PalePenguin
Hello! Im trying to build a digital synthesizer and I need to be able to read the output of a MIDI keyboard on the teensy and then create waveforms based on the MIDI signals.
My question, however, only pertains to the actual MIDI communication. All the examples I can find use USB midi library (https://www.pjrc.com/teensy/td_midi.html), programmed through Arduino IDE.
I'm supposed to select MIDI as the USB type, but this option is not available to me. I only see serial when I have the teensy 4.0 selected.
Why is this? What does this option even enable and is it possible to enable the same functionality manually?
Does anybody have another approach that I should use instead?
Kind regards,
Frederik.
Kind regards,
Frederik.
