Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 63
Thread: Teensyduino 1.48 Released
  1. #26
    4,516
    @KurtE - thanks - 1st pic with new phone
    Running sketch with no heatsink on one of my breakout boards. Just ran it at 816 and getting pretty much the same temp as you about 58 degC.
  2. #27
    big thanks for the new teensy 4 without a doubt the new teensy is a game changer!! wondering if there are near future plans to integrate Midi , HID protocols to the new new teensy 4.
    best.
  3. #28
    10,407
    I ran this yesterday but headed to bed before running it again to post. Just powered board up cold with debug_tt as last posted 7/7/2019?
    It is the @mjs513 code - with milliseconds printed along with the TEMP report - so almost 7 minutes before it crashed at last reported temp under 58įC.
    It is Stopped as shown - not taking any USB input - doing a spaz blink - and heat sink is cool so it took F_CPU down::
    T:\tCode\T4\T4-TEMPMON_buddabrot\T4-TEMPMON_buddabrot.ino Oct  8 2019 03:10:02
    >>> Reason for 'reset': 1 IPP_RESET_B :: done Reason
    F_CPU==1008000000   F_BUS==252000000 FreeMem(); 4293328836
     begin ...
    in setup @L#72	stack var addr: 0x2006FFE4
    TEMPMON driver example.
     F_CPU=1008000000	deg  C=32
    The chip initial temperature is 32.00	@ms= 2728
    31.36	@ms= 3147
    31.36	@ms= 3818
    31.36	@ms= 4489
    56.82	@ms= 416071
    56.82	@ms= 416761
    56.82	@ms= 417439
    57.45	@ms= 418131
    Fault irq 3
     stacked_r0 ::  20011BA3
     stacked_r1 ::  20070023
     stacked_r2 ::  00000060
     stacked_r3 ::  2006FFFF
     stacked_r12 ::  2001230D
     stacked_lr ::  00008211
     stacked_pc ::  0000076C
     stacked_psr ::  810B0000
     _CFSR ::  00008200
          (PRECISERR) Data bus error(address in BFAR)
          (BFARVALID) Bus Fault Address Valid
     _HFSR ::  40000000
          (FORCED) Forced Hard Fault
     _DFSR ::  00000000
     _AFSR ::  00000000
     _BFAR ::  20070000
     _MMAR ::  20070000
    in Debug_Dump @L#60	stack var addr: 0x2006FF04
     User Custom Debug Dump. Micros==418139752
     userDebugDumptt() in debug_tt  ___
     F_CPU=300000000
     >>>> Debug Fault   >>>> debug_fault   >>>> TYPE:T_4
    debug_tt Info:	[Last debug_tt helper @ L#:60  Debug_Dump()
     >>>> Debug Fault   >>>> TYPE:T_4
    --- Faulted >>>>  Execution Halted.
    For more info - print it in sketch :: Debug_Dump(void)
  4. #29
    10,407
    Nice pic @mjs513 - been wanting you to add one so your posts stand out Hope the new phone serves well.
    It seems this simple heat sink I got - same as one Frank B got IIRC - is doing the job of stopping extreme thermal buildup. Should have a set of 8 of those (similar) from Amazon today. Though as posted - something still goes awry?
    Heat Sinks just delivered … Here is ...
    debug_tt.zip
    Just rebuilt that same sketch at 960 MHz - it did not Auto Upload - so it was stuck with dead USB it seems and require Button to take code.
    Starts like this - and assume it will run some long time with no issue … we will see:
    T:\tCode\T4\T4-TEMPMON_buddabrot\T4-TEMPMON_buddabrot.ino Oct  8 2019 11:04:49
    F_CPU==960000000   F_BUS==240000000 FreeMem(); 4293328836
     begin ...
     F_CPU=960000000	deg  C=45
    The chip initial temperature is 45.36	@ms= 2731
    44.73	@ms= 3171
    Simple changes for debug_tt:
    #include "debug_tt.h"
    void Debug_Dump(void)
      where_tt( );
      printf_tt(" User Custom Debug Dump. Micros==%u", micros());
      // Put code here to call after Fault or HaltIf() - or call it in sketch
      return;
      while ( !Serial);
        delay(2000);
      debBegin_tt( (HardwareSerial*)&Serial, LED_BUILTIN, 7);
      Serial.println("\n begin ...");
      where_tt( );
    In post #28 you can see this:
    That is printed from User sketch void Debug_Dump(void) shown just above - so the fault handler WORKS and does present one last chance to dump local vars or code info when it can help.
    As far as sketch restarted at 960 MHz it is running and temp already ABOVE where it dies in prior post:
    58.73	@ms= 513748
    58.73	@ms= 514444
    61.27	@ms= 1164452
    60.64	@ms= 1165145
    60.64	@ms= 1165839
    60.64	@ms= 10074795
    60.64	@ms= 10075492
    60.00	@ms= 10076187
    Still running - 2.8 hours - room is cool … no temp climb
  5. #30
    Oct 2019
    2
    Has the experimental RawHID mode for T4 from beta#2 been disabled? All I can select is Serial from the USB Type menu.
  6. #31
    Aug 2019
    southwest USA
    50
    hi all,
    is this the right place to put this ?
    this code compiles/runs fine teensy3.6 180 mhz debug (debug only)
    but crashes during compile for teensy4.0 600 mhz debug
    am running win7pro 64 bit, Arduino 1.8.5, Teensyduino 1.48 released
    the code does not use any hardware other than led
    enclosed are code and verbose error list
    Arduino: 1.8.5 (Windows 7), TD: 1.48, Board: "Teensy 4.0, Serial, 600 MHz, Debug, US English"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=ogstd,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_917047 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_780063 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf1.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=ogstd,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_917047 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_780063 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf1.ino
    Using board 'teensy40' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Using core 'teensy4' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Detecting libraries used...
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\sketch\arf1.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\preproc\ctags_target_for_gcc_minus_e.cpp"
    "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\preproc\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/precompile_helper" "C:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047" "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047/pch/Arduino.h" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047/pch/Arduino.h.gch"
    Using previously compiled file: C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\pch\Arduino.h.gch
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_917047/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\sketch\arf1.ino.cpp.o"
    Compiling libraries...
    Compiling core...
    Using precompiled core
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -Og -Wl,--gc-sections,--relax "-TC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/imxrt1062.ld"  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047/arf1.ino.elf" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047\sketch\arf1.ino.cpp.o" "C:\Users\Dell\AppData\Local\Temp\arduino_build_917047/..\arduino_cache_780063\core\core_teensy_avr_teensy40_usb_serial,speed_600,opt_ogstd,keys_en-us_4939f5412a75a8560acb0f9e98268f02.a" "-LC:\Users\Dell\AppData\Local\Temp\arduino_build_917047" -larm_cortexM7lfsp_math -lm -lstdc++
    C:\Users\Dell\AppData\Local\Temp\arduino_build_917047/..\arduino_cache_780063\core\core_teensy_avr_teensy40_usb_serial,speed_600,opt_ogstd,keys_en-us_4939f5412a75a8560acb0f9e98268f02.a(startup.c.o): In function `ResetHandler':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/startup.c:135: undefined reference to `setup'
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/startup.c:139: undefined reference to `loop'
    // FFT W PRINT AND CONST TABLE FOR WINDOW
    // has input gen and 12 bit ad sim
    // t36 180mhz debug w lto
    // single 8.1 ms  double 54.9 ms
    // define some constants
    #define unit   1.0
    #define half   0.5
    #define two    2.0
    #define rad   57.2957795
    // define for atan, asin, acos
    #define pi     3.14159265
    #define pio2   1.57079633
    // define for sqrt
    #define sqrt2  1.41421356
    // define for log, exp
    #define ln2    0.6931471806
    #define ln10   2.30258509
      union  u {
      signed short int adin[1100];
                   float d2[256];
      union u ary;
      float d1[256];
    // all poly terms stored in one array to allow
    // ref by pointer in subroutines that are
    // called by poly solvers
      int led = 13;
      float q,x,xa,y,nng,xp;
      float t1,t2,s,c,a,m,fi,nnf,nnfr,jlf,jrf;
      unsigned short int n1,n2,n3,n4,n5,n6,n7,n8,n9,nn,il,jl;
      signed short int yi;
      unsigned short int flag;
      unsigned short int i,j,n;
      unsigned short int flg1,flg2,flg3,flg4,flg5,flg6,flg7,flg8,flg9;
      char fchar;
      signed short int r0;
      float const win [256] = {
     0.000000E+00, 4.470349E-08, 7.301569E-07, 3.591180E-06,
     1.162291E-05, 2.828241E-05, 5.851686E-05, 1.083165E-04,
     1.845211E-04, 2.951622E-04, 4.489422E-04, 6.560385E-04,
     9.270459E-04, 1.273662E-03, 1.708508E-03, 2.244964E-03,
     2.897143E-03, 3.679946E-03, 4.609019E-03, 5.700469E-03,
     6.971255E-03, 8.438721E-03, 1.012060E-02, 1.203514E-02,
     1.420127E-02, 1.663765E-02, 1.936364E-02, 2.239862E-02,
     2.576207E-02, 2.947374E-02, 3.355316E-02, 3.801981E-02,
     4.289316E-02, 4.819256E-02, 5.393678E-02, 6.014456E-02,
     6.683409E-02, 7.402332E-02, 8.172951E-02, 8.996935E-02,
     9.875893E-02, 1.081136E-01, 1.180480E-01, 1.285761E-01,
     1.397107E-01, 1.514639E-01, 1.638466E-01, 1.768690E-01,
     1.905398E-01, 2.048672E-01, 2.198576E-01, 2.355164E-01,
     2.518480E-01, 2.688551E-01, 2.865396E-01, 3.049015E-01,
     3.239399E-01, 3.436521E-01, 3.640344E-01, 3.850816E-01,
     4.067865E-01, 4.291414E-01, 4.521362E-01, 4.757600E-01,
     5.000001E-01, 5.248423E-01, 5.502715E-01, 5.762705E-01,
     6.028209E-01, 6.299029E-01, 6.574955E-01, 6.855760E-01,
     7.141204E-01, 7.431040E-01, 7.724999E-01, 8.022808E-01,
     8.324174E-01, 8.628799E-01, 8.936374E-01, 9.246574E-01,
     9.559069E-01, 9.873516E-01, 1.018957E+00, 1.050687E+00,
     1.082504E+00, 1.114373E+00, 1.146254E+00, 1.178109E+00,
     1.209899E+00, 1.241586E+00, 1.273128E+00, 1.304487E+00,
     1.335621E+00, 1.366490E+00, 1.397055E+00, 1.427274E+00,
     1.457107E+00, 1.486514E+00, 1.515456E+00, 1.543891E+00,
     1.571783E+00, 1.599092E+00, 1.625779E+00, 1.651807E+00,
     1.677141E+00, 1.701743E+00, 1.725578E+00, 1.748613E+00,
     1.770814E+00, 1.792149E+00, 1.812588E+00, 1.832100E+00,
     1.850656E+00, 1.868231E+00, 1.884797E+00, 1.900330E+00,
     1.914808E+00, 1.928208E+00, 1.940512E+00, 1.951700E+00,
     1.961755E+00, 1.970664E+00, 1.978412E+00, 1.984987E+00,
     1.990381E+00, 1.994585E+00, 1.997592E+00, 1.999398E+00,
     2.000000E+00, 1.999398E+00, 1.997592E+00, 1.994585E+00,
     1.990381E+00, 1.984987E+00, 1.978412E+00, 1.970664E+00,
     1.961755E+00, 1.951700E+00, 1.940512E+00, 1.928208E+00,
     1.914808E+00, 1.900330E+00, 1.884797E+00, 1.868231E+00,
     1.850656E+00, 1.832100E+00, 1.812588E+00, 1.792149E+00,
     1.770814E+00, 1.748613E+00, 1.725578E+00, 1.701742E+00,
     1.677140E+00, 1.651807E+00, 1.625779E+00, 1.599091E+00,
     1.571783E+00, 1.543891E+00, 1.515455E+00, 1.486514E+00,
     1.457107E+00, 1.427274E+00, 1.397055E+00, 1.366490E+00,
     1.335621E+00, 1.304487E+00, 1.273128E+00, 1.241586E+00,
     1.209899E+00, 1.178109E+00, 1.146254E+00, 1.114373E+00,
     1.082504E+00, 1.050686E+00, 1.018957E+00, 9.873512E-01,
     9.559069E-01, 9.246574E-01, 8.936372E-01, 8.628797E-01,
     8.324171E-01, 8.022803E-01, 7.724995E-01, 7.431036E-01,
     7.141205E-01, 6.855759E-01, 6.574953E-01, 6.299028E-01,
     6.028206E-01, 5.762701E-01, 5.502716E-01, 5.248424E-01,
     5.000000E-01, 4.757598E-01, 4.521360E-01, 4.291411E-01,
     4.067863E-01, 3.850812E-01, 3.640345E-01, 3.436521E-01,
     3.239397E-01, 3.049013E-01, 2.865393E-01, 2.688549E-01,
     2.518480E-01, 2.355164E-01, 2.198575E-01, 2.048671E-01,
     1.905398E-01, 1.768688E-01, 1.638464E-01, 1.514637E-01,
     1.397107E-01, 1.285761E-01, 1.180480E-01, 1.081136E-01,
     9.875878E-02, 8.996922E-02, 8.172954E-02, 7.402332E-02,
     6.683411E-02, 6.014448E-02, 5.393672E-02, 4.819247E-02,
     4.289310E-02, 3.801984E-02, 3.355316E-02, 2.947377E-02,
     2.576209E-02, 2.239856E-02, 1.936355E-02, 1.663765E-02,
     1.420123E-02, 1.203514E-02, 1.012062E-02, 8.438602E-03,
     6.971300E-03, 5.700529E-03, 4.609034E-03, 3.679931E-03,
     2.897143E-03, 2.244890E-03, 1.708493E-03, 1.273632E-03,
     9.270012E-04, 6.559640E-04, 4.489422E-04, 2.951920E-04,
     1.846105E-04, 1.084060E-04, 5.850196E-05, 2.829731E-05,
     1.163781E-05, 3.606081E-06, 7.450581E-07, 0.000000E+00,
      float const h[33]={
      3.306290E-04, 8.395911E-04, 1.004346E-03,-1.057719E-03,
     -6.058753E-03,-8.971486E-03,-1.786884E-08, 2.332381E-02,
      4.172762E-02, 2.006667E-02,-5.539681E-02,-1.355107E-01,
     -1.151403E-01, 9.022949E-02, 4.507063E-01, 8.036606E-01,
      9.509602E-01, 8.036606E-01, 4.507062E-01, 9.022947E-02,
     -1.151403E-01,-1.355106E-01,-5.539678E-02, 2.006667E-02,
      4.172761E-02, 2.332380E-02,-1.786883E-08,-8.971481E-03,
     -6.058748E-03,-1.057718E-03, 1.004345E-03, 8.395896E-04,
      3.306290E-04, };
        signed short int const ad[1100]={
        +0,    +76,   +154,   +230,   +304,   +378,   +450,   +522,   +594,   +662,
      +730,   +794,   +856,   +914,   +970,  +1024,  +1074,  +1124,  +1168,  +1210,
     +1248,  +1282,  +1312,  +1340,  +1364,  +1386,  +1404,  +1420,  +1432,  +1438,
     +1442,  +1444,  +1442,  +1438,  +1434,  +1426,  +1416,  +1402,  +1386,  +1368,
     +1348,  +1328,  +1308,  +1286,  +1264,  +1240,  +1216,  +1190,  +1164,  +1138,
     +1114,  +1090,  +1068,  +1046,  +1022,  +1000,   +978,   +958,   +940,   +924,
      +908,   +896,   +882,   +870,   +858,   +848,   +840,   +834,   +830,   +826,
      +824,   +822,   +818,   +818,   +816,   +816,   +818,   +820,   +822,   +824,
      +824,   +822,   +820,   +820,   +818,   +814,   +810,   +806,   +798,   +788,
      +776,   +762,   +746,   +728,   +710,   +688,   +664,   +636,   +604,   +572,
      +536,   +498,   +458,   +416,   +370,   +322,   +270,   +216,   +160,   +102,
       +44,    -16,    -78,   -142,   -210,   -278,   -346,   -416,   -486,   -554,
      -624,   -692,   -762,   -832,   -900,   -968,  -1034,  -1098,  -1160,  -1220,
     -1278,  -1334,  -1390,  -1442,  -1490,  -1534,  -1576,  -1614,  -1648,  -1680,
     -1708,  -1734,  -1754,  -1772,  -1784,  -1792,  -1796,  -1796,  -1794,  -1788,
     -1780,  -1766,  -1750,  -1728,  -1704,  -1676,  -1646,  -1614,  -1580,  -1544,
     -1504,  -1462,  -1418,  -1370,  -1324,  -1276,  -1228,  -1178,  -1130,  -1078,
     -1026,   -974,   -924,   -874,   -824,   -776,   -728,   -682,   -636,   -592,
      -548,   -506,   -466,   -428,   -394,   -360,   -328,   -296,   -266,   -238,
      -212,   -190,   -168,   -150,   -132,   -114,    -98,    -82,    -70,    -58,
       -46,    -38,    -28,    -18,    -10,     +2,    +10,    +20,    +30,    +38,
       +48,    +60,    +72,    +86,   +102,   +120,   +136,   +156,   +174,   +196,
      +220,   +246,   +276,   +306,   +338,   +370,   +406,   +442,   +480,   +520,
      +562,   +608,   +652,   +698,   +746,   +792,   +842,   +892,   +942,   +994,
     +1046,  +1096,  +1148,  +1196,  +1244,  +1292,  +1340,  +1388,  +1434,  +1476,
     +1518,  +1556,  +1592,  +1626,  +1656,  +1686,  +1712,  +1736,  +1754,  +1770,
     +1782,  +1788,  +1794,  +1794,  +1792,  +1786,  +1778,  +1764,  +1744,  +1722,
     +1694,  +1666,  +1632,  +1598,  +1558,  +1516,  +1468,  +1418,  +1366,  +1310,
     +1254,  +1194,  +1134,  +1072,  +1006,   +940,   +870,   +802,   +732,   +662,
      +594,   +524,   +456,   +386,   +316,   +248,   +180,   +114,    +52,    -10,
       -70,   -128,   -186,   -240,   -294,   -344,   -392,   -434,   -476,   -516,
      -552,   -588,   -620,   -650,   -676,   -700,   -720,   -738,   -754,   -770,
      -782,   -794,   -804,   -810,   -814,   -818,   -820,   -822,   -824,   -824,
      -826,   -824,   -824,   -822,   -820,   -818,   -818,   -820,   -822,   -824,
      -826,   -830,   -832,   -838,   -846,   -854,   -864,   -876,   -890,   -902,
      -916,   -932,   -950,   -968,   -990,  -1012,  -1034,  -1056,  -1080,  -1102,
     -1126,  -1150,  -1176,  -1202,  -1228,  -1252,  -1276,  -1296,  -1318,  -1338,
     -1358,  -1378,  -1394,  -1410,  -1422,  -1432,  -1438,  -1442,  -1446,  -1446,
     -1444,  -1438,  -1430,  -1416,  -1400,  -1380,  -1356,  -1332,  -1302,  -1272,
     -1236,  -1196,  -1152,  -1106,  -1056,  -1004,   -950,   -894,   -834,   -772,
      -706,   -638,   -568,   -496,   -424,   -350,   -276,   -202,   -126,    -48,
       +30,   +108,   +184,   +260,   +334,   +406,   +480,   +550,   +622,   +690,
      +756,   +820,   +880,   +936,   +992,  +1044,  +1094,  +1142,  +1186,  +1226,
     +1262,  +1294,  +1324,  +1350,  +1374,  +1394,  +1412,  +1424,  +1434,  +1440,
     +1444,  +1444,  +1442,  +1438,  +1430,  +1422,  +1410,  +1396,  +1378,  +1360,
     +1340,  +1320,  +1300,  +1278,  +1254,  +1230,  +1206,  +1180,  +1154,  +1128,
     +1104,  +1082,  +1058,  +1036,  +1014,   +992,   +970,   +952,   +934,   +918,
      +904,   +890,   +878,   +866,   +854,   +844,   +838,   +832,   +828,   +824,
      +822,   +820,   +818,   +816,   +816,   +818,   +818,   +820,   +822,   +824,
      +824,   +822,   +820,   +818,   +816,   +814,   +808,   +802,   +794,   +784,
      +770,   +756,   +740,   +722,   +702,   +678,   +652,   +624,   +592,   +558,
      +520,   +482,   +442,   +398,   +352,   +302,   +250,   +194,   +138,    +80,
       +20,    -42,   -104,   -170,   -236,   -304,   -374,   -444,   -512,   -582,
      -650,   -720,   -790,   -860,   -928,   -996,  -1060,  -1124,  -1184,  -1244,
     -1300,  -1356,  -1410,  -1462,  -1508,  -1552,  -1592,  -1628,  -1660,  -1692,
     -1718,  -1742,  -1762,  -1776,  -1788,  -1794,  -1796,  -1796,  -1792,  -1786,
     -1774,  -1760,  -1742,  -1718,  -1692,  -1664,  -1634,  -1600,  -1566,  -1528,
     -1488,  -1444,  -1398,  -1352,  -1304,  -1256,  -1208,  -1160,  -1108,  -1058,
     -1006,   -954,   -904,   -854,   -804,   -758,   -710,   -664,   -618,   -574,
      -530,   -490,   -450,   -414,   -380,   -346,   -314,   -284,   -254,   -228,
      -204,   -182,   -162,   -142,   -124,   -108,    -92,    -78,    -64,    -52,
       -42,    -34,    -24,    -14,     -6,     +6,    +14,    +24,    +34,    +42,
       +52,    +64,    +78,    +94,   +110,   +126,   +144,   +162,   +184,   +206,
      +230,   +258,   +288,   +318,   +350,   +384,   +420,   +456,   +496,   +536,
      +580,   +626,   +672,   +718,   +764,   +812,   +862,   +912,   +962,  +1014,
     +1066,  +1118,  +1166,  +1216,  +1264,  +1312,  +1360,  +1406,  +1450,  +1494,
     +1534,  +1570,  +1606,  +1638,  +1668,  +1696,  +1722,  +1744,  +1762,  +1776,
     +1784,  +1792,  +1794,  +1794,  +1790,  +1784,  +1772,  +1756,  +1736,  +1712,
     +1684,  +1652,  +1618,  +1582,  +1542,  +1498,  +1450,  +1398,  +1344,  +1288,
     +1230,  +1170,  +1110,  +1046,   +980,   +912,   +844,   +774,   +704,   +636,
      +566,   +498,   +428,   +358,   +288,   +220,   +154,    +90,    +26,    -34,
       -94,   -152,   -208,   -262,   -314,   -364,   -408,   -452,   -492,   -530,
      -566,   -600,   -632,   -660,   -686,   -708,   -728,   -744,   -760,   -774,
      -788,   -798,   -806,   -812,   -816,   -818,   -820,   -822,   -824,   -826,
      -826,   -824,   -822,   -820,   -818,   -818,   -820,   -820,   -822,   -824,
      -828,   -830,   -834,   -840,   -848,   -858,   -870,   -882,   -894,   -908,
      -922,   -938,   -956,   -976,   -998,  -1020,  -1042,  -1066,  -1088,  -1112,
     -1136,  -1160,  -1186,  -1212,  -1238,  -1262,  -1284,  -1306,  -1326,  -1346,
     -1366,  -1384,  -1400,  -1414,  -1426,  -1434,  -1440,  -1444,  -1446,  -1446,
     -1442,  -1436,  -1424,  -1410,  -1392,  -1370,  -1346,  -1320,  -1290,  -1258,
     -1220,  -1180,  -1134,  -1086,  -1036,   -982,   -928,   -870,   -808,   -746,
      -678,   -610,   -538,   -466,   -394,   -322,   -246,   -172,    -94,    -16,
       +62,   +138,   +214,   +290,   +364,   +436,   +508,   +580,   +650,   +716,
      +782,   +844,   +902,   +958,  +1012,  +1064,  +1114,  +1160,  +1202,  +1242,
     +1276,  +1306,  +1334,  +1360,  +1382,  +1402,  +1418,  +1430,  +1438,  +1442,
     +1444,  +1442,  +1440,  +1434,  +1428,  +1418,  +1404,  +1390,  +1372,  +1352,
     +1332,  +1312,  +1290,  +1268,  +1246,  +1220,  +1194,  +1168,  +1144,  +1120,
     +1096,  +1072,  +1050,  +1028,  +1004,   +984,   +962,   +944,   +926,   +912,
      +898,   +884,   +872,   +860,   +850,   +842,   +834,   +830,   +826,   +824,
      +822,   +820,   +818,   +816,   +816,   +818,   +820,   +822,   +822,   +824,
      +822,   +822,   +820,   +818,   +816,   +812,   +806,   +800,   +790,   +778,
      +764,   +748,   +732,   +714,   +692,   +668,   +642,   +612,   +578,   +542,
      +506,   +466,   +424,   +380,   +332,   +282,   +228,   +172,   +114,    +56,
        -4,    -66,   -130,   -196,   -264,   -332,   -402,   -472,   -540,   -610,
      -678,   -748,   -818,   -886,   -956,  -1022,  -1086,  -1148,  -1208,  -1266,
     -1324,  -1378,  -1432,  -1480,  -1526,  -1568,  -1606,  -1642,  -1674,  -1702,
     -1728,  -1750,  -1768,  -1782,  -1790,  -1796,  -1796,  -1794,  -1790,  -1782,
     -1770,  -1754,  -1732,  -1708,  -1682,  -1652,  -1620,  -1588,  -1550,  -1512,
     -1470,  -1426,  -1380,  -1334,  -1286,  -1238,  -1188,  -1140,  -1088,  -1038,
      -986,   -934,   -884,   -834,   -786,   -738,   -692,   -646,   -600,   -556,
      -514,   -474,   -436,   -400,   -366,   -334,   -302,   -272,   -244,   -218,
      -194,   -172,   -154,   -136,   -118,   -102,    -86,    -72,    -60,    -48,
       -40,    -30,    -20,    -10,     -2,     +8,    +18,    +28,    +38,    +46,
       +58,    +70,    +84,   +100,   +116,   +134,   +152,   +170,   +192,   +216,
      +242,   +270,   +300,   +332,   +364,   +398,   +434,   +472,   +512,   +554,
      +598,   +644,   +690,   +736,   +784,   +832,   +882,   +932,   +984,  +1036,
     +1086,  +1138,  +1186,  +1236,  +1284,  +1332,  +1378,  +1424,  +1468,  +1510,
     +1548,  +1586,  +1618,  +1650,  +1680,  +1706,  +1730,  +1752,  +1768,  +1780,
     +1788,  +1792,  +1794,  +1794,  +1788,  +1780,  +1766,  +1748,  +1726,  +1700,
     +1672,  +1640,  +1604,  +1566,  +1524,  +1478,  +1430,  +1376,  +1322,  +1264,
      void pfps() {
    int  main()
      pinMode(led, OUTPUT);
    // 256 input points
    // 128 ouput points
     mloop:
      nn=256;
      nnf=256.0;
      nng=1024.0;
      n5=1100;
      fi=1.0;
    // clear array d1
      for(jl=0;jl <= (nn-1);++jl)
        d1[jl]=0.0;
    // clear array adin
      for(jl=0;jl <= n5;++jl)
        ary.adin[jl]=0.0;
    // fill input array 3 terms
    // and round to 12 bit ints
        fchar=5;
        xa=0;
      for(jl=0;jl<(n5-1);++jl)
        ary.adin[jl]=ad[jl];
    //    xp=ary.adin[jl];
    //    pfps();
    //  do sinc filter
      n=32;
      n4=32;
      jl=n5;
    loop1:
       y=0;
        i=0;
    loop2:
        q=ary.adin[jl-i];
        q=q*h[i];
        y=y+q;
        ++i;
        if (i < n) goto loop2;
        yi=(signed short int)y;
        ary.adin[jl]=yi;
    //    xp=yi;
    //    pfps();
        jl=jl-1;
        if (jl >= n4) goto loop1;
    // do decimate by 4
      jl=0;
    loop3:
      il=jl+8;
      il=il*4;
      yi=ary.adin[il];
      d1[jl]=(float)(yi/1.0);
    //  xp=d1[jl];
    //  pfps();
      ++jl;
      if (jl < (nn-1)) goto loop3;
    // do window
        n9=nn-1;
      for(jl=0;jl <= n9;++jl)
        x=d1[jl];
        y=win[jl];
        x=x*y;
        d1[jl]=x;
    //    xp=x;
    //    pfps();
    // clear array d2 of union leftovers
        n9=nn-1;
        ary.d2[jl]=0.0;
    // do fft
      n1=0;
      n2=nn-1;
      for(n3=1;n3<=n2;++n3)
        n4=nn;
      l1470:
        n4=n4/2;
        if((n1+n4) > n2) goto l1470;
        n1=n1-((n1/n4)*n4)+n4;
        if(n1 <= n3)goto l1520;
        t1=d1[n3];
        xa=d1[n1];
        d1[n3]=xa;
        d1[n1]=t1;
        t2=ary.d2[n3];
        xa=ary.d2[n1];
        ary.d2[n3]=xa;
        ary.d2[n1]=t2;
      l1520:
      n4=n4;
        n4=1;
      l1530:
        n6=n4*2;
      for(n3=0;n3<=(n4-1);++n3)
        a=fi*(float)n3;
        a=a*pi;
        a=a/(float)n4;
        x=a;
    //  fchar=5;
    //  sincos();
        x=sinf(x);
    //    x=sinl(x);
    //    x=sinfl(x);
        s=x;
        x=a;
    //  fchar=6;
    //  sincos();
        x=cosf(x);
    //    x=cosl(x);
    //    x=cosfl(x);
        c=x;
      for(n7=n3;n7<=(nn-1);n7=(n7+n6))
        n8=n7+n4;
        x=d1[n8];
        y=ary.d2[n8];
        t1=c*x;
        t1=t1-(s*y);
        t2=c*y;
        t2=t2+s*x;
        x=d1[n7];
        y=ary.d2[n7];
        d1[n8]=x-t1;
        ary.d2[n8]=y-t2;
        d1[n7]=x+t1;
        ary.d2[n7]=y+t2;
        n4=n6;
        if(n4 < nn) goto l1530;
    // do post fft proc
      nnfr=1.0/nnf;
      nn=nn/2;
      nn=nn-1;
      for(il=0;il<=nn;++il)
        x=d1[il]*d1[il];
        x=x+ary.d2[il]*ary.d2[il];
        x=sqrtf(x);
        d1[il]=x*nnfr;
        xp=d1[il];
        pfps();
        if (flag == 0) {flag=1; digitalWrite(led, HIGH); goto mloop;}
        if (flag == 1) {flag=0; digitalWrite(led,  LOW); goto mloop;}
  7. #32
    5,981
    @analog&RFmodels
    I am not sure how you are compiling this for a T3.6? As I don't see any standard Arduino sketch stuff, like the void setup() {} function or or the void loop() {} function.
    And it has a main function...
    Maybe you were using a makefile?
  8. #33
    Aug 2019
    southwest USA
    50
    main() in Teensy 4 bug example
    @analog&RFmodels
    hi Kurt,
    i just got tired of having to make slight code changes between Arduino and GNU C compiler on the PC
    (i test what i can on the PC) so i tried to see if Arduino would take a standard format and i could
    keep track of "once at start" and "loop" myself. turned out Arduino works just fine if you do the code
    the way you see there. i am not a real programmer. you were sharp to notice.
  9. #34
    10,407
    Quote Originally Posted by prnthp View Post
    Was it enabled in Beta 1 or 2 ? it is in boards.txt under comment - not sure of the functional level - suppose not up to release level at this point.
    To enable for test remove '#' to uncomment these lines perhaps:
    #teensy40.menu.usb.rawhid=Raw HID
    #teensy40.menu.usb.rawhid.build.usbtype=USB_RAWHID
    #teensy40.menu.usb.rawhid.fake_serial=teensy_gateway
    I did that and it builds but don't see anything beyond connect so there may be more needed to enable it as Serial.prints don't show.
    From Command line:
    T:\arduino_1.8.10\hardware\tools>teensy_serialmon.exe usb:0/140000/0/8/4
    Opened hid#vid_16c0&pid_0486... RawHID
  10. #35
    Aug 2019
    southwest USA
    50
    another case of arduino 1.8.5 and teensyduinod 1.48 released never compiles- at least nothing i have tried will compile.
    running win7 pro x64
    first case i posted was earlier today - maybe 4 posts back
    in all cases choose teensy3.6 180 mhz debug - compile and run.
    in all cases choose teensy4.0 600 mhz debug - compile crash - always seems to be same reason.
    and that reason is two problems in startup.c - both undefined reference.
    i realized that the error list is always longer on first compile (verbose all cases) so this time used shorter simpler program
    and included the longer error listing - both enclosed. long error listing is very long - say the word and
    i will only include the error list from the second compile in the future
    first case was earlier today - an fft pgm.
    so sadly i seem not to be able to get on the air with teensy 4.0
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=ogstd,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_161901 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_494442 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf1.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=ogstd,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_161901 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_494442 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf1.ino
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\sketch\arf1.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\preproc\ctags_target_for_gcc_minus_e.cpp"
    "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\preproc\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/precompile_helper" "C:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901" "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch/Arduino.h" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch/Arduino.h.gch"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\sketch\arf1.ino.cpp.o"
    Compiling core...
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\memcpy-armv7m.S" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\memcpy-armv7m.S.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\memset.S" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\memset.S.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\analog.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\analog.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\bootdata.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\bootdata.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\clockspeed.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\clockspeed.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\debugprintf.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\debugprintf.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\delay.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\delay.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\digital.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\digital.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\eeprom.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\eeprom.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\interrupt.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\interrupt.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\keylayouts.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\keylayouts.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\nonstd.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\nonstd.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\pwm.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\pwm.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\rtc.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\rtc.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\startup.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\startup.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\tempmon.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\tempmon.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_desc.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_desc.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_rawhid.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_rawhid.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_seremu.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_seremu.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_serial.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_serial.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\AudioStream.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\AudioStream.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\DMAChannel.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\DMAChannel.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\EventResponder.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\EventResponder.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial1.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial1.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial2.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial2.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial3.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial3.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial4.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial4.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial5.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial5.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial6.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial6.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial7.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial7.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial8.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial8.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\IPAddress.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\IPAddress.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\IntervalTimer.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\IntervalTimer.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\Print.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Print.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\Stream.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Stream.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\Tone.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Tone.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\WMath.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\WMath.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\WString.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\WString.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\new.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\new.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_inst.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_inst.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Og -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_161901/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\yield.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\yield.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\memcpy-armv7m.S.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\memset.S.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\analog.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\bootdata.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\clockspeed.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\debugprintf.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\delay.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\digital.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\eeprom.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\interrupt.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\keylayouts.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\nonstd.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\pwm.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\rtc.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\startup.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\tempmon.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_desc.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_rawhid.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_seremu.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_serial.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\AudioStream.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\DMAChannel.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\EventResponder.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial1.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial2.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial3.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial4.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial5.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial6.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial7.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\HardwareSerial8.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\IPAddress.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\IntervalTimer.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Print.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Stream.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\Tone.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\WMath.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\WString.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\new.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\usb_inst.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\core\yield.cpp.o"
    Archiving built core (caching) in: C:\Users\Dell\AppData\Local\Temp\arduino_cache_494442\core\core_teensy_avr_teensy40_usb_serial,speed_600,opt_ogstd,keys_en-us_4939f5412a75a8560acb0f9e98268f02.a
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -Og -Wl,--gc-sections,--relax "-TC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/imxrt1062.ld"  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901/arf1.ino.elf" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901\sketch\arf1.ino.cpp.o" "C:\Users\Dell\AppData\Local\Temp\arduino_build_161901/core\core.a" "-LC:\Users\Dell\AppData\Local\Temp\arduino_build_161901" -larm_cortexM7lfsp_math -lm -lstdc++
    C:\Users\Dell\AppData\Local\Temp\arduino_build_161901/core\core.a(startup.c.o): In function `ResetHandler':
    // t36 180 mhz debug w lto
    // flt 85 ns   dbl  541 ns
    // +4.7942555E-01
    // +4.794255386042030E-01
      int led = 13;
      double q,x,xa,y,nng,xp,ifl;
    //  float q,x,xa,y,nng,xp,ifl;
      unsigned int i,j,n;
    int main()
    //  Serial.begin(9600);
    //  delay(1000);
      y=0.5L;
     mloop:
      i=0;
     mloop2:
    //    x=sinf((float)ifl/200.0+0.5);
    //    x=sinfl((float)i/200.0+0.5);
        x=sinl((long double)ifl/200.0L+0.5L);
    //      x=sinl(y);
    //      x=sinf(y);
        i=i+1;
        ifl=ifl+1.0;
        if(i<100) goto mloop2;
    //    Serial.printf ("%+1.7E \n",x);
    //    Serial.printf ("%+1.15E \n",x);
    //    delay(5000);
    Last edited by analog&RFmodels; 10-09-2019 at 04:09 AM. Reason: wording clearer again
  11. #36
    Apr 2017
    Florida
    457
    Looks like the error appears because you used main() instead of setup() and loop(). That’s not normally supported in Arduino, but it looks like it just so happened to be supported for the T3.6 and since it’s not normal it wasn’t supported for the T4.0, likely the support can be added it just hasn’t been added at this point.
  12. #37
    Aug 2019
    southwest USA
    50
    Quote Originally Posted by vjmuzik View Post
    Looks like the error appears because you used main() instead of setup() and loop(). Thatís not normally supported in Arduino, but it looks like it just so happened to be supported for the T3.6 and since itís not normal it wasnít supported for the T4.0, likely the support can be added it just hasnít been added at this point.
    i had no idea that could be teensyduino. i will re-do one of the two cases with setup() and loop() and report results.
    thank you for the feedback
  13. #38
    10,407
    Quote Originally Posted by analog&RFmodels View Post
    If something builds under the IDE and fails when changing the available compile option that is noteworthy. Under Beta - here at least - most all testing was toward default compile case testing hardware and function. Certain options - some currently not present failed and just got in the way of getting the base functionality supported.
    Starting point for testing posted 'Sketch' code has to be made for the IDE because anyone can repro that with standard install. And that uses standard toolchain all the base code and libraries were tested against for building so it should generally work elsewhere then.
  14. #39
    Aug 2019
    southwest USA
    50
    you were right - t4 cannot use main() - must use setup() and loop()
    fyi- teensy lc,3.5,and 3.6 are all ok with main() - so i just thought that it was a given
    thank you having such insight - the error message would never have taken me there
    it is quite unbelievable how fast t4.0 at default 600 mhz. the double/single float execute
    time ratio is similar to the pic 32mz so not a big surprise (t4 much faster absolute) but the
    execute time ratio rel to t3.6 at 180 mhz is fantastic. Teensy 4.0 outruns the Cray1 crunching
    dbl precision floats ! I know there are faster processors but for my work speed only is not
    the point - fast AND small AND 100 ma is the point.
    thanks again for the feedback
  15. #40
    Aug 2019
    southwest USA
    50
    @analog&RFmodels
    Kurt,
    please see my previous post - most Teensy will do main() but not t4.0 yet - needs setup() and loop()
    that's ok - the massive speed increase is worth having to make changes when using GNU C on the PC for testing,
    and the first t4 i tested was 600=89 ma, 720=110ma, 816=133ma (not bad)
    when you overclock t3.6 at 256 mhz it draws slightly over 100 ma
    again, thank you for the feedback
  16. #41
    Aug 2019
    southwest USA
    50
    i think i see your point - i will dump using main() - it is not that much trouble to go back to main() when testing under GNU C on the PC
    thanks for the feedback
  17. #42
    21,128
    Yup. The main reason I left it disabled in boards.txt is "seremu" isn't implemented at all. So while you can use RawHID to send packets back and forth, anything you do with Serial.print() will just discard data rather than sending to the serial monitor.
  18. #43
    May 2015
    393
    Thanks for posting over clocking currents. That’s quite a big jump at 816 MHz. I finally found my 4.0’s in a box under the bed(?!) so I can start trying afew things.
  19. #44
    5,981
    Kurt,
    Maybe it won't be too hard to get the T4 to act the same as the T3.x
    If I get a chance I will try it and maybe issue a PR... Or if someone gets it done before me... That would be great.
    I believe that it might be as simple as:
    a) Copy main.cpp from cores\teensy3 to cores\teensy4
    b) Change cores\teensy4\startup.c.
    Somewhere toward the top add in a line like:
    extern int main (void);
    Then in the ResetHandler function, replace the code:
    	//printf("before setup\n");
    	setup();
    	//printf("after setup\n");
    	while (1) {
    		//printf("loop\n");
    		loop();
    		yield();
    with:
    	main();
    	while (1) ;
    And then see if it fixes the problem AND also verify normal Arduino sketches still work...
  20. #45
    Oct 2019
    2
    Thanks for the clarification, raw packets is all I need!
  21. #46
    Aug 2019
    southwest USA
    50
    Kurt,
    i am a dummy - after seeing your post i realize that the error messages should have led me where i needed to go,
    but since i had not ever been using setup() and loop() for the last two years and had forgotten about them i
    thought the error message meant some missing setup and loop reference inside one of the system files - not in
    my source file - everyone saw that connection except me
  22. #47
    FastLed compile error
    file from Examples menu - fastled - any example file
    Arduino/libraries/FastLED/fastpin.h:207:2: error: static assertion failed: Invalid pin specified
    static_assert(validpin(), "Invalid pin specified");
    Multiple libraries were found for "FastLED.h"
    Used: /Users/balam/Documents/INTER-SOFTWARE/Arduino/libraries/FastLED
    Not used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED
  23. #48
    Aug 2019
    southwest USA
    50
    Quote Originally Posted by DaQue View Post
    Thanks for posting over clocking currents. Thatís quite a big jump at 816 MHz. I finally found my 4.0ís in a box under the bed(?!) so I can start trying afew things.
    you will be impressed
    yes - at a glance the 133 looks big but the clk/iq stays fairly constant - the proportionality only
    grows 10 percent over that range
    89/600 = 0.148 110/720 = 0.153 133/816 = 0.163
    i am going to do some tests where t4 is in a relatively small sealed enclosure and see what clk
    rate can be sustained
  24. #49
    10,407
    Quote Originally Posted by Balam View Post
    Try using the one included with TeensyDuino by removing the local copy from : "/Users/balam/Documents/INTER-SOFTWARE/Arduino/libraries/FastLED"
    Not sure if Fastled works on T_4 - but even less clear of what local version is in that folder.
  25. #50
    it compiles !!!!!
