lerxstrulz
Yesterday I posted a question about getting a PCA9685 working with Teensy 3.2 : https://forum.pjrc.com/threads/57819-Teensy-3-2-and-Adafruit-PCA9685
I decided to just pull the PCA9685 out of the equation for now and run the servos (there are only 4) directly. I had them working using the PWMServo library and using pins 3,4,5,6 and then all of a sudden they just stopped. I have replaced the Teensy 3.2 with another one thinking maybe I messed something up there, swapped out the servos, checked power (servos are powered externally from 6V) and connections with a meter. For debugging I am powering the Teensy through USB. I am NOT using VIN for power.
Thinking it might be something in my code I loaded up the sweep example that comes with Teensyduino, connected a single servo to pin 3 as before, powered by external 6V (checked with meter) pos and ground, signal wire continuity checked out with meter...and...nothing.
Is there some secret sauce? Something little I'm missing? Trying to figure out how it was all working before and now can't even get a simple demo sketch to work. Feeling a bit perplexed at this point
I also connected the ground of the servos to the Teensy ground according to https://www.pjrc.com/teensy/td_libs_Servo.html, but no luck.
Thoughts?
Thank you!
Just for reference, here is the simple sketch (this is for a continuous rotation servo):
Thoughts?
Thank you!
#include <PWMServo.h>
PWMServo myservo;
myservo.attach(3);
myservo.write(100);
