
https://forum.pjrc.com/threads/51154...SB-with-queues
A problem I have is my Teensies stop responding while recording in Windows unless I have a Serial.println(“loop”) in every loop call.
btspp
The source is at https://forum.pjrc.com/threads/69032...s-records-once
- You may not post replies
- You may not edit your posts
Forum Rules
