T:\tCode\T4\T4-TEMPMON_buddabrot\T4-TEMPMON_buddabrot.ino Oct 8 2019 03:10:02
>>> Reason for 'reset': 1 IPP_RESET_B :: done Reason
F_CPU==1008000000 F_BUS==252000000 FreeMem(); 4293328836
begin ...
in setup @L#72 stack var addr: 0x2006FFE4
TEMPMON driver example.
F_CPU=1008000000 deg C=32
The chip initial temperature is 32.00 @ms= 2728
31.36 @ms= 3147
31.36 @ms= 3818
31.36 @ms= 4489
56.82 @ms= 416071
56.82 @ms= 416761
56.82 @ms= 417439
57.45 @ms= 418131
Fault irq 3
stacked_r0 :: 20011BA3
stacked_r1 :: 20070023
stacked_r2 :: 00000060
stacked_r3 :: 2006FFFF
stacked_r12 :: 2001230D
stacked_lr :: 00008211
stacked_pc :: 0000076C
stacked_psr :: 810B0000
_CFSR :: 00008200
(PRECISERR) Data bus error(address in BFAR)
(BFARVALID) Bus Fault Address Valid
_HFSR :: 40000000
(FORCED) Forced Hard Fault
_DFSR :: 00000000
_AFSR :: 00000000
_BFAR :: 20070000
_MMAR :: 20070000
in Debug_Dump @L#60 stack var addr: 0x2006FF04
User Custom Debug Dump. Micros==418139752
userDebugDumptt() in debug_tt ___
F_CPU=300000000
>>>> Debug Fault >>>> debug_fault >>>> TYPE:T_4
debug_tt Info: [Last debug_tt helper @ L#:60 Debug_Dump()
>>>> Debug Fault >>>> TYPE:T_4
--- Faulted >>>> Execution Halted.
For more info - print it in sketch :: Debug_Dump(void)
@KurtE - thanks - 1st pic with new phone
Running sketch with no heatsink on one of my breakout boards. Just ran it at 816 and getting pretty much the same temp as you about 58 degC.
[ATTACH]17848._xfImport[/ATTACH]
T:\tCode\T4\T4-TEMPMON_buddabrot\T4-TEMPMON_buddabrot.ino Oct 8 2019 11:04:49
F_CPU==960000000 F_BUS==240000000 FreeMem(); 4293328836
begin ...
F_CPU=960000000 deg C=45
The chip initial temperature is 45.36 @ms= 2731
44.73 @ms= 3171
#include "debug_tt.h"
void Debug_Dump(void)
where_tt( );
printf_tt(" User Custom Debug Dump. Micros==%u", micros());
// Put code here to call after Fault or HaltIf() - or call it in sketch
return;
[B]void setup() {[/B]
while ( !Serial);
delay(2000);
debBegin_tt( (HardwareSerial*)&Serial, LED_BUILTIN, 7);
Serial.println("\n begin ...");
where_tt( );
58.73 @ms= 513748
58.73 @ms= 514444
61.27 @ms= 1164452
60.64 @ms= 1165145
60.64 @ms= 1165839
60.64 @ms= 10074795
60.64 @ms= 10075492
60.00 @ms= 10076187
Arduino: 1.8.5 (Windows 7), TD: 1.48, Board: "Teensy 4.0, Serial, 600 MHz, Debug, US English"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=ogstd,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_917047 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_780063 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf1.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=ogstd,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_917047 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_780063 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf1.ino
Using board 'teensy40' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy4' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\sketch\arf1.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/precompile_helper" "C:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047" "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047/pch/Arduino.h" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\pch\Arduino.h.gch
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_917047/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\sketch\arf1.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -Og -Wl,--gc-sections,--relax "-TC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047/arf1.ino.elf" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\sketch\arf1.ino.cpp.o" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047/..\arduino_cache_780063\core\core_teensy_avr_teensy40_usb_serial,speed_600,opt_ogstd,keys_en-us_4939f5412a75a8560acb0f9e98268f02.a" "-LC:\Users\Dell\AppData\Local\Temp\arduino_build_917047" -larm_cortexM7lfsp_math -lm -lstdc++
C:\Users\Dell\AppData\Local\Temp\arduino_build_917047/..\arduino_cache_780063\core\core_teensy_avr_teensy40_usb_serial,speed_600,opt_ogstd,keys_en-us_4939f5412a75a8560acb0f9e98268f02.a(startup.c.o): In function `ResetHandler':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/startup.c:135: undefined reference to `setup'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/startup.c:139: undefined reference to `loop'
Error compiling for board Teensy 4.0.
// FFT W PRINT AND CONST TABLE FOR WINDOW
// has input gen and 12 bit ad sim
// t36 180mhz debug w lto
// single 8.1 ms double 54.9 ms
// define some constants
#define unit 1.0
#define half 0.5
#define two 2.0
#define rad 57.2957795
// define for atan, asin, acos
#define pi 3.14159265
#define pio2 1.57079633
// define for sqrt
#define sqrt2 1.41421356
// define for log, exp
#define ln2 0.6931471806
#define ln10 2.30258509
union u {
signed short int adin[1100];
float d2[256];
union u ary;
float d1[256];
// all poly terms stored in one array to allow
// ref by pointer in subroutines that are
// called by poly solvers
int led = 13;
float q,x,xa,y,nng,xp;
float t1,t2,s,c,a,m,fi,nnf,nnfr,jlf,jrf;
unsigned short int n1,n2,n3,n4,n5,n6,n7,n8,n9,nn,il,jl;
signed short int yi;
unsigned short int flag;
unsigned short int i,j,n;
unsigned short int flg1,flg2,flg3,flg4,flg5,flg6,flg7,flg8,flg9;
char fchar;
signed short int r0;
float const win [256] = {
0.000000E+00, 4.470349E-08, 7.301569E-07, 3.591180E-06,
1.162291E-05, 2.828241E-05, 5.851686E-05, 1.083165E-04,
1.845211E-04, 2.951622E-04, 4.489422E-04, 6.560385E-04,
9.270459E-04, 1.273662E-03, 1.708508E-03, 2.244964E-03,
2.897143E-03, 3.679946E-03, 4.609019E-03, 5.700469E-03,
6.971255E-03, 8.438721E-03, 1.012060E-02, 1.203514E-02,
1.420127E-02, 1.663765E-02, 1.936364E-02, 2.239862E-02,
2.576207E-02, 2.947374E-02, 3.355316E-02, 3.801981E-02,
4.289316E-02, 4.819256E-02, 5.393678E-02, 6.014456E-02,
6.683409E-02, 7.402332E-02, 8.172951E-02, 8.996935E-02,
9.875893E-02, 1.081136E-01, 1.180480E-01, 1.285761E-01,
1.397107E-01, 1.514639E-01, 1.638466E-01, 1.768690E-01,
1.905398E-01, 2.048672E-01, 2.198576E-01, 2.355164E-01,
2.518480E-01, 2.688551E-01, 2.865396E-01, 3.049015E-01,
3.239399E-01, 3.436521E-01, 3.640344E-01, 3.850816E-01,
4.067865E-01, 4.291414E-01, 4.521362E-01, 4.757600E-01,
5.000001E-01, 5.248423E-01, 5.502715E-01, 5.762705E-01,
6.028209E-01, 6.299029E-01, 6.574955E-01, 6.855760E-01,
7.141204E-01, 7.431040E-01, 7.724999E-01, 8.022808E-01,
8.324174E-01, 8.628799E-01, 8.936374E-01, 9.246574E-01,
9.559069E-01, 9.873516E-01, 1.018957E+00, 1.050687E+00,
1.082504E+00, 1.114373E+00, 1.146254E+00, 1.178109E+00,
1.209899E+00, 1.241586E+00, 1.273128E+00, 1.304487E+00,
1.335621E+00, 1.366490E+00, 1.397055E+00, 1.427274E+00,
1.457107E+00, 1.486514E+00, 1.515456E+00, 1.543891E+00,
1.571783E+00, 1.599092E+00, 1.625779E+00, 1.651807E+00,
1.677141E+00, 1.701743E+00, 1.725578E+00, 1.748613E+00,
1.770814E+00, 1.792149E+00, 1.812588E+00, 1.832100E+00,
1.850656E+00, 1.868231E+00, 1.884797E+00, 1.900330E+00,
1.914808E+00, 1.928208E+00, 1.940512E+00, 1.951700E+00,
1.961755E+00, 1.970664E+00, 1.978412E+00, 1.984987E+00,
1.990381E+00, 1.994585E+00, 1.997592E+00, 1.999398E+00,
2.000000E+00, 1.999398E+00, 1.997592E+00, 1.994585E+00,
1.990381E+00, 1.984987E+00, 1.978412E+00, 1.970664E+00,
1.961755E+00, 1.951700E+00, 1.940512E+00, 1.928208E+00,
1.914808E+00, 1.900330E+00, 1.884797E+00, 1.868231E+00,
1.850656E+00, 1.832100E+00, 1.812588E+00, 1.792149E+00,
1.770814E+00, 1.748613E+00, 1.725578E+00, 1.701742E+00,
1.677140E+00, 1.651807E+00, 1.625779E+00, 1.599091E+00,
1.571783E+00, 1.543891E+00, 1.515455E+00, 1.486514E+00,
1.457107E+00, 1.427274E+00, 1.397055E+00, 1.366490E+00,
1.335621E+00, 1.304487E+00, 1.273128E+00, 1.241586E+00,
1.209899E+00, 1.178109E+00, 1.146254E+00, 1.114373E+00,
1.082504E+00, 1.050686E+00, 1.018957E+00, 9.873512E-01,
9.559069E-01, 9.246574E-01, 8.936372E-01, 8.628797E-01,
8.324171E-01, 8.022803E-01, 7.724995E-01, 7.431036E-01,
7.141205E-01, 6.855759E-01, 6.574953E-01, 6.299028E-01,
6.028206E-01, 5.762701E-01, 5.502716E-01, 5.248424E-01,
5.000000E-01, 4.757598E-01, 4.521360E-01, 4.291411E-01,
4.067863E-01, 3.850812E-01, 3.640345E-01, 3.436521E-01,
3.239397E-01, 3.049013E-01, 2.865393E-01, 2.688549E-01,
2.518480E-01, 2.355164E-01, 2.198575E-01, 2.048671E-01,
1.905398E-01, 1.768688E-01, 1.638464E-01, 1.514637E-01,
1.397107E-01, 1.285761E-01, 1.180480E-01, 1.081136E-01,
9.875878E-02, 8.996922E-02, 8.172954E-02, 7.402332E-02,
6.683411E-02, 6.014448E-02, 5.393672E-02, 4.819247E-02,
4.289310E-02, 3.801984E-02, 3.355316E-02, 2.947377E-02,
2.576209E-02, 2.239856E-02, 1.936355E-02, 1.663765E-02,
1.420123E-02, 1.203514E-02, 1.012062E-02, 8.438602E-03,
6.971300E-03, 5.700529E-03, 4.609034E-03, 3.679931E-03,
2.897143E-03, 2.244890E-03, 1.708493E-03, 1.273632E-03,
9.270012E-04, 6.559640E-04, 4.489422E-04, 2.951920E-04,
1.846105E-04, 1.084060E-04, 5.850196E-05, 2.829731E-05,
1.163781E-05, 3.606081E-06, 7.450581E-07, 0.000000E+00,
float const h[33]={
3.306290E-04, 8.395911E-04, 1.004346E-03,-1.057719E-03,
-6.058753E-03,-8.971486E-03,-1.786884E-08, 2.332381E-02,
4.172762E-02, 2.006667E-02,-5.539681E-02,-1.355107E-01,
-1.151403E-01, 9.022949E-02, 4.507063E-01, 8.036606E-01,
9.509602E-01, 8.036606E-01, 4.507062E-01, 9.022947E-02,
-1.151403E-01,-1.355106E-01,-5.539678E-02, 2.006667E-02,
4.172761E-02, 2.332380E-02,-1.786883E-08,-8.971481E-03,
-6.058748E-03,-1.057718E-03, 1.004345E-03, 8.395896E-04,
3.306290E-04, };
signed short int const ad[1100]={
+0, +76, +154, +230, +304, +378, +450, +522, +594, +662,
+730, +794, +856, +914, +970, +1024, +1074, +1124, +1168, +1210,
+1248, +1282, +1312, +1340, +1364, +1386, +1404, +1420, +1432, +1438,
+1442, +1444, +1442, +1438, +1434, +1426, +1416, +1402, +1386, +1368,
+1348, +1328, +1308, +1286, +1264, +1240, +1216, +1190, +1164, +1138,
+1114, +1090, +1068, +1046, +1022, +1000, +978, +958, +940, +924,
+908, +896, +882, +870, +858, +848, +840, +834, +830, +826,
+824, +822, +818, +818, +816, +816, +818, +820, +822, +824,
+824, +822, +820, +820, +818, +814, +810, +806, +798, +788,
+776, +762, +746, +728, +710, +688, +664, +636, +604, +572,
+536, +498, +458, +416, +370, +322, +270, +216, +160, +102,
+44, -16, -78, -142, -210, -278, -346, -416, -486, -554,
-624, -692, -762, -832, -900, -968, -1034, -1098, -1160, -1220,
-1278, -1334, -1390, -1442, -1490, -1534, -1576, -1614, -1648, -1680,
-1708, -1734, -1754, -1772, -1784, -1792, -1796, -1796, -1794, -1788,
-1780, -1766, -1750, -1728, -1704, -1676, -1646, -1614, -1580, -1544,
-1504, -1462, -1418, -1370, -1324, -1276, -1228, -1178, -1130, -1078,
-1026, -974, -924, -874, -824, -776, -728, -682, -636, -592,
-548, -506, -466, -428, -394, -360, -328, -296, -266, -238,
-212, -190, -168, -150, -132, -114, -98, -82, -70, -58,
-46, -38, -28, -18, -10, +2, +10, +20, +30, +38,
+48, +60, +72, +86, +102, +120, +136, +156, +174, +196,
+220, +246, +276, +306, +338, +370, +406, +442, +480, +520,
+562, +608, +652, +698, +746, +792, +842, +892, +942, +994,
+1046, +1096, +1148, +1196, +1244, +1292, +1340, +1388, +1434, +1476,
+1518, +1556, +1592, +1626, +1656, +1686, +1712, +1736, +1754, +1770,
+1782, +1788, +1794, +1794, +1792, +1786, +1778, +1764, +1744, +1722,
+1694, +1666, +1632, +1598, +1558, +1516, +1468, +1418, +1366, +1310,
+1254, +1194, +1134, +1072, +1006, +940, +870, +802, +732, +662,
+594, +524, +456, +386, +316, +248, +180, +114, +52, -10,
-70, -128, -186, -240, -294, -344, -392, -434, -476, -516,
-552, -588, -620, -650, -676, -700, -720, -738, -754, -770,
-782, -794, -804, -810, -814, -818, -820, -822, -824, -824,
-826, -824, -824, -822, -820, -818, -818, -820, -822, -824,
-826, -830, -832, -838, -846, -854, -864, -876, -890, -902,
-916, -932, -950, -968, -990, -1012, -1034, -1056, -1080, -1102,
-1126, -1150, -1176, -1202, -1228, -1252, -1276, -1296, -1318, -1338,
-1358, -1378, -1394, -1410, -1422, -1432, -1438, -1442, -1446, -1446,
-1444, -1438, -1430, -1416, -1400, -1380, -1356, -1332, -1302, -1272,
-1236, -1196, -1152, -1106, -1056, -1004, -950, -894, -834, -772,
-706, -638, -568, -496, -424, -350, -276, -202, -126, -48,
+30, +108, +184, +260, +334, +406, +480, +550, +622, +690,
+756, +820, +880, +936, +992, +1044, +1094, +1142, +1186, +1226,
+1262, +1294, +1324, +1350, +1374, +1394, +1412, +1424, +1434, +1440,
+1444, +1444, +1442, +1438, +1430, +1422, +1410, +1396, +1378, +1360,
+1340, +1320, +1300, +1278, +1254, +1230, +1206, +1180, +1154, +1128,
+1104, +1082, +1058, +1036, +1014, +992, +970, +952, +934, +918,
+904, +890, +878, +866, +854, +844, +838, +832, +828, +824,
+822, +820, +818, +816, +816, +818, +818, +820, +822, +824,
+824, +822, +820, +818, +816, +814, +808, +802, +794, +784,
+770, +756, +740, +722, +702, +678, +652, +624, +592, +558,
+520, +482, +442, +398, +352, +302, +250, +194, +138, +80,
+20, -42, -104, -170, -236, -304, -374, -444, -512, -582,
-650, -720, -790, -860, -928, -996, -1060, -1124, -1184, -1244,
-1300, -1356, -1410, -1462, -1508, -1552, -1592, -1628, -1660, -1692,
-1718, -1742, -1762, -1776, -1788, -1794, -1796, -1796, -1792, -1786,
-1774, -1760, -1742, -1718, -1692, -1664, -1634, -1600, -1566, -1528,
-1488, -1444, -1398, -1352, -1304, -1256, -1208, -1160, -1108, -1058,
-1006, -954, -904, -854, -804, -758, -710, -664, -618, -574,
-530, -490, -450, -414, -380, -346, -314, -284, -254, -228,
-204, -182, -162, -142, -124, -108, -92, -78, -64, -52,
-42, -34, -24, -14, -6, +6, +14, +24, +34, +42,
+52, +64, +78, +94, +110, +126, +144, +162, +184, +206,
+230, +258, +288, +318, +350, +384, +420, +456, +496, +536,
+580, +626, +672, +718, +764, +812, +862, +912, +962, +1014,
+1066, +1118, +1166, +1216, +1264, +1312, +1360, +1406, +1450, +1494,
+1534, +1570, +1606, +1638, +1668, +1696, +1722, +1744, +1762, +1776,
+1784, +1792, +1794, +1794, +1790, +1784, +1772, +1756, +1736, +1712,
+1684, +1652, +1618, +1582, +1542, +1498, +1450, +1398, +1344, +1288,
+1230, +1170, +1110, +1046, +980, +912, +844, +774, +704, +636,
+566, +498, +428, +358, +288, +220, +154, +90, +26, -34,
-94, -152, -208, -262, -314, -364, -408, -452, -492, -530,
-566, -600, -632, -660, -686, -708, -728, -744, -760, -774,
-788, -798, -806, -812, -816, -818, -820, -822, -824, -826,
-826, -824, -822, -820, -818, -818, -820, -820, -822, -824,
-828, -830, -834, -840, -848, -858, -870, -882, -894, -908,
-922, -938, -956, -976, -998, -1020, -1042, -1066, -1088, -1112,
-1136, -1160, -1186, -1212, -1238, -1262, -1284, -1306, -1326, -1346,
-1366, -1384, -1400, -1414, -1426, -1434, -1440, -1444, -1446, -1446,
-1442, -1436, -1424, -1410, -1392, -1370, -1346, -1320, -1290, -1258,
-1220, -1180, -1134, -1086, -1036, -982, -928, -870, -808, -746,
-678, -610, -538, -466, -394, -322, -246, -172, -94, -16,
+62, +138, +214, +290, +364, +436, +508, +580, +650, +716,
+782, +844, +902, +958, +1012, +1064, +1114, +1160, +1202, +1242,
+1276, +1306, +1334, +1360, +1382, +1402, +1418, +1430, +1438, +1442,
+1444, +1442, +1440, +1434, +1428, +1418, +1404, +1390, +1372, +1352,
+1332, +1312, +1290, +1268, +1246, +1220, +1194, +1168, +1144, +1120,
+1096, +1072, +1050, +1028, +1004, +984, +962, +944, +926, +912,
+898, +884, +872, +860, +850, +842, +834, +830, +826, +824,
+822, +820, +818, +816, +816, +818, +820, +822, +822, +824,
+822, +822, +820, +818, +816, +812, +806, +800, +790, +778,
+764, +748, +732, +714, +692, +668, +642, +612, +578, +542,
+506, +466, +424, +380, +332, +282, +228, +172, +114, +56,
-4, -66, -130, -196, -264, -332, -402, -472, -540, -610,
-678, -748, -818, -886, -956, -1022, -1086, -1148, -1208, -1266,
-1324, -1378, -1432, -1480, -1526, -1568, -1606, -1642, -1674, -1702,
-1728, -1750, -1768, -1782, -1790, -1796, -1796, -1794, -1790, -1782,
-1770, -1754, -1732, -1708, -1682, -1652, -1620, -1588, -1550, -1512,
-1470, -1426, -1380, -1334, -1286, -1238, -1188, -1140, -1088, -1038,
-986, -934, -884, -834, -786, -738, -692, -646, -600, -556,
-514, -474, -436, -400, -366, -334, -302, -272, -244, -218,
-194, -172, -154, -136, -118, -102, -86, -72, -60, -48,
-40, -30, -20, -10, -2, +8, +18, +28, +38, +46,
+58, +70, +84, +100, +116, +134, +152, +170, +192, +216,
+242, +270, +300, +332, +364, +398, +434, +472, +512, +554,
+598, +644, +690, +736, +784, +832, +882, +932, +984, +1036,
+1086, +1138, +1186, +1236, +1284, +1332, +1378, +1424, +1468, +1510,
+1548, +1586, +1618, +1650, +1680, +1706, +1730, +1752, +1768, +1780,
+1788, +1792, +1794, +1794, +1788, +1780, +1766, +1748, +1726, +1700,
+1672, +1640, +1604, +1566, +1524, +1478, +1430, +1376, +1322, +1264,
void pfps() {
int main()
pinMode(led, OUTPUT);
// 256 input points
// 128 ouput points
mloop:
nn=256;
nnf=256.0;
nng=1024.0;
n5=1100;
fi=1.0;
// clear array d1
for(jl=0;jl <= (nn-1);++jl)
d1[jl]=0.0;
// clear array adin
for(jl=0;jl <= n5;++jl)
ary.adin[jl]=0.0;
// fill input array 3 terms
// and round to 12 bit ints
fchar=5;
xa=0;
for(jl=0;jl<(n5-1);++jl)
ary.adin[jl]=ad[jl];
// xp=ary.adin[jl];
// pfps();
// do sinc filter
n=32;
n4=32;
jl=n5;
loop1:
y=0;
i=0;
loop2:
q=ary.adin[jl-i];
q=q*h[i];
y=y+q;
++i;
if (i < n) goto loop2;
yi=(signed short int)y;
ary.adin[jl]=yi;
// xp=yi;
// pfps();
jl=jl-1;
if (jl >= n4) goto loop1;
// do decimate by 4
jl=0;
loop3:
il=jl+8;
il=il*4;
yi=ary.adin[il];
d1[jl]=(float)(yi/1.0);
// xp=d1[jl];
// pfps();
++jl;
if (jl < (nn-1)) goto loop3;
// do window
n9=nn-1;
for(jl=0;jl <= n9;++jl)
x=d1[jl];
y=win[jl];
x=x*y;
d1[jl]=x;
// xp=x;
// pfps();
// clear array d2 of union leftovers
n9=nn-1;
ary.d2[jl]=0.0;
// do fft
n1=0;
n2=nn-1;
for(n3=1;n3<=n2;++n3)
n4=nn;
l1470:
n4=n4/2;
if((n1+n4) > n2) goto l1470;
n1=n1-((n1/n4)*n4)+n4;
if(n1 <= n3)goto l1520;
t1=d1[n3];
xa=d1[n1];
d1[n3]=xa;
d1[n1]=t1;
t2=ary.d2[n3];
xa=ary.d2[n1];
ary.d2[n3]=xa;
ary.d2[n1]=t2;
l1520:
n4=n4;
n4=1;
l1530:
n6=n4*2;
for(n3=0;n3<=(n4-1);++n3)
a=fi*(float)n3;
a=a*pi;
a=a/(float)n4;
x=a;
// fchar=5;
// sincos();
x=sinf(x);
// x=sinl(x);
// x=sinfl(x);
s=x;
x=a;
// fchar=6;
// sincos();
x=cosf(x);
// x=cosl(x);
// x=cosfl(x);
c=x;
for(n7=n3;n7<=(nn-1);n7=(n7+n6))
n8=n7+n4;
x=d1[n8];
y=ary.d2[n8];
t1=c*x;
t1=t1-(s*y);
t2=c*y;
t2=t2+s*x;
x=d1[n7];
y=ary.d2[n7];
d1[n8]=x-t1;
ary.d2[n8]=y-t2;
d1[n7]=x+t1;
ary.d2[n7]=y+t2;
n4=n6;
if(n4 < nn) goto l1530;
// do post fft proc
nnfr=1.0/nnf;
nn=nn/2;
nn=nn-1;
for(il=0;il<=nn;++il)
x=d1[il]*d1[il];
x=x+ary.d2[il]*ary.d2[il];
x=sqrtf(x);
d1[il]=x*nnfr;
xp=d1[il];
pfps();
if (flag == 0) {flag=1; digitalWrite(led, HIGH); goto mloop;}
if (flag == 1) {flag=0; digitalWrite(led, LOW); goto mloop;}
@analog&RFmodels
I am not sure how you are compiling this for a T3.6? As I don't see any standard Arduino sketch stuff, like the void setup() {} function or or the void loop() {} function.
And it has a main function...
Maybe you were using a makefile?
Has the experimental RawHID mode for T4 from beta#2 been disabled? All I can select is Serial from the USB Type menu.
#teensy40.menu.usb.rawhid=Raw HID
#teensy40.menu.usb.rawhid.build.usbtype=USB_RAWHID
#teensy40.menu.usb.rawhid.fake_serial=teensy_gateway
T:\arduino_1.8.10\hardware\tools>teensy_serialmon.exe usb:0/140000/0/8/4
Opened hid#vid_16c0&pid_0486... RawHID
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=ogstd,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_161901 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_494442 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf1.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=ogstd,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_161901 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_494442 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf1.ino
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\sketch\arf1.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/precompile_helper" "C:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901" "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch/Arduino.h" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch/Arduino.h.gch"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\sketch\arf1.ino.cpp.o"
Compiling core...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\memcpy-armv7m.S" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\memcpy-armv7m.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\memset.S" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\memset.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\analog.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\analog.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\bootdata.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\bootdata.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\clockspeed.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\clockspeed.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\debugprintf.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\debugprintf.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\delay.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\delay.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\digital.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\digital.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\eeprom.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\eeprom.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\interrupt.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\interrupt.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\keylayouts.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\keylayouts.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\nonstd.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\nonstd.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\pwm.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\pwm.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\rtc.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\rtc.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\startup.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\startup.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\tempmon.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\tempmon.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_desc.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_desc.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_rawhid.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_rawhid.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_seremu.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_seremu.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_serial.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_serial.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\AudioStream.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\AudioStream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\DMAChannel.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\DMAChannel.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\EventResponder.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\EventResponder.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial1.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial1.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial2.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial2.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial3.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial3.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial4.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial4.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial5.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial5.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial6.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial6.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial7.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial7.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial8.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial8.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\IPAddress.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\IPAddress.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\IntervalTimer.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\IntervalTimer.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\Print.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Print.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\Stream.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Stream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\Tone.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Tone.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\WMath.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\WMath.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\WString.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\WString.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\new.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\new.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_inst.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_inst.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\yield.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\yield.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\memcpy-armv7m.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\memset.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\analog.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\bootdata.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\clockspeed.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\debugprintf.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\delay.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\digital.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\eeprom.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\interrupt.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\keylayouts.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\nonstd.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\pwm.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\rtc.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\startup.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\tempmon.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_desc.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_rawhid.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_seremu.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_serial.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\AudioStream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\DMAChannel.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\EventResponder.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial1.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial2.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial3.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial4.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial5.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial6.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial7.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial8.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\IPAddress.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\IntervalTimer.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Print.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Stream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Tone.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\WMath.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\WString.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\new.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_inst.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\yield.cpp.o"
Archiving built core (caching) in: C:\Users\Dell\AppData\Local\Temp\arduino_cache_494442\core\core_teensy_avr_teensy40_usb_serial,speed_600,opt_ogstd,keys_en-us_4939f5412a75a8560acb0f9e98268f02.a
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -Og -Wl,--gc-sections,--relax "-TC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901/arf1.ino.elf" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\sketch\arf1.ino.cpp.o" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901/core\core.a" "-LC:\Users\Dell\AppData\Local\Temp\arduino_build_161901" -larm_cortexM7lfsp_math -lm -lstdc++
C:\Users\Dell\AppData\Local\Temp\arduino_build_161901/core\core.a(startup.c.o): In function `ResetHandler':
// t36 180 mhz debug w lto
// flt 85 ns dbl 541 ns
// +4.7942555E-01
// +4.794255386042030E-01
int led = 13;
double q,x,xa,y,nng,xp,ifl;
// float q,x,xa,y,nng,xp,ifl;
unsigned int i,j,n;
int main()
// Serial.begin(9600);
// delay(1000);
y=0.5L;
mloop:
i=0;
mloop2:
// x=sinf((float)ifl/200.0+0.5);
// x=sinfl((float)i/200.0+0.5);
x=sinl((long double)ifl/200.0L+0.5L);
// x=sinl(y);
// x=sinf(y);
i=i+1;
ifl=ifl+1.0;
if(i<100) goto mloop2;
// Serial.printf ("%+1.7E \n",x);
// Serial.printf ("%+1.15E \n",x);
// delay(5000);
Looks like the error appears because you used main() instead of setup() and loop(). That’s not normally supported in Arduino, but it looks like it just so happened to be supported for the T3.6 and since it’s not normal it wasn’t supported for the T4.0, likely the support can be added it just hasn’t been added at this point.
i had no idea that could be teensyduino. i will re-do one of the two cases with setup() and loop() and report results.
thank you for the feedback
Quote Originally Posted by vjmuzik View Post
@analog&RFmodels
If something builds under the IDE and fails when changing the available compile option that is noteworthy. Under Beta - here at least - most all testing was toward default compile case testing hardware and function. Certain options - some currently not present failed and just got in the way of getting the base functionality supported.
Starting point for testing posted 'Sketch' code has to be made for the IDE because anyone can repro that with standard install. And that uses standard toolchain all the base code and libraries were tested against for building so it should generally work elsewhere then.
suppose not up to release level at this point.
Kurt,
please see my previous post - most Teensy will do main() but not t4.0 yet - needs setup() and loop()
that's ok - the massive speed increase is worth having to make changes when using GNU C on the PC for testing,
and the first t4 i tested was 600=89 ma, 720=110ma, 816=133ma (not bad)
when you overclock t3.6 at 256 mhz it draws slightly over 100 ma
again, thank you for the feedback
extern int main (void);
//printf("before setup\n");
setup();
//printf("after setup\n");
while (1) {
//printf("loop\n");
loop();
yield();
main();
while (1) ;
Yup. The main reason I left it disabled in boards.txt is "seremu" isn't implemented at all. So while you can use RawHID to send packets back and forth, anything you do with Serial.print() will just discard data rather than sending to the serial monitor.
Thanks for posting over clocking currents. That’s quite a big jump at 816 MHz. I finally found my 4.0’s in a box under the bed(?!) so I can start trying afew things.
FastLed compile error
file from Examples menu - fastled - any example file
Arduino/libraries/FastLED/fastpin.h:207:2: error: static assertion failed: Invalid pin specified
static_assert(validpin(), "Invalid pin specified");
Multiple libraries were found for "FastLED.h"
Used: /Users/balam/Documents/INTER-SOFTWARE/Arduino/libraries/FastLED
Not used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED
Error compiling for board Teensy 4.0.
Try using the one included with TeensyDuino by removing the local copy from : "/Users/balam/Documents/INTER-SOFTWARE/Arduino/libraries/FastLED"
Not sure if Fastled works on T_4 - but even less clear of what local version is in that folder.
