Results 1 to 5 of 5
Thread: SD card speed on Teensy 4.0 vs. Audio Board
    Mar 2019
    Hoboken, New Jersey, USA
    63
    Is there a difference in read/write speed of SD card between the one soldered directly onto Teensy 4.0 vs. one on the new Audio Board?
    I'd like to use the one on Teensy 4.0, but I also need the USB host contacts and using them both doesn't seem to be possible.
    Will I be able to record audio from the Audio Board onto it's SD card? At what rate?
    Thank you.
    3,316
    Quote Originally Posted by Andy Belov View Post
    Thank you.
    Well the Teensy 4.0 does not come with a SD card soldered on to it. You have to do the soldering. On the beta units, Paul's breakout board for the Teensy 3.x audio shield brought out both SD card and the USB host pins. In addition, the other two breakout boards announced both have the SD card and USB broken out.
    In terms of speed, the audio shield only has a single data bit, while the boards connected to the 1mm pins underneath the Teensy 4.0 have 4 pins to send data in parallel. So it should be much faster.
    Mar 2019
    63
    Appreciate the response, Michael.
    I guess the short answer is "4 times faster", but "paint in the neck, if you can't afford the breakout board due to size constraints and need the host USB".
    I really wish for Teensy 4.1 to have the 2 USB host contacts not under the SD card.
    I'm getting my new Audio Board today or tomorrow and will check the recording speed on it.
    Will report.
    271
    Will report.
    I recently released SdFat-beta with support for the Teensy 4.0 uSDHC pins.
    Here are results for the bench example using uSDHC. About 22 MB/sec read write.
    FILE_SIZE_MB = 5
    BUF_SIZE = 512 bytes
    write speed and latency
    speed,max,min,avg
    KB/Sec,usec,usec,usec
    21834.06,3014,22,23
    22026.43,52,22,22
    read speed and latency
    speed,max,min,avg
    22624.43,133,22,22
    22624.43,1096,22,22
    Here is SPI assuming the uSD is the only SPI device. About 3.7 MB/sec.
    FILE_SIZE_MB = 5
    speed,max,min,avg
    3728.56,4615,136,137
    3736.92,152,136,136
    speed,max,min,avg
    3759.40,137,135,136
    3765.06,137,135,135
    Here is SPI assuming the uSD shares SPI with another device. About 470 KB/sec write and 1006 KB/sec read.
    FILE_SIZE_MB = 5
    speed,max,min,avg
    476.96,18551,196,1073
    469.57,20260,196,1090
    speed,max,min,avg
    1006.04,1865,371,508
    1012.56,1830,371,505
    This is with a transfer size of 512 bytes. Shared SPI speed will be greater with larger transfers.
    Mar 2019
    63
    Thanks for sharing, Bill.
    What a dramatic difference!
    I guess I'll design my board for soldering Teensy 4 so that I can use both the USB host port and the on-board SD reader.
    Looks like it was already done.
