Results 1 to 10 of 10
Thread: Trouble passing Serial, Serial1, Serial2 as a reference
    Nov 2016
    6
    I'm trying to have a single project that can either send/receive strings via USB serial or Bluetooth. I have a command to switch between Serial and Serial2. It doesn't seem to work the way I expect. When I send a "BTON" command, the print statement prints to Serial, switches to Serial2 and properly prints to Serial2. But when I send the "BTOFF" command immediately after "BTON", both print statements print to Serial when I expected the 1st print command to go to Serial2. It seems as though the "Stream& MySerial = Serial2;" does not persist. Can anyone provide help?
    Thanks.
    uint8_t argCount;
    uint8_t thisArg = 0;
    char *argv[30];
    bool BT = false;
    Stream& MySerial = Serial;
    	Serial2.begin(115200);
    	static char buffer[80];
    	if ((readline(Serial.read(), buffer, 80) > 0) || (readline(Serial2.read(), buffer, 80) > 0)) {
    		char tmpBuffer[sizeof(buffer)-2];
    		strcpy(tmpBuffer, &(buffer[2]));
    		cmd_parse(buffer);
    		if (!strcmp(argv[0],"BTON")) {
    			MySerial.println("Bluetooth Turning on");  // This properly prints to Serial
    			MySerial.println("Bluetooth is turned on");  // This properly prints to Serial2
    		else if (!strcmp(argv[0],"BTOFF")) {
    			MySerial.println("Bluetooth Turning off");  // THIS DOES NOT PRINT TO SERIAL2
    			MySerial.println("Bluetooth is turned off");  // This prints to Serial
    184
    You have defined 3 variables named MySerial. This is probably not what you intended.
    5,584
    I am not the greatest c++ expert, but would strongly guess that the MySerial.println("Bluetooth Turning off"); // THIS DOES NOT PRINT TO SERIAL2
    Would print to Serial and not Serial2.
    Why: as @markonian mentioned, you have defined three different MySerial objects, each have their own scope.
    In Particular: Stream& MySerial = Serial;
    Has a global scope, so it is valid everywhere in your sketch (after that point it is defined).
    And the definition:
    Is only valid within the code block that it is defined. That is everywhere after where it is defined up till that next }
    Within that scope it sort of masks the global definition variable, but when you exit that scope, the global version is again used...
    I know that a compiler person could explain this better than I just did, including the proper terms for the scoping...
    Nov 2016
    6
    Shoot. Of course... Now I'm not sure how to change the global reference to Serial2. I have read that you cannot change references. Do I understand this correctly or is there a way to change the global reference back and forth between Serial and Serial2?
    1,170
    Don't redeclare MySerial. Just assign a new value to it.
    MySerial = Serial2;
    MySerial = Serial;
    Pete
    Nov 2016
    6
    MySerial = Serial2;
    MySerial = Serial;
    Pete
    I tried this and it didn't work. I don't think I am able to re-assign the reference that way as everything prints to Serial.
    1,170
    Hmm. I'll have to ponder that.
    BTW what is readline? It looks like you are reading a line from Serial and a line from Serial2 into the same buffer. If so, that'll be quite messy.
    Pete
    Try this:
    			Serial2.println("Bluetooth is turned on");  // This properly prints to Serial2
    			Serial2.println("Bluetooth Turning off");  // THIS DOES NOT PRINT TO SERIAL2
    The usual test for data on a serial port is:
    	if (Serial.available() > 0)
    		incomingByte = Serial.read();
    Germany
    546
    Right, references can not be reassigned. This is much easier by using pointers instead of references.
    Just declare a global pointer holding the address of the Serial object you want to print to. You can change that at any time.
    Since your code snippet does not compile here a simple example which shows the principle by switching the port after each print:
    Stream *mySerial;
       Serial1.begin(9600);
       Serial2.begin(9600);
       // E.g. assign the address of Serial1 to mySerial for a start
       mySerial = &Serial1;
       // just assign any Stream address (e.g. Serial, Seria1, ....)
       // to mySerial.
       // Here a simple example which switches ports after each print
       // replace that with your switching code
       if (mySerial == &Serial1)
          mySerial = &Serial2;
          (mySerial = &Serial1);
      // print to the currently selected port
       mySerial->println("Hello");
       delay(100); // don't overrun the receiver
    Nov 2016
    6
    luni,
    Thank you. I have switched to pointers and MySerial->print. This works!!
    Elf,
    Thank you for the suggestion, but I do not want to print twice everywhere as I have some timing constraints and prints take too much time already.
