Bill Greiman
I am porting the ChibiOS RTOS to T4 and need to use the SVC Call vector. Here is the code I am currently using for SVC_Handler and periodic tick.
Is there a better way to connect to the SVC Call vector?
The above works fine. The T4 is great with ChibiOS. A context switch triggered by a semaphore in the following example takes only 200 ns.
This means that an interrupt handler can start a thread in 200 ns with a semaphore.
static void tick() {
CH_IRQ_PROLOGUE();
chSysLockFromISR();
chSysTimerHandlerI();
chSysUnlockFromISR();
CH_IRQ_EPILOGUE();
extern "C" void SVC_Handler(void);
IntervalTimer chTimer;
extern "C" void st_lld_init(void) {
_VectorsRam[11] = SVC_Handler;
chTimer.begin(tick, 1000);
// Connect a scope to pin 13
// Measure difference in time between first pulse with no context switch
// and second pulse started in thread 2 and ended in thread 1.
// Difference should be about 15-16 usec on a 16 MHz 328 Arduino.
// 200 ns on T4.
#include "ChRt.h"
// LED_BUILTIN pin on Arduino is usually pin 13.
// Semaphore to trigger context switch
SEMAPHORE_DECL(sem, 0);
// thread 1 - high priority thread to set pin low.
// 64 byte stack beyond task switch and interrupt needs.
static THD_WORKING_AREA(waThread1, 64);
static THD_FUNCTION(Thread1, arg) {
(void)arg;
while (true) {
chSemWait(&sem);
// thread 2 - lower priority thread to toggle LED and trigger thread 1.
static THD_WORKING_AREA(waThread2, 64);
static THD_FUNCTION(Thread2, arg) {
(void)arg;
pinMode(LED_BUILTIN, OUTPUT);
while (true) {
// First pulse to get time with no context switch.
// Start second pulse.
// Trigger context switch for task that ends pulse.
chSemSignal(&sem);
// Sleep until next tick.
chThdSleep(1);
void chSetup() {
// Start high priority thread.
chThdCreateStatic(waThread1, sizeof(waThread1),
NORMALPRIO + 2, Thread1, NULL);
// Start lower priority thread.
chThdCreateStatic(waThread2, sizeof(waThread2),
NORMALPRIO+1, Thread2, NULL);
chBegin(&chSetup);
// chBegin() resets stacks and should never return.
while (true) {}
// Not used.
