Redgeneral
Hi
I've been trying to use the 74HC595 with the Teensy LC, but I'm not having much luck.
Although the end intent is to make a button matrix, I've been trying to test it using LEDs, but they do not light up at all.
My Circuit:
My Breadboard:
My Code (no error messages):
Additional testing:
Software: Arduino 1.8.8 and Teensyduino
Hardware: Teensy LC and 74HC595 (Texas Instruments SN74HC595N)
Additional Libraries: None
I'm not sure what I'm doing wrong and would be grateful for any help
Thank you
My Circuit:
My Breadboard:
// teensy tto 74hc595 - column light up
//connections to 74hc595
int latchPin = 8;
int clockPin = 13;
int dataPin = 11;
// shifting values
byte patterns[8]={
B00000001,
B00000010,
B00000100,
B00001000,
B00010000,
B00100000,
B01000000,
B10000000
int current = 0;
int count = sizeof(patterns);
// set serial pins to output
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
//write to shift registor
digitalWrite(latchPin,LOW);
shiftOut(dataPin, clockPin, MSBFIRST, patterns[current]);
digitalWrite(latchPin, HIGH);
//increase current
current++;
//reset current
if(current >= 8){
current = 0;
Additional testing:
- Tested each wire and LEDs
- Rechecked all LEDs are the right way round
- Teensy LC onboard LED (pin 13) flashes - so it is working
Thank you
