Page 4 of 4 FirstFirst ... 2 3 4
Results 76 to 88 of 88
Thread: Future Teensy features & pinout
  1. #76
    Jun 2017
    4
    I've a lot of 3.6 devices (hundreds) out whose computation power is used at their limit, so they need to run with single precision instead of double precision for most of their matrix operations.
    I actually use 5 out of 6 serial ports and my desire is to have almost the same pinout for serial ports than 3.6.
    Definitely, I wold like:
    1) Teensy 3. 5/6 pinout compatibility (as much as possible) and same PCB size.
    2) MicroSD socket.
    P.S.: Any possibility to have a wifi module on a future 4.x board?
  2. #77
    May 2015
    San Francisco
    175
    I meant to suggest this earlier: pads on the bottom to provide access to the USB connector data pins. This allows for a design that has its own USB port for power/programming (USB-C anyone?)
  3. #78
    3,309
    I must admit that as we've had multiple threads about various castlelated pins and board extensions, it would be nice if there was an easier method for getting to the underneath pads with breakout boards. Particularly ones that can be easily manufactured. Perhaps having all of the pins in 0.1" (2.54mm) pitch so that we could use pogo pins or perhaps SMT pins like loglow/talldog used for the earlier Teensy breakouts.
  4. #79
    3,309
    Quote Originally Posted by blackketter View Post
    Unfortunately, Paul has said that was a design choice due to wanting to run at USB 2.0/HI speed (480 Mbps) instead of USB 1.2/Full speed (12 Mbps) that the previous Teensys ran at. Evidently there was too much electrical interference if the pads were exposed.
  5. #80
    Aug 2016
    132
    Robin deserves a lot of the credit. She does quite a lot of "infrastructure" stuff that makes everything else possible.
    so she is the glue that holds the whole thing together?
  6. #81
    Mar 2017
    Canada
    245
    FORM FACTOR - keeping the T3.6 form factor would be great
    RAM - adding a big chunk of reasonably fast ram would be ideal. A single HyperRAM chip on board would be my suggestion in 64Mbit or 128Mbit variety. This will boost the BOM quite a bit so I think you might need to introduce two SKUs here where the RAM chip is not populated for very cost sensitive buyers who don't need the extra RAM. The FlexSPI memory mapping is pretty cool, but that's still some really slow RAM when compared to proper program memory. SPI RAM is best for certain types of data (LUTs) or low-speed streaming (like audio).
    CODEC - I really don't think having a codec on board is a good idea. While Audio is a huge user base for Teensy, it's also a very picky group who need to tailor their CODEC selection and preamp design to their particular needs. I know an SGTL5000 is inexpensive but I'm sure a lot of people don't want to pay for it on the BOM.
    SD Card - I don't use it personally on T3.6 but it always seemed to add a lot of value for very little BOM cost, really just costing PCB space more than anything else. Layout-wise, if it came down to the choice of a MicroSD card or space for an optional HyperRAM, I'd take the RAM.
  7. #82
    20,682
    Does anyone make HyperRAM other than Cypress? So far, all their chips I've seen are quite expensive.
  8. #83
    Mar 2017
    Canada
    245
    ISSI is probably the cheapest alternative (well, a little bit cheaper than Cypress) ignoring all the Chinese-only market stuff. You can get 64Mbit for about $5 USD in production quantities. Would I recommend it being on every T4.1? No, that's a steep BOM price increase if the customer doesn't need it. However, my personal experience with edge devices is when the customer needs more RAM, it's a show-stopper so they're willing to pay a big premium. Hobbyists facing BGA only parts will also be highly motivated.
    That's why I recommend a dual SKU with populated vs unpopulated. For an extra 8Mbytes of medium speed (compared to OCM and SPI) I think a lot of customer wouldn't hesitate to pay a $10 to $20 premium because so far the alternative for larger RAM requires is to go overkill with an Rpi (which is no where near as easy and simple to use as a Teensy)
    Dual SKU might also open the flood-gates of people wanting all kind of customizable options which I don't think will work well with the lean business of PJRC, but RAM is such a common issue this would be the one exception I could see it making a large positive impact.
  9. #84
    20,682
    Is HyperRAM really worth so much more than QSPI in hobbyist-frields SOIC8 packages? Sure, it's 8 bits & DDR, where QSPI is 4 bits and only on the rising edge of the clock. Either way, you're waiting a long time for a cache miss. Or is there something I've missed about HyperRAM?
  10. #85
    Mar 2017
    Canada
    245
    I don't think you're missing anything. Memory comes down capacity, latency and throughput (let's ignore power for now). So I guess it comes down to how much of your customer base needs something better than QSPI to justify the recurring costs in time, labour, parts to your business vs. the profit?
    - QSPI capacity is limited to about 512 Kbyte right now. Common HyperRAM is 8 Mbytes to 32 MBytes (64 to 256 Mbit)
    - Throughput is a big difference. QSPI is typically 40 MHz max, so max bandwidth is 40x4 = 160 Mbit/s = 20 Mbytes per second. HyperRAM is typically 100 or 166 MHz DDR 8-bit so 200/333 Mbytes/sec
    - latency on a cache miss would need to be characterized but for very small reads (one L1 cache line) the latency might be similar, HyperRAM could be faster but I won't go as far as say that. For larger transfers the increased speed starts to payoff much more.
    Back to power (per bit of storage, HyperRAM uses far less power than SPI SRAM because the former is DDR under the hood but handles the refresh for you.)
  11. #86
    Dec 2016
    18
    If it is to express wishes ... I am a user who uses this type of plates to build one or another gadget with TFT's, I have reached the point of requiring a plate that in addition to speed, is compact, with enough pins and friendly in the arduino environment.
    I support the idea of ​​accessing a microSD reader in 4-bit mode, even if they are only solder pads, it is possible to manage to connect a reader there, you just have to have a lot of patience and surgeon's pulse!
  12. #87
    That's me sold on HyperRAM. How about RAM as an add-on daughter board? This would also allow pads to be placed on the T4 under the RAM board.
  13. #88
    20,682
    Quote Originally Posted by Blackaddr View Post
    8 MByte QSPI RAM chips are made by Chinese companies. I recently bought some for testing.
    Yes, HyperRAM is faster. But I'm skeptical it's worthwhile for most uses. Also from a business point of view, I'm reluctant to go much higher on cost when the market is filled with products like Raspberry Pi and ESP32.
