Results 1 to 10 of 10
Thread: Audio library cannot find sd card
    Oct 2019
    14
    I created a 44000hz 16 bit stereo wav file with audacity , then I put it on a sd card (FAT32 - windows 7)
    I put the sd card in a teensy 3.6
    trying the below code, the teensy is not reacheable anymore ...after a while, a message keeps repeating in the IDE
    Error while setting serial port parameters: 38,400 N 8 1
    unless I comment the "SD.begin..." line
    really weird, since it's taken from the official audio library example code, and the teensy is bare (not inside a system nor anything)
    any help appreciated
    thanks
    AudioPlaySdWav           playWav1;
    AudioOutputAnalog       audioOutput;
    AudioConnection          patchCord1(playWav1, 0, audioOutput, 0);
    AudioConnection          patchCord2(playWav1, 1, audioOutput, 1);
    #define SDCARD_CS_PIN    BUILTIN_SDCARD
    #define SDCARD_MOSI_PIN  11  // not actually used
    #define SDCARD_SCK_PIN   13  // not actually used
      Serial.begin(38400);
      AudioMemory(8);
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
      Serial.println("SD.begin...");
        // stop here, but print a message repetitively
        while (1) {
      Serial.print("Playing file: ");
      Serial.println(filename);
      playWav1.play(filename);
      delay(5);
      while (playWav1.isPlaying()) {
      playFile("MYFILE.WAV");  // filenames are always uppercase 8.3 format
      delay(2000);
    2,238
    what version of IDE and teensyduino are you using? there was a problem AudioPlaySdWav a few months ago. you may need to get the latest IDE/Teensyduino
    Oct 2019
    14
    1.8.9, I'll try 1.8.10
    hope it dont breaks anything else :-)
    Oct 2019
    14
    arf f#@k , now I get "Audio.h: No such file or directory"
    I just hate the arduino IDE
    2,238
    Quote Originally Posted by yoda1976 View Post
    the SdWav problem was with Teensyduino -- what version of that are you running? (it's what you install from Teensy after you have installed new version of Arduino IDE)
    get the latest 1.48-beta3 https://forum.pjrc.com/threads/57894...no-1-48-Beta-3
    Oct 2019
    14
    I cant install teensyduino anymore
    I cant select the arduino install folder , the next button stays grayed out
    checking the ? button I see 1.8.10 is not supported...for fuck sake
    20,820
    Get the latest 1.48-beta3.
    In that screenshot, you have 1.47 which is older than the latest Arduino 1.8.10.
    Oct 2019
    14
    No I recompile and I get this
    seriously ???
    Oct 2019
    14
    oh no way ot a beta , dude, I am not playing around here come on
    f the sd card, I'll do without it
    20,820
    In your screenshot on msg #8, looks like Teensy 3.2 is select. That's probably why you're getting the error the SDCARD_CS_PIN is undefined. Teensy 3.2 doesn't have a built in SD card socket.
    I know compile errors are frustrating. I also hope you can understand why this error happens when you have Teensy 3.2 selected?
    I'll admit, we are late for a stable 1.48 release. Since beta3 is looking good, I'm probably going to release it later today.
    Normally the plan is to release a beta within 24 hours of each Arduino release. Arduino 1.8.10 was released Sept 13. We did get 1.48-beta1 published about 24 hours later. Normally the plan looks like 2 to 3 weeks of beta testing before we release a stable version. That also allows time to see if Arduino has any serious bugs that prompt another quick release (as happened with 1.8.6).
    So please try to keep a little perspective here. It's been 3 weeks and 2 days since Arduino released 1.8.10. A stable non-beta release just isn't practical immediately when Arduino publishes a new version. Normally we get it within 2-3 weeks, and this time we're going to be only a few days beyond that time frame.
