PC time sync from Arduino
ddano007
Hi, I`m reading with Teensy 3.2 time protocol from Time server via serial line , and want to send received date/ time to PC via RS422. The best will be to emmulate with Teensy some some standard protocol, which is PC able to automatic synchronise time with.
I find lot of programs, how to sync Arduino time from PC, but nothing like I need: how to sync PC time from Arduino.
Can somebody help me with some useful links?
Have you checked this yet?
https://www.pjrc.com/teensy/td_libs_Time.html
Maybe there's a way to adapt some of these methods to what you need:)
Thanks for tips, I`m going to check it, however it`s seems to be Teensy`s synchro with external source and I need opposite way...
The only way I can think of would be to setup a NTP server with the Teensy, I don't think the current Ethernet library has any examples of this, just an NTP client. It would depend on your OS but I don't know if any OS has a way for a program to set the system time besides telling the time to sync with an NTP server.
OK, I found nothing useful for me, so I`m sending simple time string and in PC will be a program reading this and synchronize the time.
However thanks for You comments.
