Page 2 of 2 FirstFirst 1 2
Results 26 to 45 of 45
Thread: I2C Slave on Teensy 4
  1. #26
    Sep 2019
    11
    Hi Richard,
    I' m converting a system for noise measurement from Teensy 3.6 to Teensy 4.0. The system uses the Teensy to read the input from a microphone and calculate the SPL and some more values and than transmits these values over IC to a master (in my case a NodeMCU - ESP8266 system). The Teensy 3.6 system uses the Wire lib and all works well.
    For Teensy 4.0 I found your lib supporting slave mode and tried it. Well I have the problem that there are sporadically errors in the IC transmission. To catch the problem I used your examples which worked fine. Than I changed the number of transmitted bytes from master to slave and vice versa to 31 bytes. Based on your recommendation not to use the Wire API I switched to the i2c_driver.h API but still getting sporadically errors in the transmission from slave to master.
    Any hint what is going wrong is apprtiated.
    Code for slave and master follows as well as some pictures showing the errors in transmisson.
    Slave:
    // Wire Slave Receiver
    // by Nicholas Zambetti <http://www.zambetti.com>
    // Modified by Richard Gemmell Oct 2019
    // Demonstrates use of the Wire library
    // Receives data as an I2C/TWI slave device
    // Refer to the "Wire Master Writer" example for use with this
    // To use it, connect a master to the Teensy on pins 18 and 19.
    // Consider using the I2CRegisterSlave class instead of Wire to
    // create an I2C slave.
    // Created 29 March 2006
    #include <Arduino.h>
    #include <i2c_driver.h>
    #include "imx_rt1060/imx_rt1060_i2c_driver.h"
    uint8_t number_bytes;
    uint8_t i;
    uint8_t ii;
    const uint16_t slave_address = 0x0055;
    I2CSlave& slave = Slave;
    void after_receive(int size);
    void before_transmit_isr();
    void after_transmit();
    const size_t slave_rx_buffer_size = 64;
    uint8_t slave_rx_buffer[slave_rx_buffer_size] = {};
    volatile size_t slave_bytes_received = 0;
    // Set up transmit buffer
    const size_t slave_tx_buffer_size = 64;
    uint8_t slave_tx_buffer[slave_tx_buffer_size] = {};
    // Flags for handling callbacks
    volatile bool before_transmit_received = false;
    volatile bool after_transmit_received = false;
    volatile bool buffer_underflow_detected = false;
    int led = LED_BUILTIN;
      pinMode(led, OUTPUT);
      digitalWrite(led, LOW);
      Serial.begin(115200);           // start serial for output
      Serial.println(" "); Serial.println("IC slave mode communication test on Teensy 4.0");
      // Configure I2C Slave and Start It
      slave.after_receive(after_receive);
      slave.set_receive_buffer(slave_rx_buffer, slave_rx_buffer_size);
      slave.before_transmit(before_transmit_isr);
      slave.after_transmit(after_transmit);
      slave.set_transmit_buffer(slave_tx_buffer, slave_tx_buffer_size);
      slave.listen(slave_address);
      if (slave_bytes_received) {
        // now copy to transmit buffer
        memcpy(slave_tx_buffer, slave_rx_buffer, slave_bytes_received);
    //    Serial.print("loop: slave_bytes_received "); Serial.print(slave_bytes_received);
    //    Serial.print(", last byte transmitted: ");
        Serial.println(slave_rx_buffer[30]);
        // Clear slave_bytes_received to signal that we're ready for another message
      if (before_transmit_received) {
    // Called by the I2C interrupt service routine.
    // This method must be as fast as possible.
    // Do not perform IO in it.
    void after_receive(int size) {
      // This is the only time we can guarantee that the
      // receive buffer is not changing.
      // Copy the content so we can handle it in the main loop.
      if (!slave_bytes_received) {
        slave_bytes_received = size;
        digitalWrite(led, LOW);       // briefly flash the LED
      // else ignore this message because the main loop hasn't
      // handled the previous one yet.
    // Called by an interrupt service routine.
    // This function must be _very_ fast. Avoid IO.
    void before_transmit_isr() {
        before_transmit_received = true;
    void after_transmit() {
        digitalWrite(led, HIGH);       // briefly flash the LED
        after_transmit_received = true;
        if (slave.has_error()) {
            I2CError error = slave.error();
            if (error == I2CError::buffer_underflow) {
                buffer_underflow_detected = true;
                Serial.println("Unexpected error");
    Master:
    // define pins for I2C for NodeMCU
    #define I2C_PIN_SCL D4
    #define I2C_PIN_SDA D3
    uint8_t i = 0;
    uint8_t ii = 0;
    byte buf [64] = {0x78, 0x20, 0x69, 0x73, 0x20, 0x78, 0x20, 0x69, 0x73, 0x20, 0x78, 0x20, 0x69, 0x73, 0x20, 0x78, 0x20, 0x69, 0x73, 0x20, 0x78, 0x20, 0x69, 0x73, 0x20, 0x78, 0x20, 0x69, 0x73, 0x20};
    byte *buf_zeiger = &buf[0];
    uint32_t error_counter = 0;
    uint32_t loop_counter = 0;
      Wire.begin(I2C_PIN_SDA, I2C_PIN_SCL); // join i2c bus (address optional for master)
      Serial.println(" "); Serial.println(" "); Serial.println(" ");
      Serial.println("IC communication test runnig");
      Serial.print("tx: x is "); Serial.print(i);
      Wire.beginTransmission(0x55); // transmit to device 0x55
      buf[30] = i;
      ii = Wire.write(buf_zeiger, 31);        // sends 31 bytes
      if (ii == 31) {
        // all bytes send
        ii = Wire.endTransmission();    // stop transmitting
        if (ii != 0) error_counter++;
        //  Serial.print(", return value of endTransmission: "); Serial.print(ii);
        i++;
        ii = 0;
        Wire.requestFrom(0x55, 31);    // request 31 bytes from slave device 0x55
        Serial.print(", rx: ");
        while (Wire.available()) { // slave may send less than requested
          char c = Wire.read(); // receive a byte as character
          if (ii < 30) {
            Serial.print(c);         // print the character
            if (c != buf[ii]) error_counter++;
            Serial.print(int(c));
          ii++;
        Serial.print(", error_counter: "); Serial.print(error_counter);
        if (error_counter != 0) {
          Serial.print("error_counter: "); Serial.print(error_counter);
          Serial.print(", loop_counter: "); Serial.print(loop_counter);
          while (1) {
        loop_counter++;
        //  Serial.print(", loop_counter: "); Serial.print(loop_counter);
        delay(150);
        // something went wrong
        Wire.endTransmission(); // stop transmission an start again
        Serial.print(" error, # bytes send: "); Serial.print(ii);
    Some pictures:
ID:	19292Click image for larger version.
ID:	19293Click image for larger version.
    Regards,
    Helmut
  2. #27
    Oct 2018
    London
    61
    I couldn't see how to perform asynchonous writes as master, so I added a few extra functions to i2c_driver_wire.cpp to enable me to do it:
     * Starts a transaction with the slave at the given address and blocking status.
     * Setting blocking true forces polling until the previous command completes.
     * Setting non-blocking, returns false when the previous command not yet completed.
     * This allows the whole transaction to be skipped for non-vital data updates.
     * @param addr the IIC slave address to use.
     * @param blocking whether to use a blocking or non-blocking call.
     * @return whether to continue the transaction or not.
    bool I2CDriverWire::beginTransmission(const uint8_t addr, bool blocking) {
        if (master.finished()) {
            write_address = (uint16_t)addr;
            tx_next_byte_to_write = 0;
            return true;
        } else if (blocking) {
            complete(); // Wait until complete //
            return true;
            return false;
     * Waits for transaction completion or timeout (blocking).
    void I2CDriverWire::complete() {
        while ((int)millis() < final_time) { // 200 ms timeout //
                return;
            yield(); // Good idea? //
        //Serial.println("Timed out waiting for transfer to finish.");
     * Asynchronous write operation.
    void I2CDriverWire::sendTransmission() {
        master.write_async(write_address, tx_buffer, tx_next_byte_to_write, true);
        final_time = (int)millis() + timeout_millis; // Record start time for timeout check //
    // Added to allow existing code to be ported more readily //
    void I2CDriverWire::setSDA(uint8_t sda) {
        // Conforms to Teensy standards //
    void I2CDriverWire::setSCL(uint8_t scl) {
    // ---------- Header ---------- //
    void setSDA(uint8_t);
    void setSCL(uint8_t);
    bool beginTransmission(const uint8_t addr, bool blocking);
    void complete();
    void sendTransmission();
    When using asynchronous transfer, all data transmissions must use the overloaded beginTransmission(address, blocking). The blocking parameter determines how to respond if the previous operation has not yet completed:
    - blocking (true): wait until complete then continue the transmission.
    - blocking (false): skip this transmission (useful for non-essential display updates etc).
    if (wptr->beginTransmission(0x70, true)) {
        wptr->write((uint8_t)0x00); // Write data here //
        wptr->sendTransmission(); // Asynchonous transmission //
    Does that seem like a good approach?
    Also, just wondering whether the polling for completeness could call yield() to help other processes while waiting?
    Wish List: Ultra Fast Mode (UFm) would be great!
    Thanks,
    microderm
  3. #28
    I apologise for not responding to the latest posts. It turns out I hadn't subscribed to the thread. I'll get back to both of you soon.
    To anyone posting in the future, please note that I don't monitor the PJRC forums. If you ask for help with my library and I don't reply in a day or two then I probably haven't noticed that you want help. Please send me an email via this forum or GitHub to get my attention.
    cheers,
    Richard
  4. #29
    Hi hbit,
    The output you've posted suggests that individual bits are being corrupted during transmission. This is probably a hardware problem of some kind.
    The most likely hardware problem when changing from a Teensy 3.6 to a Teensy 4 implementation is the pull up resistors. I think people often used 4.7k resistors with Teensy 3s but that's too high for a Teensy 4. You need to use 2.2 kOhm or 1 kOhm resistors instead. Other than that, make sure the 2 devices have a good common ground and that the wiring is sound. I expect you've already done that though.
    If you're still having hardware problems then you may have some subtle electrical or electronic issue. I don't know enough about the hardware side to offer you any advice about that.
    The most common software problem is a race condition involving the main loop and event handlers. The problem is that the Teensy will interrupt almost any code in loop() in order to handle I2C. Note that I2C transmissions aren't atomic. The Teensy may start a function call in loop(), then receive a byte or two, then continue with the same function call in loop(), then receive another byte etc.
    I think there's a bug like that in the slave code you posted. It's possible that the contents of slave_rx_buffer are changing in the middle of the call to memcpy() on line 73. Likewise, the slave could be transmitting during the call to memcpy(). If this happens then the master will receive part of one message and part of the next one.
    I think the best solution would be to move the call to memcpy from loop() into before_transmit_isr. This works because the before_transmit event handler is called just before the slave starts transmitting to the master. At this point, we know that the master is no longer transmitting to the slave so slave_rx_buffer should not be changing. e.g.
    It's not ideal to call Serial.println() in an event handler but you'll probably get away with it. Don't forget to remove the memcpy code from loop().
    For anyone else reading this please check out the list of common problems.
    I hope this helps.
    Richard.
  5. #30
    Hi microderm,
    The "real" API for my library is the one in i2c_driver.h. This is inherently asynchronous and should lend itself well to this sort of problem. See I2CMaster::write_async() and I2CMaster::finished(). You might not even need the equivalent of complete() if you're really interested in whether you can start a transaction rather than deliberately waiting for one to finish.
    I created I2CDriverWire so that people who prefer the existing Wire library would have a drop in replacement. It's also handy for people porting existing code. Wire doesn't support the sort of behaviour you want which is why you had to create these new methods. I'm reluctant to modify of extend the Wire implementation as I would prefer people to use i2c_driver.h when Wire isn't sufficient. I also want to avoid creating an implementation of Wire which has a different flavour to the reference implementation.
    Having said all that, your approach seems like a perfectly reasonable way to get the behaviour you want. The example code you give is neat and tidy which is always a good sign.
    I believe your code contains a bug or two. The problem is that millis() will sometimes return a value close to the max_int. When that happens this line
    can produce a number less than the current value of mills() causing complete() to return immediately without calling master.finished(). This is why I2CDriverWire::finish() uses elapsedMillis().
    I wasn't aware of the scheduler library and yield() so I don't have any experience with using it. Your suggested use seems like a good place to call yield(). Of course, it won't matter unless you have additional processes to yield to.
    To loop round to where I started, I'd suggest having a go at writing your extension with I2CMaster on it's own without I2CDriverWire. You may well be able to come up with an implementation which avoids blocking at all.
    I shied away from implementing Ultra Fast Mode because it looks fairly complicated and I didn't need it. If your needs ever change from "nice to have" to "must have" then please raise an issue on github. I might be inspired to have a go particularly if other people want it too.
    cheers,
    Richard
  6. #31
    Sep 2019
    11
    Hi Richard,
    thanks for the suggestions. I need 2 - 3 days and come back then.
    Regards,
    Helmut
  7. #32
    Sep 2019
    11
    Hi Richard,
    one of your suggestions made me a bit curious, changing the pull up to 1k. Just for intrest I tried it and it got even worse. So I looked into the pin configuration and found that the internal pull ups are enabled (PUS(3) - 22k). If it's enabled on both sides that gives 11k what should be o.k. for standard I2C speed of 100 kHz and a short distance. After playing a bit with DSE, SRE I tried the hysteresis bit (HYS) and that changed the situation. With HYS sat the testprogram was running for some hours transferring 31 bytes back anf forth without any error (something I expect for a standard IC connection).
    imx_rt1060_i2c_driver.cpp looks now
    // Copyright  2019 Richard Gemmell
    // Released under the MIT License. See license.txt. (https://opensource.org/licenses/MIT)
    // Fragments of this code copied from WireIMXRT.cpp  Paul Stoffregen.
    // Please support the Teensy project at pjrc.com.
    //#define DEBUG_I2C // Uncomment to enable debug tools
    #ifdef DEBUG_I2C
    #pragma clang diagnostic push
    #pragma ide diagnostic ignored "hicpp-signed-bitwise"
    #include <imxrt.h>
    #include <pins_arduino.h>
    #include "imx_rt1060_i2c_driver.h"
    #define DUMMY_BYTE 0x00 // Used when there's no real data to write.
    #define NUM_FIFOS 4     // Number of Rx and Tx FIFOs available to master
    #define MASTER_READ 1   // Makes the address a read request
    #define MASTER_WRITE 0  // Makes the address a write request
    #define MAX_MASTER_READ_LENGTH 256  // Maximum number of bytes that can be read by a single Master read
    #define PINCONFIG (IOMUXC_PAD_HYS | IOMUXC_PAD_ODE | IOMUXC_PAD_SRE | IOMUXC_PAD_DSE(4) | IOMUXC_PAD_SPEED(1) | IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(3))
    // Debug tools
    #ifdef DEBUG_I2C
    static void log_slave_status_register(uint32_t ssr);
    static void log_master_status_register(uint32_t msr);
    static void log_master_control_register(const char* message, uint32_t mcr);
    static uint8_t empty_buffer[0];
    I2CBuffer::I2CBuffer() : buffer(empty_buffer) {
    static void initialise_pin(IMX_RT1060_I2CBase::PinInfo pin) {
    //    *(portControlRegister(pin.pin)) |= IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(3);
        *(portControlRegister(pin.pin)) = PINCONFIG;
        *(portConfigRegister(pin.pin)) = pin.mux_val;
        if (pin.select_input_register) {
            *(pin.select_input_register) = pin.select_val;
    Would be great if you could recheck it.
    Here are my testprograms for teensy4.0 for Master and Slave side
    Master:
    //#include <Wire.h>
    #include <i2c_driver_wire.h>
    uint8_t i = 0;
    uint8_t ii = 0;
    String input_string = "";
    int number_bytes_tx;
    bool string_complete;
    char ch;
      Wire.begin(); // join i2c bus (address optional for master)
      pinMode(13, OUTPUT);
      Serial.print("input number of bytes for each transmission: ");
      string_complete = false;
      while (!string_complete) {
        while (Serial.available()) {
          // get the new byte:
          char in_char = (char)Serial.read();
          // add it to the inputString:
          input_string += in_char;
          // if the incoming character is a newline, set a flag so the main loop can
          // do something about it:
          if (in_char == '\n') {
            string_complete = true;
      number_bytes_tx = input_string.toInt();
      Serial.println(number_bytes_tx); Serial.println(" ");
      buf[number_bytes_tx - 1] = i;
      ii = Wire.write(buf_zeiger, number_bytes_tx);        // sends x bytes
      if (ii == number_bytes_tx) {
        // all bytes send
        i++;
        delay(1);
        Wire.requestFrom(0x55, number_bytes_tx);    // request x bytes from slave device 0x55
        ii = 0;
          if (ii < number_bytes_tx - 1) {
          ii++;
        //    Serial.print(", # errors: "); Serial.print(error_counter);
          while (1) {
            if ( Serial.available()) SCB_AIRCR = 0x05FA0004;
            digitalWriteFast( 13, !digitalReadFast(13));
        Wire.endTransmission(); // stop transmission and start again
        Serial.print(" error, wrong # bytes send: "); Serial.print(ii);
      loop_counter++;
    Slave:
    uint8_t i;
    uint8_t ii;
      Serial.println(" "); Serial.println("IC Slave Mode Teensy4.0 with lib imx_rt1060_i2c_driver");
        Serial.print("# rx: "); Serial.print(slave_bytes_received); Serial.print(" ");
        Serial.print(slave_rx_buffer[slave_bytes_received - 1]); Serial.print(" ");
      if (after_transmit_received) {
        if (buffer_underflow_detected) {
          Serial.println("App: Buffer Underflow. (Master asked for too many bytes.)");
          Serial.println(" tx ok");
      //    digitalWrite(led, HIGH);       // briefly flash the LED
    Regards,
    Helmut
  8. #33
    Quote Originally Posted by hbit View Post
    Thanks for that. The pin configuration is the one part of the driver that I don't really understand. I wouldn't be at all surprised to learn that I got something wrong. I'll definitely check it out.
  9. #34
    Hi Helmut,
    I've spent the last few days playing around with the pin configuration. I found NXPs documentation which wasn't in the datasheet and I also looked at changes made to the official Teensy Wire implementation.
    The practical upshot of this, is that I've changed the driver to use the config you suggested except that I omitted IOMUXC_PAD_SRE. I've also added API methods so that users can override the default config if necessary without having to modify the driver files. See I2CDriverWire::setPadControlConfiguration(). I've updated the README to explain this as well.
    The long story is that I tested various configurations on my project. This has 2 I2C connections. One to an INA260 current sensor and one to a Raspberry Pi. The Teensy is the master for the first connection and a slave for the second. I've never been able to make the connection to the Pi reliable. I was pretty sure that the problem was down to noise and I finally got the error rate down to about 1 failure in 10,000 messages. To achieve this, I had to add external pullups and rearranged the board to keep noisy lines away from the I2C wires.
    I've looked at each part of the pad config to see what effect it has. I removed the external pullups before testing as I knew that increased the error rate significantly. The only settings that made any noticeable difference were:-
    * the link fails completely if DSE is set to 0
    * enabling the 22k internal resistor reduced the error rate by 15%
    * HYS completely eliminated all errors
    So I believe I've confirmed your finding that enabling IOMUXC_PAD_HYS seems to eliminate errors caused by noise. I decided to copy the other settings from the official Teensy Wire implementation as they work fine with my project and fix other problems. The only exception is that I didn't removed SRE as NXP's documentation says you shouldn't use it unless necessary as it can cause EMC problems.
    Thanks very much for your tip. It's helped enormously.
    Richard
  10. #35
    Sep 2019
    11
    Hi Richard,
    good to hear that it helped to make your communication between Pi and Teensy4 more reliable in a noisy environment. The application note from NXP (AN5078) you found, is definitly information that should have been in the reference manual.
    Regards,
    Helmut
  11. #36
    Hello! All was looking good until I tried to include the audio lib or the lcd lib, it then throws lots of error on compile. here is the code... T4 on 1.52. What can I do? It compiles fine if I remove the includes for the audio or lcd but I need them ; )
    // Wire Slave Sender
    // Sends data as an I2C/TWI slave device
    // Refer to the "Wire Master Reader" example for use with this
    //#include <SerialFlash.h>
    // Screen
    //#include <ILI9341_t3.h>
    //#include "font_Arial.h"
    //#define TFT_DC  5
    //#define TFT_CS 10
    //ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC);
    // alternative wire lib
    void requestEvent();
      Wire.begin(2);        // join i2c bus with address #8
      //Wire.onReceive(receiveEvent); // Receive event
      Wire.onRequest(requestEvent); // Request event
    // function that executes whenever data is requested by master
    // this function is registered as an event, see setup()
    void requestEvent()
      Wire.write("hello ");     // respond with message of 6 bytes
                                    // as expected by master
    // from slave receiver //
    // function that executes whenever data is received from master
    errors...
    /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_127074/libraries/Wire/WireIMXRT.cpp.o:(.data.Wire2+0x0): multiple definition of `Wire2'
    /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_127074/libraries/teensy4_i2c/i2c_driver_wire.cpp.o:(.bss.Wire2+0x0): first defined here
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Disabling relaxation: it will not work with multiple definitions
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire2' changed from 116 in /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_127074/libraries/teensy4_i2c/i2c_driver_wire.cpp.o to 112 in /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_127074/libraries/Wire/WireIMXRT.cpp.o
    /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_127074/libraries/Wire/WireIMXRT.cpp.o: In function `Print::availableForWrite()':
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:235: multiple definition of `Wire1'
    /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_127074/libraries/teensy4_i2c/i2c_driver_wire.cpp.o:/Users/Alex/Documents/Arduino/libraries/teensy4_i2c/src/i2c_driver_wire.cpp:123: first defined here
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire1' changed from 116 in /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_127074/libraries/teensy4_i2c/i2c_driver_wire.cpp.o to 112 in /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_127074/libraries/Wire/WireIMXRT.cpp.o
     Used: /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/SD
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:235: multiple definition of `Wire'
     Not used: /Applications/Ard Teensyduino 1.52.app/Contents/Java/libraries/SD
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire' changed from 116 in /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_127074/libraries/teensy4_i2c/i2c_driver_wire.cpp.o to 112 in /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_127074/libraries/Wire/WireIMXRT.cpp.o
    collect2: error: ld returned 1 exit status
    Error compiling for board Teensy 4.0.
    edit: I have done some reading and I see that I need to change all the includes for Wire.h. is there a way to do this so that it isn't going to break when I next update teensyduino? Also how can i find where it needs changing for example if I include Audio.h it breaks, but there is no mention of Wire.h in Audio.h
    Thanks for any input. A
  12. #37
    Sep 2019
    11
    Hi alrj,
    have you changed all occurences of "#include Wire.h" in the Audio lib and in the lcd lib to "#include <i2c_driver.h> #include <i2c_driver_wire.h>"? You can not use both librarys at the same time.
    Also use the latest version of Richards teensy4_i2c lib.
    Regards,
    Helmut
  13. #38
    Thanks I have realised that is what I need to do but searching Audio.h for wire provided no results.
    edit: i see it shows where the issue is in the readout.
    Also if I go down this route is there a way to avoid loosing all the changes when I update teensyduino? I have also been looking at RichGs alternative i2c implementation in the same lib but I don't really understand it!
  14. #39
    If I do this in WireIMXRT.cpp which is where the error is caused when I add Audio.h
    //#include "Wire.h"
    I get a whole heap of trouble...
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp: In member function 'void I2CDriverWire::begin()':
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:18:2: error: 'hardware' was not declared in this scope
      hardware.clock_gate_register |= hardware.clock_gate_mask;
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:19:2: error: 'port' was not declared in this scope
      port->MCR = LPI2C_MCR_RST;
    In file included from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/cores/teensy4/core_pins.h:33:0,
                     from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/cores/teensy4/wiring.h:39,
                     from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/cores/teensy4/WProgram.h:45,
                     from /var/folders/lm/jj9j_4s516l88sg7hbq9blb00000gp/T/arduino_build_655445/pch/Arduino.h:6,
                     from /Users/Alex/Documents/Arduino/libraries/teensy4_i2c/src/i2c_driver_wire.h:7,
                     from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:4:
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:23:42: error: 'sda_pin_index_' was not declared in this scope
      *(portControlRegister(hardware.sda_pins[sda_pin_index_].pin)) = PINCONFIG;
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/cores/teensy4/pins_arduino.h:141:61: note: in definition of macro 'portControlRegister'
     #define portControlRegister(pin) ((digital_pin_to_info_PGM[(pin)].pad))
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:30:42: error: 'scl_pin_index_' was not declared in this scope
      *(portControlRegister(hardware.scl_pins[scl_pin_index_].pin)) = PINCONFIG;
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp: At global scope:
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:37:6: error: redefinition of 'void I2CDriverWire::begin(uint8_t)'
     void TwoWire::begin(uint8_t address)
    In file included from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:4:0:
    /Users/Alex/Documents/Arduino/libraries/teensy4_i2c/src/i2c_driver_wire.h:98:17: note: 'void I2CDriverWire::begin(uint8_t)' previously defined here
         inline void begin(uint8_t address) { begin((int)address); }
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:46:33: error: no 'void I2CDriverWire::setSDA(uint8_t)' member function declared in class 'I2CDriverWire'
     void TwoWire::setSDA(uint8_t pin) {
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:68:33: error: no 'void I2CDriverWire::setSCL(uint8_t)' member function declared in class 'I2CDriverWire'
     void TwoWire::setSCL(uint8_t pin) {
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:90:27: error: no 'bool I2CDriverWire::force_clock()' member function declared in class 'I2CDriverWire'
     bool TwoWire::force_clock()
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp: In member function 'virtual size_t I2CDriverWire::write(uint8_t)':
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:125:6: error: 'transmitting' was not declared in this scope
      if (transmitting || slave_mode) {
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:125:22: error: 'slave_mode' was not declared in this scope
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:126:7: error: 'txBufferLength' was not declared in this scope
       if (txBufferLength >= BUFFER_LENGTH+1) {
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:126:25: error: 'BUFFER_LENGTH' was not declared in this scope
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:130:3: error: 'txBuffer' was not declared in this scope
       txBuffer[txBufferLength++] = data;
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:130:12: error: 'txBufferLength' was not declared in this scope
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp: In member function 'virtual size_t I2CDriverWire::write(const uint8_t*, size_t)':
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:138:6: error: 'transmitting' was not declared in this scope
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:138:22: error: 'slave_mode' was not declared in this scope
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:139:18: error: 'BUFFER_LENGTH' was not declared in this scope
       size_t avail = BUFFER_LENGTH+1 - txBufferLength;
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:139:36: error: 'txBufferLength' was not declared in this scope
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:144:10: error: 'txBuffer' was not declared in this scope
       memcpy(txBuffer + txBufferLength, data, quantity);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:166:25: error: no 'bool I2CDriverWire::wait_idle()' member function declared in class 'I2CDriverWire'
     bool TwoWire::wait_idle()
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:185:9: error: prototype for 'uint8_t I2CDriverWire::endTransmission(uint8_t)' does not match any in class 'I2CDriverWire'
     uint8_t TwoWire::endTransmission(uint8_t sendStop)
    /Users/Alex/Documents/Arduino/libraries/teensy4_i2c/src/i2c_driver_wire.h:62:13: error: candidate is: uint8_t I2CDriverWire::endTransmission(int)
         uint8_t endTransmission(int stop = true);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:237:9: error: prototype for 'uint8_t I2CDriverWire::requestFrom(uint8_t, uint8_t, uint8_t)' does not match any in class 'I2CDriverWire'
     uint8_t TwoWire::requestFrom(uint8_t address, uint8_t length, uint8_t sendStop)
    /Users/Alex/Documents/Arduino/libraries/teensy4_i2c/src/i2c_driver_wire.h:68:13: error: candidate is: uint8_t I2CDriverWire::requestFrom(int, int, int)
         uint8_t requestFrom(int address, int quantity, int stop = true);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:296:9: error: prototype for 'uint8_t I2CDriverWire::requestFrom(uint8_t, uint8_t, uint32_t, uint8_t, uint8_t)' does not match any in class 'I2CDriverWire'
     uint8_t TwoWire::requestFrom(uint8_t addr, uint8_t qty, uint32_t iaddr, uint8_t n, uint8_t stop)
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:316:20: error: 'I2C_Hardware_t' in 'using TwoWire = class I2CDriverWire {aka class I2CDriverWire}' does not name a type
     constexpr TwoWire::I2C_Hardware_t TwoWire::i2c1_hardware = {
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:322:29: error: 'i2c1_hardware' is not a member of 'TwoWire {aka I2CDriverWire}'
     TwoWire Wire(&IMXRT_LPI2C1, TwoWire::i2c1_hardware);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:325:20: error: 'I2C_Hardware_t' in 'using TwoWire = class I2CDriverWire {aka class I2CDriverWire}' does not name a type
     constexpr TwoWire::I2C_Hardware_t TwoWire::i2c3_hardware = {
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:331:30: error: 'i2c3_hardware' is not a member of 'TwoWire {aka I2CDriverWire}'
     TwoWire Wire1(&IMXRT_LPI2C3, TwoWire::i2c3_hardware);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:334:20: error: 'I2C_Hardware_t' in 'using TwoWire = class I2CDriverWire {aka class I2CDriverWire}' does not name a type
     constexpr TwoWire::I2C_Hardware_t TwoWire::i2c4_hardware = {
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:340:30: error: 'i2c4_hardware' is not a member of 'TwoWire {aka I2CDriverWire}'
     TwoWire Wire2(&IMXRT_LPI2C4, TwoWire::i2c4_hardware);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp: In member function 'void I2CDriverWire::setClock(uint32_t)':
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp:351:2: error: 'port' was not declared in this scope
      port->MCR = 0;
  15. #40
    Quote Originally Posted by alrj
    You need to replace all usages of Wire.h in any library dependencies and not just in the headers that you include. In your case, this means replacing the #include "Wire.h" in each of the control_xxx.cpp files in your hardware\teensy\avr\libraries\Audio directory.
    I don't know anything about how teensyduino does updates but I suspect you'll have to re-apply your changes. You could use copies of the libraries you need but then you wouldn't gain the benefit of any updates.
    If you haven't already found them you might like to have a look at the examples.
    Whichever teensy4_i2c API you use you'll still have to change audio etc to use i2c_driver_wire.h.
    If you're already familiar with the Arduino Wire API and you know that it'll do what you want, then you might be better of sticking with it.
    If you let me know what you're trying to achieve with the I2C part of your project then I'll be happy to suggest which API to use and to provide examples etc.
    If you've never encountered I2C before then the critical thing to understand is that it's a master/slave setup. The master initiates every transfer whether it's sending or receiving. The slave can only react to the master's demands.
    cheers,
    Richard
  16. #41
    Thanks for the reply. I am pretty familiar with the Arduino i2c library but I have never used an arduino/teensy as a slave before. I just want to send trigger messages of a few bytes from one to another.
    I tried to replace "Wire.h" as per the instructions but I got the errors I posted in post #39. what have I done wrong?
    regards, Al.
  17. #42
    Okay So! I have audio working via updating the control elements : ) thank you for your explanation.
    I have now added "#include <ILI9341_t3.h>" for the screen I am using. Here is the code and the errors...
    // Screen
    //#define TFT_DC  5
    //#define TFT_CS 10
    // MOSI=11, MISO=12, SCK=13
    void requestEvent()
      Wire.write("ACK ");     // respond with message of 6 bytes
    /*void receiveEvent(int howMany)
      while(Wire.available() > 1) {  // loop through all but the last
        char c = Wire.read();        // receive byte as a character
      int x = Wire.read();           // receive byte as an integer
      Serial.println(x);             // print the integer
    Errors...
    In file included from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/exception:162:0,
                     from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/typeinfo:34,
                     from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/functional:53,
                     from /Users/Alex/Documents/Arduino/libraries/teensy4_i2c/src/i2c_driver.h:9,
                     from /Users/Alex/Documents/Arduino/slave_sender_working/slave_sender_working.ino:29:
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/exception_ptr.h:118:68: error: macro "swap" requires 2 arguments, but only 1 given
             exception_ptr(static_cast<exception_ptr&&>(__o)).swap(*this);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/exception_ptr.h:126:26: error: macro "swap" requires 2 arguments, but only 1 given
           swap(exception_ptr&) _GLIBCXX_USE_NOEXCEPT;
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/exception_ptr.h:161:23: error: macro "swap" requires 2 arguments, but only 1 given
         { __lhs.swap(__rhs); }
    In file included from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/string:52:0,
                     from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/stdexcept:39,
                     from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/array:38,
                     from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/tuple:39,
                     from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/functional:55,
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.h:1953:29: error: macro "swap" requires 2 arguments, but only 1 given
           swap(basic_string& __s) _GLIBCXX_NOEXCEPT;
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.h:5218:47: error: macro "swap" passed 6 arguments, but takes just 2
       basic_string<_CharT, _Traits, _Alloc>& __rhs)
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.h:5220:39: error: macro "swap" requires 2 arguments, but only 1 given
         noexcept(noexcept(__lhs.swap(__rhs)))
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.h:5222:23: error: macro "swap" requires 2 arguments, but only 1 given
    In file included from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/string:53:0,
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/bits/basic_string.tcc:59:27: error: macro "swap" requires 2 arguments, but only 1 given
    In file included from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/tuple:39:0,
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/array:115:26: error: macro "swap" requires 2 arguments, but only 1 given
           swap(array& __other)
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/array:274:56: error: macro "swap" passed 4 arguments, but takes just 2
         swap(array<_Tp, _Nm>& __one, array<_Tp, _Nm>& __two)
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/array:275:39: error: macro "swap" requires 2 arguments, but only 1 given
         noexcept(noexcept(__one.swap(__two)))
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/array:276:23: error: macro "swap" requires 2 arguments, but only 1 given
         { __one.swap(__two); }
    In file included from /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/functional:55:0,
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/tuple:580:23: error: macro "swap" requires 2 arguments, but only 1 given
           swap(tuple& __in)
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/tuple:590:23: error: macro "swap" requires 2 arguments, but only 1 given
           void swap(tuple&) noexcept { /* no-op */ }
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/tuple:740:23: error: macro "swap" requires 2 arguments, but only 1 given
           swap(tuple& __in)
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/tuple:1133:35: error: macro "swap" requires 2 arguments, but only 1 given
         noexcept(noexcept(__x.swap(__y)))
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/tuple:1134:19: error: macro "swap" requires 2 arguments, but only 1 given
         { __x.swap(__y); }
    In file included from /Users/Alex/Documents/Arduino/libraries/teensy4_i2c/src/i2c_driver.h:9:0,
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/functional:2030:16: error: macro "swap" requires 2 arguments, but only 1 given
      __x.swap(*this);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/functional:2071:26: error: macro "swap" requires 2 arguments, but only 1 given
      function(__x).swap(*this);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/functional:2089:37: error: macro "swap" requires 2 arguments, but only 1 given
      function(std::move(__x)).swap(*this);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/functional:2132:52: error: macro "swap" requires 2 arguments, but only 1 given
        function(std::forward<_Functor>(__f)).swap(*this);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/functional:2141:28: error: macro "swap" requires 2 arguments, but only 1 given
        function(__f).swap(*this);
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/functional:2154:30: error: macro "swap" requires 2 arguments, but only 1 given
           void swap(function& __x)
    /Applications/Ard Teensyduino 1.52.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/c++/5.4.1/functional:2370:19: error: macro "swap" requires 2 arguments, but only 1 given
         { __x.swap(__y); }
    No files were added to the sketch.
  18. #43
    The problem is that both ILI9341_t3.h and <functional> define swap. I can get it to compile by including ILI9341_t3.h after i2c_driver_wire.h like this:-
    The problem may re-appear as you add more code to your project.
  19. #44
    I managed to get my code to compile using the Adafruit TFT lib but whenever I called playwav it would hang unless I commented out wire begin so I have admitted defeat and I will use UART. Thanks for your help, it is very much appreciated
  20. #45
    Thanks for letting me know. Good luck.
