Results 1 to 1 of 1
Thread: Teensyduino 1.48 does not create HID devices
    Mar 2019
    United Kingdom
    6
    I've just updated my various development PC's to Arduino 1.8.10 and Teensyduino 1.48, and find that I can no longer create HID devices. I'm looking specifically at anything with a joystick in it. This was working fine for me up until the update.
    As an example of what is happening, I have just tried to load a program to a 3.6 that had previously been used so it already had a com port (7 in this case). the program apparently compiled OK and also seemed to upload OK, however no HID device was created in windows, and if I look in the IDE, the serial port is no longer there and I am back to a similar identifier as with a new device. Screenshots 1 & 2 attached show this.
    I tried again with 'Everything' and while it appeared to make a port, nothing appeared in windows.
    I tried again with Serial, Keyboard, Mouse, Joystick and got the a similar result see screenshots 4 & 5.
    I have had occasions where a device does appear in windows, but it is at the bottom of the devices panel, and is permanently labelled as 'configuring device'
    I done the update on 3 of my 4 regular PC's and get the same result on all of them.
    I've attached the source code for the program I was trying to use.
    Any thoughts would be welcome, before I uninstall and try to go back to the previous version.
Name:	Screenshot 1 Keyboard-Mouse-Joystick.jpg
ID:	18106Click image for larger version.
Name:	Screenshot 2 KMJ Devices view.jpg
ID:	18107Click image for larger version.
Name:	Screenshot3 everything.jpg
ID:	18108Click image for larger version.
Name:	Screenshot 4 Serial Mouse Keyboard Joystick.jpg
ID:	18109Click image for larger version.
Name:	Screenshot 5 SMKJ Devices view.jpg
    Attached Files Attached Files
