Results 1 to 3 of 3
Thread: is posible to read AudioSynthWaveform out as data?
    Sep 2019
    Sevilla, Spain
    2
    hi, I'm working in a multiple LFO eurorack module with cross modulation, sadly the AudioSynthWaveform does not have a read(); function (like AudioSynthWaveformDc has) so if I want to control the amount of modulation for pitch, amplitude and offset lots of mixers are needed. Checked AudioRecordQueue but this gives a read of 128 samples, in that case there will be a latency of 2,9 milliseconds. If there was a way read each waveform as data, it would be much easier as all the parameters I would like to modulate are already functions of AudioSynthWaveform.
    first column of mixers controls the frequency modulation, second the amplitude and third the offset
    160
    I did something like this:
    Edit synth_waveform.cpp around line 175:
    // Hack to get amplitude for LFO purposes.
    	last_amplitude = static_cast<float>(block->data[AUDIO_BLOCK_SAMPLES-1]) / 32767.0f;
    Edit synth_waveform.h around line 117 to add last_amplitude and a getter for it:
    	float getLastAmplitude(void) {
    		return last_amplitude;
    private:
    	uint32_t phase_accumulator;
    	uint32_t phase_increment;
    	uint32_t phase_offset;
    	int32_t  magnitude;
    	uint32_t pulse_width;
    	const int16_t *arbdata;
    	int16_t  sample; // for WAVEFORM_SAMPLE_HOLD
    	short    tone_type;
    	int16_t  tone_offset;
    	float last_amplitude=0.0;
    last_amplitude will only be updated every 128 samples, so the max frequency it could measure would be something like 20000 / 128 = 156Hz which is perfectly fine for LFO usage.
    If you don't want to hack up the Audio library, you can use the Peak Analyzer, but I prefer not to since it consumes valuable CPU cycles. Anyway, hope that helps, good luck.
    Sep 2019
    Sevilla, Spain
    2
    thanks a lot for the answer, must try this and see how it works
