Power_Broker
As part of one of my personal projects, I decided to write a library to transfer UART serial data in a fast and reliable manner.
This library (SerialTransfer.h):
It can be found in the Arduino Library Manager (see attached screenshot) or at https://github.com/PowerBroker2/SerialTransfer
Here is an example set of Arduino sketches:
TX Arduino:
RX Arduino:
- is non blocking
- uses packet delimiters
- uses consistent overhead byte stuffing
- uses cyclic redundancy checksums
- allows the use of dynamically sized packets (packets can have payload lengths anywhere from 1 to 255 bytes)
TX Arduino:
#include "SerialTransfer.h"
SerialTransfer myTransfer;
Serial1.begin(115200);
myTransfer.begin(Serial1);
myTransfer.txBuff[0] = 'h';
myTransfer.txBuff[1] = 'i';
myTransfer.txBuff[2] = '\n';
myTransfer.sendData(3);
RX Arduino:
int8_t result = myTransfer.available();
if(result == NEW_DATA)
Serial.println("New Data");
for(byte i = 0; i < 3; i++)
Serial.write(myTransfer.rxBuff[i]);
else if((result != NO_DATA) && (result != CONTINUE))
Serial.print("ERROR: ");
Serial.println(result);
