Results 1 to 3 of 3
Thread: error trying to compile blinky in unbuntu
    I am a new Teensy 3.2 owner and Im just getting started understanding how to use this amazing little guy.
    I am on Ubuntu trying to compile the blinky example, but this error was appearing.
    blinky$ make
    -------- begin --------
    avr-gcc (GCC) 5.4.0
    Copyright (C) 2015 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    Compiling C: blinky.c
    avr-gcc -c -mmcu=atmega32u4         -I. -gdwarf-2 -DF_CPU=16000000UL -Os -funsigned-char -funsigned-bitfields -ffunction-sections -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=./blinky.lst  -std=gnu99 -MMD -MP -MF .dep/blinky.o.d blinky.c -o blinky.o
    Compiling C: usb_debug_only.c
    avr-gcc -c -mmcu=atmega32u4         -I. -gdwarf-2 -DF_CPU=16000000UL -Os -funsigned-char -funsigned-bitfields -ffunction-sections -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=./usb_debug_only.lst  -std=gnu99 -MMD -MP -MF .dep/usb_debug_only.o.d usb_debug_only.c -o usb_debug_only.o
    usb_debug_only.c:96:24: error: variable ‘device_descriptor’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’
     static uint8_t PROGMEM device_descriptor[] = {
    usb_debug_only.c:113:24: error: variable ‘hid_report_descriptor’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’
     static uint8_t PROGMEM hid_report_descriptor[] = {
    usb_debug_only.c:128:24: error: variable ‘config1_descriptor’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’
     static uint8_t PROGMEM config1_descriptor[CONFIG1_DESC_SIZE] = {
    usb_debug_only.c:175:52: error: variable ‘string0’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’
     static struct usb_string_descriptor_struct PROGMEM string0 = {
    usb_debug_only.c:180:52: error: variable ‘string1’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’
     static struct usb_string_descriptor_struct PROGMEM string1 = {
    usb_debug_only.c:185:52: error: variable ‘string2’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’
     static struct usb_string_descriptor_struct PROGMEM string2 = {
    usb_debug_only.c:198:11: error: variable ‘descriptor_list’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’
     } PROGMEM descriptor_list[] = {
    make: *** [Makefile:550: usb_debug_only.o] Error 1
    blinky$ avr-gcc -v
    Using built-in specs.
    Reading specs from /usr/lib/gcc/avr/5.4.0/device-specs/specs-avr2
    COLLECT_GCC=avr-gcc
    COLLECT_LTO_WRAPPER=/usr/lib/gcc/avr/5.4.0/lto-wrapper
    Target: avr
    Configured with: ../gcc/configure -v --enable-languages=c,c++ --prefix=/usr/lib --infodir=/usr/share/info --mandir=/usr/share/man --bindir=/usr/bin --libexecdir=/usr/lib --libdir=/usr/lib --enable-shared --with-system-zlib --enable-long-long --enable-nls --without-included-gettext --disable-libssp --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=avr CFLAGS='-g -O2 -fdebug-prefix-map=/build/gcc-avr-cb8hC_/gcc-avr-5.4.0+Atmel3.6.1=. -fstack-protector-strong -Wformat ' CPPFLAGS='-Wdate-time -D_FORTIFY_SOURCE=2' CXXFLAGS='-g -O2 -fdebug-prefix-map=/build/gcc-avr-cb8hC_/gcc-avr-5.4.0+Atmel3.6.1=. -fstack-protector-strong -Wformat ' FCFLAGS='-g -O2 -fdebug-prefix-map=/build/gcc-avr-cb8hC_/gcc-avr-5.4.0+Atmel3.6.1=. -fstack-protector-strong' FFLAGS='-g -O2 -fdebug-prefix-map=/build/gcc-avr-cb8hC_/gcc-avr-5.4.0+Atmel3.6.1=. -fstack-protector-strong' GCJFLAGS='-g -O2 -fdebug-prefix-map=/build/gcc-avr-cb8hC_/gcc-avr-5.4.0+Atmel3.6.1=. -fstack-protector-strong' LDFLAGS='-Wl,-Bsymbolic-functions -Wl,-z,relro' OBJCFLAGS='-g -O2 -fdebug-prefix-map=/build/gcc-avr-cb8hC_/gcc-avr-5.4.0+Atmel3.6.1=. -fstack-protector-strong -Wformat ' OBJCXXFLAGS='-g -O2 -fdebug-prefix-map=/build/gcc-avr-cb8hC_/gcc-avr-5.4.0+Atmel3.6.1=. -fstack-protector-strong -Wformat '
    Thread model: single
    gcc version 5.4.0 (GCC)
    I searched and found this reference:
    https://github.com/arduino/Arduino/w...sked-Questions
    which says :
    A: The latest avr-gcc compiler (used by Arduino 1.6.x) requires that variables in PROGMEM to be declared as const.
    So I added const... Seems to compile:
    blinky$ diff usb_debug_only.c usb_debug_only.c-original
    96c96
    < const static uint8_t PROGMEM device_descriptor[] = {
    113c113
    < const static uint8_t PROGMEM hid_report_descriptor[] = {
    128c128
    < const static uint8_t PROGMEM config1_descriptor[CONFIG1_DESC_SIZE] = {
    175c175
    < const static struct usb_string_descriptor_struct PROGMEM string0 = {
    180c180
    < const static struct usb_string_descriptor_struct PROGMEM string1 = {
    185c185
    < const static struct usb_string_descriptor_struct PROGMEM string2 = {
    198c198
    < } const PROGMEM descriptor_list[] = {
    I was able to compile a hex file and load it.. unfortunately, I don't know Morse code... so I'm not sure if the blink pattern is correct. :-P
    actually, I do have another issue.. the MCU listed in the Makefile.. not supported for Teensy3.2
    # MCU name, you MUST set this to match the board you are using
    # type "make clean" after changing this, so all files will be rebuilt
    #MCU = at90usb162       # Teensy 1.0
    MCU = atmega32u4        # Teensy 2.0
    #MCU = at90usb646       # Teensy++ 1.0
    #MCU = at90usb1286      # Teensy++ 2.0
    #MCU = MK20DX256      # Teensy++ 2.0
    I guess I must use Teensyduino only ?
    Germany
    540
    You are compiling with the wrong compiler (avr-gcc) and for a wrong controller (mmcu=atmega32u4). This can not run on a Teensy 3.2. Don't know where you have the makefile from but it is definitely not the right one. Best to first install a standard development environment (Arduino IDE + Teensyduino) and switch to other build systems if the first works...
    Edit: The line
    is the right controller (Teensy 3.2) the comment seems to be wrong, you can try if that works.
