Results 1 to 15 of 15
Thread: Soft reboot on Teensy4.0
    Is there a way to trigger a reboot of the teensy 4.0 from the code? E.g. using watchdog? Anyone implemented it already?
    10,392
    not sure of the net effect - but yesterday a link to tonton81 github IIRC show a T4 watchdog sketch ….
    Apr 2017
    202
    Not sure if this will work on a t4, but works on a teensy 3.2
    // in globals declaration section
    #define CPU_RESTART_ADDR (uint32_t *)0xE000ED0C
    #define CPU_RESTART_VAL 0x5FA0004
    #define CPU_RESTART (*CPU_RESTART_ADDR = CPU_RESTART_VAL);
    // Then in loop do something like
    if (digitalRead(2) == HIGH){
    CPU_RESTART;
    not sure of the net effect - but yesterday a link to tonton81 github IIRC show a T4 watchdog sketch .
    I saw it also yesterday by accident.
    That does not work for me. The project is blocking the T4.
    I think it was developed for the T4beta1 using the 1052
    Quote Originally Posted by Jean-Marc View Post
    Also tried below procedure but no luck (see 1060 manual)
    *(volatile uint32_t *)0x400BC004 = 0xD928C520;
    while((*(volatile uint32_t *)0x400BC000 & (1UL<<11) )==0);
    *(volatile uint32_t *)0x400BC008 = 256;
    *(volatile uint32_t *)0x400BC000 |= (1UL<<7) + (1UL<<8) + (1UL<<6) + (1UL<<15)+ (1UL<<5);
    while((*(volatile uint32_t *)0x400BC000 & (1UL<<10) )==0);
    *(volatile uint32_t *)0x400BC004 = 0xB480A602;
    I asso don't see why I would unlock the WDOG.
    I don't see it locked in startup code?
    SCB_AIRCR = 0x5FA0004;
    while (true) {
    Also not working on the T4
    2,298
    The NXP 1060 SDK has a WDOG example, and I believe the program (wdog.c) is identical to the 1050 SDK version. The example works on the NXP 1050 eval board and workson 1060 eval board.
     * Copyright (c) 2016, Freescale Semiconductor, Inc.
     * Copyright 2016-2018 NXP
     * All rights reserved.
     * SPDX-License-Identifier: BSD-3-Clause
    #include "fsl_debug_console.h"
    #include "board.h"
    #include "fsl_wdog.h"
    #include "pin_mux.h"
    #include "clock_config.h"
     * Definitions
    #define DEMO_WDOG_BASE WDOG1
    #define DEMO_WDOG_IRQHandler WDOG1_IRQHandler
     * Prototypes
    * Variables
     * Code
    void DEMO_WDOG_IRQHandler(void)
        WDOG_Refresh(DEMO_WDOG_BASE);
        WDOG_ClearInterruptStatus(DEMO_WDOG_BASE, kWDOG_InterruptFlag);
        /*User code. */
        PRINTF(" \r\nWDOG has be refreshed!");
     * @brief Main function
    int main(void)
        uint16_t resetFlag = 0U;
        wdog_config_t config;
        BOARD_ConfigMPU();
        BOARD_InitPins();
        BOARD_BootClockRUN();
        BOARD_InitDebugConsole();
        PRINTF("\r\n******** System Start ********\r\n");
        PRINTF("System reset by:");
        resetFlag = WDOG_GetStatusFlags(DEMO_WDOG_BASE);
        switch (resetFlag & (kWDOG_PowerOnResetFlag | kWDOG_TimeoutResetFlag | kWDOG_SoftwareResetFlag))
            case kWDOG_PowerOnResetFlag:
                PRINTF(" Power On Reset!\r\n");
            case kWDOG_TimeoutResetFlag:
                PRINTF(" Time Out Reset!\r\n");
            case kWDOG_SoftwareResetFlag:
                PRINTF(" Software Reset!\r\n");
            default:
                PRINTF(" Error status!\r\n");
    /* Disable wdog reset function test for some devices can't using this feature. */
    #if (!(defined(EXAMPLE_DISABLE_WDOG_RESET_FUNCTION) && EXAMPLE_DISABLE_WDOG_RESET_FUNCTION))
        /* If system reset from power on, trigger a software reset. */
        if (resetFlag & kWDOG_PowerOnResetFlag)
            PRINTF("\r\n- 1.Testing System reset by software trigger...   ");
            WDOG_TriggerSystemSoftwareReset(DEMO_WDOG_BASE);
        /* If system reset from software trigger, testing the timeout reset. */
        if (resetFlag & kWDOG_SoftwareResetFlag)
            PRINTF("\r\n- 2.Testing system reset by WDOG timeout.\r\n");
             * wdogConfig->enableWdog = true;
             * wdogConfig->workMode.enableWait = true;
             * wdogConfig->workMode.enableStop = false;
             * wdogConfig->workMode.enableDebug = false;
             * wdogConfig->enableInterrupt = false;
             * wdogConfig->enablePowerdown = false;
             * wdogConfig->resetExtension = flase;
             * wdogConfig->timeoutValue = 0xFFU;
             * wdogConfig->interruptTimeValue = 0x04u;
            WDOG_GetDefaultConfig(&config);
            config.timeoutValue = 0xFU; /* Timeout value is 2.5 sec. */
            WDOG_Init(DEMO_WDOG_BASE, &config);
            PRINTF("--- wdog Init done---\r\n");
        /* If system reset from WDOG timeout, testing the refresh function using interrupt. */
        if (resetFlag & kWDOG_TimeoutResetFlag)
            PRINTF("\r\n- 3.Test the WDOG refresh function by using interrupt.\r\n");
            config.timeoutValue = 0xFU; /* Timeout value is 8 sec. */
            config.enableInterrupt = true;
            config.interruptTimeValue = 0x4U; /* Interrupt occurred 2 sec before WDOG timeout. */
        while (1)
    output from 1060 eval board test
            System reset by: Power On Reset!
            - 1.Testing System reset by software trigger... �
            System reset by: Software Reset!
            System reset by: Time Out Reset!
    FWIW, i made a wdog1.ino that does the same WDOG1 tests as the SDK example. The sketch works on T4B1 (1050), but on the production T4 (1060) it fails to restart after a watchdog timeout or a software reset.
    2,298
    the NXP 1060 SDK example does a software reset with base->WCR &= ~WDOG_WCR_SRS_MASK;
    on T4 (1060), WDOG1_WCR &= ~WDOG_WCR_SRS will cause a reset (sermon gray) but T4 doesn't restart. The T4B1 (1050) does restart on software reset.
    Same behavior for SCB_AIRCR = 0x05FA0004;, resets and restarts on T4B1, but doesn't restart on T4 (1060).
    Same behaviour as with wdog sample of tonton81 I had posted the question yesterday in the teensy beta thread, Tonton81 did react and will have a look later. Thanks to all.
    10,392
    For ref here what was the observed behavior?
    IIRC - first person trying this from other links - it lead to T4 sitting in bootloader?
    New York
    4,503
    Seems both WDOG and SCB_AIRCR suffer from the same system. When executed it shuts down the T4 as opposed to restarting - this was discussed in a couple of other threads as well:
    https://forum.pjrc.com/threads/57553...ight=SCB_AIRCR
    Dec 2017
    12
    Generic M7 manual indicates that this should work (same as T3.x), but I guess it doesn't.
    So has nobody figured out how to do a soft-reset on T4?
    Quote Originally Posted by roach374 View Post
    This is indeed the Arm7 procedure working on the T3.6 but not working on the T4.
    No progress so far.
    Has anyone here been able to get the watchdog timer to successfully reboot the system? I am still seeing the same behavior reported back in Oct, both a watchdog timeout or a forced system reset simply shuts down the T4 instead of causing it to reboot which obviously subverts the desired functionality... Is it a bug in the processor or perhaps something with the T4 board?
