Results 1 to 4 of 4
Thread: Teensy SDR help
    Teensy SDR help
    HI,
    I'm looking for a SIMPLE SDR sketch! You have to crawl before you can walk, so I've attempted to use VE3MKC's version 1 SDR, with no success. I was trying to compile using Arduino 1.8.9 with no luck. Then my friend said I should try the older Arduino version since the sketch was written back in 2015, so he kindly sent me 1.6.3 and the matching teensyduino file. Neither Arduino version will compile. I only get a cryptic message "multiple copies found for SD.h". Removing the offending SD.h file doesn't help either.
    I just want a simple SDR: Teensy 3.2, Teensy audio board, TFT display (ST7735S), Si5351, and an encoder. I don't need to record, keep time, or transmit.... This isn't rocket science, is it? Does anyone have such a sketch or .HEX file I can play with?
    Thanks,
    Jim
    Senior Member DD4WH's Avatar
    Oct 2015
    Central Europe
    507
    This should be pretty close to what you are looking for:
    https://github.com/DD4WH/Teensy-SDR-Rx
    Have a close look at the pdf first of all.
    All the best,
    Frank DD4WH
    May 2016
    226
    You might also take a look at AudioSDR here. It is a single Audio Library object that contains a complete SDR software package, but it is designed expressly for f32 processing and therefore needs a T3.6 or T4. My current full system uses the T3.6, but I also have a T4 "barebones" AudioSDR WSPR (Weak Signal Propagation Reporter) receiver running 24/7 very successfully on 40m (without any user controls).
    There is extensive documentation in the AudioSDR package.
    Derek
    Mar 2019
    14
    I found this website and author very helpful..
    https://zl2ctm.blogspot.com/2018/03/...27447334353041
    I've used the very basic code from this site to demod SSB using teensy3.6 and it works fine.
    Rob
