Results 1 to 6 of 6
Thread: Teensy 4.0 and FastLED
    Oct 2019
    2
    Hello community,
    i have been using a Teensy 3.5 to control my WS2812B Neopixels and was happy about WS2812Serial Library that made it possible to use an IR Remote at the same time.
    Now i ordered a teensy 4.0 and wanted to use it within the same setup as my teensy 3.5, but it doesn't work ..
    One problem seems to be, that the WS2812Serial library wasn't updated for teensy 4.0 yet, am i right? I just get a compilation Error when i try to run it.
    This is the Code:
    #include <WS2812Serial.h>
    #define USE_WS2812SERIAL
    #include <FastLED.h>
    #include <IRremote.h>
    #define NUM_LEDS 432
    #define SEGMENTLAENGE 25
    #define SEGMENTE 17
    //#define SEGMENTLAENGE 432
    //#define SEGMENTE 1
    #define IRRECEIVE_PIN 2
    // Usable pins:
    //   Teensy LC:   1, 4, 5, 24
    //   Teensy 3.2:  1, 5, 8, 10, 31   (overclock to 120 MHz for pin 8)
    //   Teensy 3.5:  1, 5, 8, 10, 26, 32, 33, 48
    //   Teensy 3.6:  1, 5, 8, 10, 26, 32, 33
    #define NEOPIXEL_PIN 8
    int static Programmnummer = 6;
    int static Anzahl_der_Programme = 2;
    int static Stopp = -1; // -1 = Stopp, 1 = Run
    int static Pause = -1; // -1 = Pause, 1 = Run
    int static Abbruch = 0;
    int static Helligkeitsfaktor=2;
    int static IR_gelesen = 0;
    int static Geschwindigkeitsquotient = 5;
    void (*Effektprogramme[])() = {&Matrix_fluessig, &DMT, &Blitzen, &Wanderpixel, &Regenbogen, &Strobo, &Boom};
    IRrecv IrReceive(IRRECEIVE_PIN);
    decode_results IR_Result;
    CRGBArray<NUM_LEDS> leds;
    CRGB* LEDs[SEGMENTE];
    //typedef void (*f)(void);
    //Alternative Initialisierung des Function Arrays
    //f Effektprogramme[] = {&Matrix_fluessig, &DMT};
      int i;
      IrReceive.enableIRIn(); // Start the receiver
      //FastLED.addLeds<NEOPIXEL,NEOPIXEL_PIN>(leds, NUM_LEDS);
      //LEDS.addLeds<WS2812SERIAL,NEOPIXEL_PIN,RGB>(leds,NUM_LEDS);
      LEDS.addLeds<WS2812SERIAL,NEOPIXEL_PIN,BRG>(leds,NUM_LEDS);
      for (i = 0; i < SEGMENTE; i++)
        LEDs[i] = &leds[i*SEGMENTLAENGE];
      //Serial.println("Mainloop");
      CheckIR();
      if (Abbruch == 1 && Stopp == 1) {Abschalten(); Pause = 1;}
      Abbruch = 0;
      //Serial.print("Programmnummer = "); Serial.println(Programmnummer);
      if (Stopp == -1) {Effektprogramme[Programmnummer]();}
      delay(50);
    void Matrix_fluessig()
      int i[SEGMENTE] = {0};
      //int Leuchten[SEGMENTE];
      int Schweiflaenge[SEGMENTE];
      int Helligkeit[SEGMENTE] = {0};
      int Shiftdirection[SEGMENTE] = {0};
      Serial.println("Starte Matrix fluessig");
      Geschwindigkeitsquotient = 7;
    //  Shiftdirection[1]=1;
    //  Shiftdirection[3]=1;
    //  Shiftdirection[5]=1;
    //  Shiftdirection[7]=1;
    //  Shiftdirection[9]=1;
    //  Shiftdirection[11]=1;
    //  Shiftdirection[13]=1;
    //  Shiftdirection[15]=1;
      while (true) {
      if (Abbruch == 1)
        Serial.println("Abbruchanforderung registriert, Breche Matrix-Loop ab");
      for (int Segmentnummer = 0; Segmentnummer < SEGMENTE; Segmentnummer++)
        if ((Helligkeit[Segmentnummer] == 0) && (random(1,10) > 8)) {Helligkeit[Segmentnummer] = 255; i[Segmentnummer] = 0;}
        if (Helligkeit[Segmentnummer] == 255)
          Schweiflaenge[Segmentnummer] = random(10,20);
        if (Helligkeit[Segmentnummer] > 0)
          Helligkeit[Segmentnummer] = 255*(Schweiflaenge[Segmentnummer]-i[Segmentnummer])/Schweiflaenge[Segmentnummer];
          i[Segmentnummer]++;
        LEDshiftByRef(LEDs[Segmentnummer], Shiftdirection[Segmentnummer]);
        //if (Shiftdirection[Segmentnummer] == 0) LEDs[Segmentnummer][0] = CHSV(Segmentnummer*255/SEGMENTE,255,Helligkeit[Segmentnummer]); //Regenbogenvariante
        //if (Shiftdirection[Segmentnummer] == 1) LEDs[Segmentnummer][SEGMENTE-1] = CHSV(Segmentnummer*255/SEGMENTE,255,Helligkeit[Segmentnummer]); //Regenbogenvariante
        if (Shiftdirection[Segmentnummer] == 0) LEDs[Segmentnummer][0] = CHSV(82,255,Helligkeit[Segmentnummer]);
        if (Shiftdirection[Segmentnummer] == 1) LEDs[Segmentnummer][SEGMENTE-1] = CHSV(82,255,Helligkeit[Segmentnummer]);
        while(Pause == 1){delay(100); CheckIR();}
        CheckIR();
        FastLED.setBrightness(pow(4,Helligkeitsfaktor)-1);
        FastLED.show();
        delay(5000/pow(2,Geschwindigkeitsquotient));
    void DMT()
      int Segmentnummer;
      CHSV Farben[3];
      Farben[0] = CHSV(1,255,255);
      Farben[1] = CHSV(1,0,255);
      Farben[2] = CHSV(82,255,255);
      Serial.println("DMT-Programm gestartet");
      while (true)
    //  if (Abbruch == 1)
    //    Serial.println("Abbruchanforderung registriert, Breche DMT-Loop ab");
    //    break;
        for (int g = 0; g < sizeof(Farben)/3; g++)
          if (Abbruch == 1)
            Serial.println("Abbruchanforderung registriert, Breche FarbLoop ab");
            return;
          for (int j = 0; j < SEGMENTLAENGE/2; j++)
            for (Segmentnummer = 0; Segmentnummer < SEGMENTE; Segmentnummer++)
              CheckIR();
              if (SEGMENTLAENGE % 2 == 1)
                LEDs[Segmentnummer][(SEGMENTLAENGE+1)/2] = Farben[g];
                LEDs[Segmentnummer][(SEGMENTLAENGE+1)/2-1-j] = Farben[g];
                LEDs[Segmentnummer][(SEGMENTLAENGE+1)/2+1+j] = Farben[g];
                LEDs[Segmentnummer][SEGMENTLAENGE/2-1-j] = Farben[g];
                LEDs[Segmentnummer][SEGMENTLAENGE/2+j] = Farben[g];
          FastLED.show();
    void Wanderpixel()
      Geschwindigkeitsquotient = 9;
      Serial.println("Wanderpixel gestartet");
      Abschalten();
      while (true)
        for (int i = 0; i <= NUM_LEDS; i++)
          CheckIR();
          if (Abbruch == 1)
            Serial.println("Abbruchanforderung registriert, Breche Wanderpixel ab");
            return;
          leds[i] = CHSV(1,0,255);
          FastLED.show();
          leds[i] = CHSV(1,0,0);
    void Blitzen()
      Serial.println("Blitzen gestartet");
      while (true)
      if (Abbruch == 1) {return;}
    //  for (i = 0; i <= NUM_LEDS; i++)
    //    if (random(1,10) > 5) Helligkeit = 0;
    //    if (random(1,10) <= 5) Helligkeit = pow(4,random(0,4));
    //    leds[i] = CHSV(1,0,Helligkeit);
        leds[i] = CHSV(1,0,pow(4,random(-20,4)));
      CheckIR();
      FastLED.show();
    void Regenbogen()
      Serial.println("Regenbogen gestartet");
      while (true)
        for (int colorshift = 0; colorshift <= 255; colorshift = colorshift+5)
          for (int i = 0; i <= SEGMENTLAENGE; i++)
            LEDs[Segmentnummer][i] = CHSV(Diff255(map(i, 0, SEGMENTLAENGE, 0, 255)+colorshift),255,255);
            //LEDs[Segmentnummer][i] = CHSV(Diff255(map(i, 0, SEGMENTLAENGE, 0, 255)),255,255);
        CheckIR();
        FastLED.show();
    void Strobo()
      Serial.println("Strobo gestartet");
      Geschwindigkeitsquotient = 6;
      while (true)
      FastLED.show();
      CheckIR();
      FastLED.show();
    void Boom()
      Serial.println("Boom gestartet");
      Abschalten();
      while (true)
        for (int i = 0; i <= SEGMENTLAENGE/2; i++)
            CheckIR();
            if (Abbruch == 1)
              return;
            if (i>0) {LEDs[Segmentnummer][i-1] = CHSV(1,0,0); LEDs[Segmentnummer][SEGMENTLAENGE-i+1] = CHSV(1,0,0);}
            LEDs[Segmentnummer][i] = CHSV(1,0,120);
            LEDs[Segmentnummer][SEGMENTLAENGE-i] = CHSV(1,0,120);
          FastLED.show();
          delay(15000/pow(2,Geschwindigkeitsquotient));
      LEDs[Segmentnummer][SEGMENTLAENGE/2] = CHSV(1,0,255);
      LEDs[Segmentnummer][SEGMENTLAENGE-SEGMENTLAENGE/2] = CHSV(1,0,255);
      FastLED.setBrightness(255);
      FastLED.show();
      delay(30);
        for (int i = SEGMENTLAENGE/2+1; i >= 0; i--)
          CheckIR();
          if (Abbruch == 1)
            return;
          LEDs[Segmentnummer][i] = CHSV(i*3,255,255);
          LEDs[Segmentnummer][SEGMENTLAENGE-i] = CHSV(i*3,255,255);
          FastLED.show();
          delay(2500/pow(2,Geschwindigkeitsquotient));
          CheckIR();
          if (Abbruch == 1)
            return;
          LEDs[Segmentnummer][i] = CHSV(i,255,0);
          LEDs[Segmentnummer][SEGMENTLAENGE-i] = CHSV(i,255,0);
          FastLED.show();
    void CheckIR()
      if (IrReceive.decode(&IR_Result))
        Serial.println(IR_Result.value);
        switch(IR_Result.value)
          case 16761405: if (Programmnummer < sizeof(Effektprogramme)/4-1) {Programmnummer++; Serial.print("Programmnummer = "); Serial.println(Programmnummer); Abbruch = 1;} break;
          case 16720605: if (Programmnummer > 0) {Programmnummer--;                         Serial.print("Programmnummer = "); Serial.println(Programmnummer); Abbruch = 1;} break;
          case 16753245: Stopp = Stopp * -1; Pause = -1; Serial.print("Stopp = "); Serial.println(Stopp); Abbruch = 1; break;
          case 16736925: if (Helligkeitsfaktor < 4) {Helligkeitsfaktor++; Serial.print("Helligkeitsfaktor = "); Serial.println(Helligkeitsfaktor);} break;
          case 16754775: if (Helligkeitsfaktor > -1) {Helligkeitsfaktor--; Serial.print("Helligkeitsfaktor = "); Serial.println(Helligkeitsfaktor);} break;
          case 16769055: if (Geschwindigkeitsquotient > 0) {Geschwindigkeitsquotient--; Serial.print("Geschwindigkeitsquotient = "); Serial.println(Geschwindigkeitsquotient);} break;
          case 16748655: if (Geschwindigkeitsquotient < 9) {Geschwindigkeitsquotient++; Serial.print("Geschwindigkeitsquotient = "); Serial.println(Geschwindigkeitsquotient);} break;
          case 16712445: Pause = Pause * -1; Stopp = -1;  Serial.print("Pause = "); Serial.println(Pause); break;
        IrReceive.resume();
    //void LoopcallwithTimeout(int (*Functionpointer)(), int Timeoutms)
    //  long Timeoutstartzeit;
    //  Timeoutstartzeit = millis();
    //  while (((millis() - Timeoutstartzeit) <= Timeoutms))
    //    Functionpointer();
    //    if (IR_gelesen == 1) {IR_gelesen = 0; return;}
    //    delay(50);
    //  IrReceive.resume();
    //void Debugln(String Nachricht)
    //  Serial.println(Nachricht);
    //void Debugfloat(float Zahl)
    //  Serial.println(Zahl);
    //void Debugmsg(String Nachricht, float Variable)
    //  Serial.print(Nachricht);
    //  Serial.println(Variable);
    //void Pause()
    //  Serial.println("Pause wurde gedrückt.");
    //  Stopp = Stopp * -1;
    void Abschalten()
      Serial.println("Abschalten aufgerufen");
      int i;
      Abbruch = 0;
      FastLED.show();
    void LEDshiftByRef(CRGB* LEDs, int Richtung)
      int i;
      if (Richtung == 0)
        for (i = SEGMENTLAENGE-1; i >= 1; i--)
          LEDs[i]=LEDs[i-1];
      if (Richtung == 1)
        for (i = 0; i <= SEGMENTLAENGE-1; i++)
          LEDs[i]=LEDs[i+1];
    int Diff255(int Summe)
      if (Summe >= 255)
        return Summe - 255;
        return Summe;
    This is the error:
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=147 -DARDUINO=10809 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\ifeel\\AppData\\Local\\Temp\\arduino_build_393761/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\WS2812Serial" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\FastLED" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\IRremote" "C:\\Users\\ifeel\\AppData\\Local\\Temp\\arduino_build_393761\\sketch\\Masterprogramm_SerialLED.ino.cpp" -o "C:\\Users\\ifeel\\AppData\\Local\\Temp\\arduino_build_393761\\sketch\\Masterprogramm_SerialLED.ino.cpp.o"
    In file included from Z:\Daten\OneDrive\Unverschlüsselt\Projekte\Infinity Cube\Arduino\Sources\LED_Stripe_Kontrolle\Masterprogramm_SerialLED\Masterprogramm_SerialLED.ino:3:0:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.000
     #    pragma message "FastLED version 3.003.000"
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FastLED/FastLED.h: In static member function 'static CLEDController& CFastLED::addLeds(CRGB*, int, int)':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FastLED/FastLED.h:393:10: error: 'CWS2812SerialController' does not name a type
       static CWS2812SerialController<DATA_PIN,RGB_ORDER> controller;
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FastLED/FastLED.h:394:19: error: 'controller' was not declared in this scope
       return addLeds(&controller, data, nLedsOrOffset, nLedsIfOffset);
    Masterprogramm_SerialLED: In function 'void DMT()':
    Masterprogramm_SerialLED:179: warning: comparison between signed and unsigned integer expressions
    Masterprogramm_SerialLED: In function 'void CheckIR()':
    Masterprogramm_SerialLED:456: warning: comparison between signed and unsigned integer expressions
    Z:\Daten\OneDrive\Unverschlüsselt\Projekte\Infinity Cube\Arduino\Sources\LED_Stripe_Kontrolle\Masterprogramm_SerialLED\Masterprogramm_SerialLED.ino: At global scope:
    Masterprogramm_SerialLED:22: warning: 'Anzahl_der_Programme' defined but not used
    Masterprogramm_SerialLED:27: warning: 'IR_gelesen' defined but not used
    Bibliothek WS2812Serial im Ordner: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\WS2812Serial (legacy) wird verwendet
    Bibliothek FastLED in Version 3.3.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FastLED  wird verwendet
    Bibliothek SPI in Version 1.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI  wird verwendet
    Bibliothek IRremote in Version 2.2.3 im Ordner: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\IRremote  wird verwendet
    Fehler beim Kompilieren für das Board Teensy 4.0.
    Then i tried a project that makes just use of the FastLED library for Teensy but it, after compiling successfully, didn't work either. Then LED stripe gets just plain white.
    This is the code that compiled successfully:
    #define NUM_LEDS 144
    #define LED_PIN 8
      FastLED.addLeds<NEOPIXEL,LED_PIN>(leds, NUM_LEDS);
      int i;
        leds[i] = CHSV((map(i, 0, NUM_LEDS, 0, 255)),255,40);
      FastLED.show();
      if (Summe >= 255)
        return Summe - 255;
        return Summe;
    I am using Pin 8 for the signal and the GND at the top left corner to connect to the LED strips ground.
    Thanks in advance for every kind of advice!
    Enndee
    Oct 2019
    2
    I think i found the solution myself .. gotta try this:
    https://www.reddit.com/r/FastLED/com...811_ws2812_ws/
    2,238
    install the latest from https://github.com/FastLED/FastLED
    it should work with teensy 4
    Quote Originally Posted by Enndee View Post
    could you please explain more about how you make it work!
    I did use the code for parallel output from
    https://gist.github.com/chemdoc77/8b...cca62759efbd2f
    but does not work as expected.
    Junior Member chemdoc77's Avatar
    Sep 2019
    Chicagoland Area
    6
    What pin did you use for your dout on the Teensy 4.0?
    What did not work as expected?
    Can you post a link to your sketch in GitHub or GitHub Gist?
    5,740
    Try looking at the thread: https://forum.pjrc.com/threads/58442...and-Teensy-4-0
    I have 3 updated libraries (with PRs) to support WS2812Serial library which required a fix in the main Teensy cores file imxrt.h
    The DMUX_SOURCE_ for the UARTS TX and RX were reversed... You can simply find all of them and CHANGE TX->RX and RX->TX to fix.
    FastLED - latest had T4 support in it but not WS2812Serial support for T4... Again I Have PR back to FastLED, BUT not sure who if anyone is going to maintain that library since the owner passed away in that boat fire... Again the fix is easy, you can either grab from my fork or look at the thread I mention.
