Results 1 to 5 of 5
Thread: PC time sync from Arduino
    Oct 2019
    6
    Hi, I`m reading with Teensy 3.2 time protocol from Time server via serial line , and want to send received date/ time to PC via RS422. The best will be to emmulate with Teensy some some standard protocol, which is PC able to automatic synchronise time with.
    I find lot of programs, how to sync Arduino time from PC, but nothing like I need: how to sync PC time from Arduino.
    Can somebody help me with some useful links?
    Aug 2017
    139
    Quote Originally Posted by ddano007 View Post
    Have you checked this yet?
    https://www.pjrc.com/teensy/td_libs_Time.html
    Maybe there's a way to adapt some of these methods to what you need
    Oct 2019
    6
    Thanks for tips, I`m going to check it, however it`s seems to be Teensy`s synchro with external source and I need opposite way...
    Apr 2017
    Florida
    402
    The only way I can think of would be to setup a NTP server with the Teensy, I don't think the current Ethernet library has any examples of this, just an NTP client. It would depend on your OS but I don't know if any OS has a way for a program to set the system time besides telling the time to sync with an NTP server.
    Oct 2019
    6
    OK, I found nothing useful for me, so I`m sending simple time string and in PC will be a program reading this and synchronize the time.
    However thanks for You comments.
