Serial connection disabled from one revision to the next
StockHuman
New member
Hello teensy people,
In the interest of making this question as scan-able as possible:
0. This code works where this does not.
1. You can reproduce this with no hardware beyond a single Teensy 4.0
2. I am on Windows 10
3. This code works as expected:
void setup() {Serial.begin(9600); } void loop() { Serial.println("test"); delay(200); }
4. I am using PlatformIO, though the Arduino IDE refuses to connect as well.
In longer form, while programming I've come across a side effect of a revision of mine that I don't understand. With seemingly minor changes, the most recent version of what I'm uploading to the teensy no longer interacts with my PC. Indeed, automatic programming also breaks, and upon opening the serial monitor, I'm greeted with a "
could not open port u'COM3': could not open port u'COM3': WindowsError(2, 'The system cannot find the file specified.')
" error.
The most significant changes are in the Keyboard.cpp file, and that's what I suspect is breaking things. I am trial-and-error'ing my way through every line, but I imagine I won't learn all that much from that approach. If you'd like to build this code yourself, the library not included in my repo is this observer template one.
Thank you kindly for any insights as to what's going on.
Thank you both for your swift replies!
void SynthEngine::setup() {
  AudioMemory(20); // upped from 10
  waveform.begin(WAVEFORM_SINE);
  waveform.frequency(440);
  waveform.amplitude(0);
I was wrong in my assumption that the keyboard.cpp changes were the culprit. Seemingly increasing the audiomemory of the sketch fixed the serial comms issue. Is it policy here to delete one's threads once solved?
On an unrelated note: The Teensy platform is so great, hardware and community.
Glad the solution was found.
Forum searching isn't great - but leaving the issues discovered by one poster may very well hope another so threads just survive with that goal in mind.
