Hi all,
Ove the last couple of months (on and off) I've been developing a project around OBD/UDS canbus based data display for my car (MQB VW)
I started off with an Arduino Uno and an Elecfreaks Canbus shield as well as an I2c OLED display (SH1106) and later on an SPI (SSD1351) RGB OLED.
The Uno is a little slow to say the least - as I am requesting and displaying 6-10 PID's at a time and I need a high sample rate and display rate to display realtime engine data.
I decided to try out the Teensy 3.2, being that it is a lot faster than the Uno, and has built in Can capabilities.
I purchased a few TJA1050 transceivers, hooked them up to the Teensy with a 5v supply (via USB) and tried out SK Pang's OBD sketch (https://github.com/skpang/Teensy_CAN-Bus_ECU_reader) using Collin80's FlexCan library - but it was not picking up anything at 500KBs (where the Uno was).
I did a lot of research and every time it came to the 3.2 and canbus, Collin's fork of FlexCan was suggested.
I stumbled across this article (https://ironsource.com/streaming-can-bus-data-with-teensy/) and tried it out (with the TJA in place as well as without) but still - nothing in the Teensy's serial monitor.
I thought it might be a defective TJA, so I tried the other. All with the same result.
I was hoping someone could direct me to the right FlexCan library for the 3.2
Which one should be used?
Techtop
Collin80
tonton
Pawelsky
David
Techtop
Collin80
tonton
Pawelsky
David
