DmaSpi library with T4
Spyy
is there any chance that this great library will work together with the teensy 4 ?
https://github.com/crteensy/DmaSpi
As far i understood with this library you can "deligate" the SPI transfer to a DMA channel and you program can do other things while the data is transferred to the SPI "client", and you can synchronize it via interrupt ?
Thank you
Torsten
Hi KurtE,
Yes it says unknown chip...i thing due to an #ifdef....and i really do not understand what the purpose of this is...so i can't fix it...
Thank you for your help...
Torsten
I did a pass through it to add T4, that it appears like the DMASpi_example1 is working.
The Fork/Branch is up at: https://github.com/KurtE/DmaSpi/tree/T4
It might be good if someone else tried it as well. I have not yet tried out using SPI1 or SPI2 with it.
Edit: Went ahead and issue PR: https://github.com/crteensy/DmaSpi/pull/28
I tried on SPi1 as well
Thanks for doing this, I'm using this for my adventures with DMA and SPI.
I have a question, I can get SPI0 or SPI1 to work, fab.
But I can't get DMA for both, I assume I'm doing something wrong, or was the library not designed to do both?
Thanks in advance
Paula
My bad, complete noob error on my part... going to rest my eyes as this was a truly stupid mistake.
