Results 1 to 7 of 7
Thread: Teensy4.0 does not receive data longer than 62 characters
    Hello everybody. I'm writing a simple communication program with Teensy 4.0.
    Please give me a hint as data reception from the terminal does not go well.
    In the attached program, if I send characters over 62 bytes to Teensy4.0, it will no longer respond.
    Where is my mistake?
    String    hostString = "";
      Serial.begin(38400);
      hostString = "";
    void    serialEvent() {
      while (Serial.available()) {
        char inChar = (char)Serial.read();
        hostString += inChar;
      if (hostString.length()){
        Serial.print(hostString);
        hostString = "";
    9,948
    Tried that code here and it works - given "1234567890a1234567890b1234567890c1234567890d12345 67890e1234567890f1234567890g1234567890h"
    That is 8 sets of 10 digits and 8 letters - for 88 character total.
    Works for MOST any length String EXCEPT exactly this string of "1234567890123456789012345678901234567890123456789 01234567890abc" 63 chars plus NewLine :: Total 64.
    ANY set of 64 chars as such are Perfectly HIDDEN - until a longer or shorter string are send and then those buffered strings are released in order received.
    @Paul - this seems to be a USB receive bug.
    9,948
    WITH A TWIST??? - written as a NULL term c string and not a STRING:
    char szH[400];
    uint32_t ii=0;
        szH[ii++] = (char)Serial.read();
      if (ii) {
        Serial.print(szH);
        Serial.print("| #=");
        Serial.println(ii);
        for ( ii=0; ii<400; ii++) szH[ii]=0;
        ii=0;
    This works as in this SerMon output?
    12345678901234567890123456789012345678901234567890 1234567890
    | #=61
    12345678901234567890123456789012345678901234567890 1234567890a
    | #=62
    12345678901234567890123456789012345678901234567890 1234567890ab
    | #=63
    12345678901234567890123456789012345678901234567890 1234567890abc
    | #=64
    12345678901234567890123456789012345678901234567890 1234567890abcd| #=64
    | #=1
    e
    | #=2
    Apr 2017
    Florida
    398
    I’m pretty sure this makes sense since the default serial buffer size is 64, I believe the number can be easily edited in one of the Teensy core files. So anything over 64 would be read in multiples instead of one long stream.
    9,948
    Post #3 shows expected sensible results - NO PROBLEM after all ? - the lines and '|' separator show the newline placement and where 64 byte expected buffer shows up.
    >> post #1 && #2 with the STRING code is having an issue where the string isn't empty but somehow 'if (hostString.length()){' isn't triggering until it is a non 64 multiple?
    Apr 2017
    Florida
    398
    Maybe the string isn’t be null terminated properly if the there’s an exact amount in the buffer?
    20,683
    Just want to confirm this is on my high priority list of bugs to investigate & fix.
    There's a similar report on github, like the same issue.
    https://github.com/PaulStoffregen/cores/issues/401
    Even though this is high priority, I probably won't be able to really work on it until Nov 25th.
