#include <WS2812Serial.h>
#define USE_WS2812SERIAL
#include <FastLED.h>
#include <IRremote.h>
#define NUM_LEDS 432
#define SEGMENTLAENGE 25
#define SEGMENTE 17
//#define SEGMENTLAENGE 432
//#define SEGMENTE 1
#define IRRECEIVE_PIN 2
// Usable pins:
// Teensy LC: 1, 4, 5, 24
// Teensy 3.2: 1, 5, 8, 10, 31 (overclock to 120 MHz for pin 8)
// Teensy 3.5: 1, 5, 8, 10, 26, 32, 33, 48
// Teensy 3.6: 1, 5, 8, 10, 26, 32, 33
#define NEOPIXEL_PIN 8
int static Programmnummer = 6;
int static Anzahl_der_Programme = 2;
int static Stopp = -1; // -1 = Stopp, 1 = Run
int static Pause = -1; // -1 = Pause, 1 = Run
int static Abbruch = 0;
int static Helligkeitsfaktor=2;
int static IR_gelesen = 0;
int static Geschwindigkeitsquotient = 5;
void (*Effektprogramme[])() = {&Matrix_fluessig, &DMT, &Blitzen, &Wanderpixel, &Regenbogen, &Strobo, &Boom};
IRrecv IrReceive(IRRECEIVE_PIN);
decode_results IR_Result;
CRGBArray<NUM_LEDS> leds;
CRGB* LEDs[SEGMENTE];
//typedef void (*f)(void);
//Alternative Initialisierung des Function Arrays
//f Effektprogramme[] = {&Matrix_fluessig, &DMT};
int i;
IrReceive.enableIRIn(); // Start the receiver
//FastLED.addLeds<NEOPIXEL,NEOPIXEL_PIN>(leds, NUM_LEDS);
//LEDS.addLeds<WS2812SERIAL,NEOPIXEL_PIN,RGB>(leds,NUM_LEDS);
LEDS.addLeds<WS2812SERIAL,NEOPIXEL_PIN,BRG>(leds,NUM_LEDS);
for (i = 0; i < SEGMENTE; i++)
LEDs[i] = &leds[i*SEGMENTLAENGE];
//Serial.println("Mainloop");
CheckIR();
if (Abbruch == 1 && Stopp == 1) {Abschalten(); Pause = 1;}
Abbruch = 0;
//Serial.print("Programmnummer = "); Serial.println(Programmnummer);
if (Stopp == -1) {Effektprogramme[Programmnummer]();}
delay(50);
void Matrix_fluessig()
int i[SEGMENTE] = {0};
//int Leuchten[SEGMENTE];
int Schweiflaenge[SEGMENTE];
int Helligkeit[SEGMENTE] = {0};
int Shiftdirection[SEGMENTE] = {0};
Serial.println("Starte Matrix fluessig");
Geschwindigkeitsquotient = 7;
// Shiftdirection[1]=1;
// Shiftdirection[3]=1;
// Shiftdirection[5]=1;
// Shiftdirection[7]=1;
// Shiftdirection[9]=1;
// Shiftdirection[11]=1;
// Shiftdirection[13]=1;
// Shiftdirection[15]=1;
while (true) {
if (Abbruch == 1)
Serial.println("Abbruchanforderung registriert, Breche Matrix-Loop ab");
for (int Segmentnummer = 0; Segmentnummer < SEGMENTE; Segmentnummer++)
if ((Helligkeit[Segmentnummer] == 0) && (random(1,10) > 8)) {Helligkeit[Segmentnummer] = 255; i[Segmentnummer] = 0;}
if (Helligkeit[Segmentnummer] == 255)
Schweiflaenge[Segmentnummer] = random(10,20);
if (Helligkeit[Segmentnummer] > 0)
Helligkeit[Segmentnummer] = 255*(Schweiflaenge[Segmentnummer]-i[Segmentnummer])/Schweiflaenge[Segmentnummer];
i[Segmentnummer]++;
LEDshiftByRef(LEDs[Segmentnummer], Shiftdirection[Segmentnummer]);
//if (Shiftdirection[Segmentnummer] == 0) LEDs[Segmentnummer][0] = CHSV(Segmentnummer*255/SEGMENTE,255,Helligkeit[Segmentnummer]); //Regenbogenvariante
//if (Shiftdirection[Segmentnummer] == 1) LEDs[Segmentnummer][SEGMENTE-1] = CHSV(Segmentnummer*255/SEGMENTE,255,Helligkeit[Segmentnummer]); //Regenbogenvariante
if (Shiftdirection[Segmentnummer] == 0) LEDs[Segmentnummer][0] = CHSV(82,255,Helligkeit[Segmentnummer]);
if (Shiftdirection[Segmentnummer] == 1) LEDs[Segmentnummer][SEGMENTE-1] = CHSV(82,255,Helligkeit[Segmentnummer]);
while(Pause == 1){delay(100); CheckIR();}
CheckIR();
FastLED.setBrightness(pow(4,Helligkeitsfaktor)-1);
FastLED.show();
delay(5000/pow(2,Geschwindigkeitsquotient));
void DMT()
int Segmentnummer;
CHSV Farben[3];
Farben[0] = CHSV(1,255,255);
Farben[1] = CHSV(1,0,255);
Farben[2] = CHSV(82,255,255);
Serial.println("DMT-Programm gestartet");
while (true)
// if (Abbruch == 1)
// Serial.println("Abbruchanforderung registriert, Breche DMT-Loop ab");
// break;
for (int g = 0; g < sizeof(Farben)/3; g++)
if (Abbruch == 1)
Serial.println("Abbruchanforderung registriert, Breche FarbLoop ab");
return;
for (int j = 0; j < SEGMENTLAENGE/2; j++)
for (Segmentnummer = 0; Segmentnummer < SEGMENTE; Segmentnummer++)
CheckIR();
if (SEGMENTLAENGE % 2 == 1)
LEDs[Segmentnummer][(SEGMENTLAENGE+1)/2] = Farben[g];
LEDs[Segmentnummer][(SEGMENTLAENGE+1)/2-1-j] = Farben[g];
LEDs[Segmentnummer][(SEGMENTLAENGE+1)/2+1+j] = Farben[g];
LEDs[Segmentnummer][SEGMENTLAENGE/2-1-j] = Farben[g];
LEDs[Segmentnummer][SEGMENTLAENGE/2+j] = Farben[g];
FastLED.show();
void Wanderpixel()
Geschwindigkeitsquotient = 9;
Serial.println("Wanderpixel gestartet");
Abschalten();
while (true)
for (int i = 0; i <= NUM_LEDS; i++)
CheckIR();
if (Abbruch == 1)
Serial.println("Abbruchanforderung registriert, Breche Wanderpixel ab");
return;
leds[i] = CHSV(1,0,255);
FastLED.show();
leds[i] = CHSV(1,0,0);
void Blitzen()
Serial.println("Blitzen gestartet");
while (true)
if (Abbruch == 1) {return;}
// for (i = 0; i <= NUM_LEDS; i++)
// if (random(1,10) > 5) Helligkeit = 0;
// if (random(1,10) <= 5) Helligkeit = pow(4,random(0,4));
// leds[i] = CHSV(1,0,Helligkeit);
leds[i] = CHSV(1,0,pow(4,random(-20,4)));
CheckIR();
FastLED.show();
void Regenbogen()
Serial.println("Regenbogen gestartet");
while (true)
for (int colorshift = 0; colorshift <= 255; colorshift = colorshift+5)
for (int i = 0; i <= SEGMENTLAENGE; i++)
LEDs[Segmentnummer][i] = CHSV(Diff255(map(i, 0, SEGMENTLAENGE, 0, 255)+colorshift),255,255);
//LEDs[Segmentnummer][i] = CHSV(Diff255(map(i, 0, SEGMENTLAENGE, 0, 255)),255,255);
CheckIR();
FastLED.show();
void Strobo()
Serial.println("Strobo gestartet");
Geschwindigkeitsquotient = 6;
while (true)
FastLED.show();
CheckIR();
FastLED.show();
void Boom()
Serial.println("Boom gestartet");
Abschalten();
while (true)
for (int i = 0; i <= SEGMENTLAENGE/2; i++)
CheckIR();
if (Abbruch == 1)
return;
if (i>0) {LEDs[Segmentnummer][i-1] = CHSV(1,0,0); LEDs[Segmentnummer][SEGMENTLAENGE-i+1] = CHSV(1,0,0);}
LEDs[Segmentnummer][i] = CHSV(1,0,120);
LEDs[Segmentnummer][SEGMENTLAENGE-i] = CHSV(1,0,120);
FastLED.show();
delay(15000/pow(2,Geschwindigkeitsquotient));
LEDs[Segmentnummer][SEGMENTLAENGE/2] = CHSV(1,0,255);
LEDs[Segmentnummer][SEGMENTLAENGE-SEGMENTLAENGE/2] = CHSV(1,0,255);
FastLED.setBrightness(255);
FastLED.show();
delay(30);
for (int i = SEGMENTLAENGE/2+1; i >= 0; i--)
CheckIR();
if (Abbruch == 1)
return;
LEDs[Segmentnummer][i] = CHSV(i*3,255,255);
LEDs[Segmentnummer][SEGMENTLAENGE-i] = CHSV(i*3,255,255);
FastLED.show();
delay(2500/pow(2,Geschwindigkeitsquotient));
CheckIR();
if (Abbruch == 1)
return;
LEDs[Segmentnummer][i] = CHSV(i,255,0);
LEDs[Segmentnummer][SEGMENTLAENGE-i] = CHSV(i,255,0);
FastLED.show();
void CheckIR()
if (IrReceive.decode(&IR_Result))
Serial.println(IR_Result.value);
switch(IR_Result.value)
case 16761405: if (Programmnummer < sizeof(Effektprogramme)/4-1) {Programmnummer++; Serial.print("Programmnummer = "); Serial.println(Programmnummer); Abbruch = 1;} break;
case 16720605: if (Programmnummer > 0) {Programmnummer--; Serial.print("Programmnummer = "); Serial.println(Programmnummer); Abbruch = 1;} break;
case 16753245: Stopp = Stopp * -1; Pause = -1; Serial.print("Stopp = "); Serial.println(Stopp); Abbruch = 1; break;
case 16736925: if (Helligkeitsfaktor < 4) {Helligkeitsfaktor++; Serial.print("Helligkeitsfaktor = "); Serial.println(Helligkeitsfaktor);} break;
case 16754775: if (Helligkeitsfaktor > -1) {Helligkeitsfaktor--; Serial.print("Helligkeitsfaktor = "); Serial.println(Helligkeitsfaktor);} break;
case 16769055: if (Geschwindigkeitsquotient > 0) {Geschwindigkeitsquotient--; Serial.print("Geschwindigkeitsquotient = "); Serial.println(Geschwindigkeitsquotient);} break;
case 16748655: if (Geschwindigkeitsquotient < 9) {Geschwindigkeitsquotient++; Serial.print("Geschwindigkeitsquotient = "); Serial.println(Geschwindigkeitsquotient);} break;
case 16712445: Pause = Pause * -1; Stopp = -1; Serial.print("Pause = "); Serial.println(Pause); break;
IrReceive.resume();
//void LoopcallwithTimeout(int (*Functionpointer)(), int Timeoutms)
// long Timeoutstartzeit;
// Timeoutstartzeit = millis();
// while (((millis() - Timeoutstartzeit) <= Timeoutms))
// Functionpointer();
// if (IR_gelesen == 1) {IR_gelesen = 0; return;}
// delay(50);
// IrReceive.resume();
//void Debugln(String Nachricht)
// Serial.println(Nachricht);
//void Debugfloat(float Zahl)
// Serial.println(Zahl);
//void Debugmsg(String Nachricht, float Variable)
// Serial.print(Nachricht);
// Serial.println(Variable);
//void Pause()
// Serial.println("Pause wurde gedrückt.");
// Stopp = Stopp * -1;
void Abschalten()
Serial.println("Abschalten aufgerufen");
int i;
Abbruch = 0;
FastLED.show();
void LEDshiftByRef(CRGB* LEDs, int Richtung)
int i;
if (Richtung == 0)
for (i = SEGMENTLAENGE-1; i >= 1; i--)
LEDs[i]=LEDs[i-1];
if (Richtung == 1)
for (i = 0; i <= SEGMENTLAENGE-1; i++)
LEDs[i]=LEDs[i+1];
int Diff255(int Summe)
if (Summe >= 255)
return Summe - 255;
return Summe;
This is the error:
