Results 1 to 5 of 5
Thread: [queued] Lilla
    Member Sandro's Avatar
    Nov 2016
    Rimini - Italy
    83
    [queued] Lilla
    Dear friends, I'm proud to share my midi expander project (I would apologize in advance for the naivety of my code)
    https://github.com/SandroGrassia/Lilla-midi-expander
    I would say thank you to Paul and to all many friends who gave me support, tips, and energy in the last 2 years (since this project started).
    In a month I should be able to do a video with some musicians friends... In the meanwhile hope to find the time to do a video-demo.
    Nov 2016
    Rimini - Italy
    83
    Lilla is an open source project for a polyphonic midi expander, based on Teensy 3.6 microcontroller. Lilla includes:
    devices/ICs:
    n.1 Teensy 3.6 microcontroller
    n.1 Teensy Audio Adaptor
    n.1 flash memory chip W25Q128FV (actually testing W25Q256FV )
    n.3 CD74HC4067 (16-Channel Analog Multiplexer)
    n.1 128x160 TFT color display
    n.1 HCPL260L (single-channel optocoupler)
    n.1 CD4093B (quad 2-Input NAND Schmitt Triggers)
    commands:
    n.12 rotary encoders with pushbutton
    n.8 pushbuttons
    Teensy program pushbutton
    interfaces:
    midi in (DIN)
    midi thru (DIN)
    stereo line output
    micro-SD socket
    polyphony:
    reading files from external flash memory: 6
    reading files from internal memory: 12
    Audio files and presets
    Lilla uses 44.1kHz 16bit mono .RAW audio files, imported from a micro SD card. Lilla can store up to 100 "Sounds", up to 30 setup (Sessions), in a Session up to 8 Instruments which also can be layered.
    Effects
    Lilla includes 3 simple effects:
    resolution: decreases the number of bits (16bit -> 1bit)
    downsampling: decreases the sampling frequency (44.1KHz -> 344Hz)
    saturation: limits samples value within a range
    Settings
    Lilla requires/allows the following settings:
    MIDI channel
    first octave number
    Instruments volume control: each Instrument can be associated to a MIDI Controller
    enabling/disabling effects for each Instrument
    MIDI Velocity response: 4 curves / 8 adjustment points
    Editing
    Sounds, Instruments and Sessions have to be created by the user. All settings can be edited using a tree menus; Sounds of a Session can be modified on the fly (during a performance) with fast and direct access (pushbuttons).
    very nice, thanks for sharing!
    Nov 2016
    Rimini - Italy
    83
    Lilla debuts at Soundmit
    https://soundmit.com/it/espositore/l...0R0-5EKiC-8jE8
    Turin(Italy), 2-3 Nov 2019
    Nov 2016
    Rimini - Italy
    83
    Also tested W25Q256FV but I had an issue, looking like a loss of connection... as soon as possible I'd like to share .
