Results 1 to 17 of 17
Thread: Teensy 4 PDM Audio Input
    Jun 2016
    6
    Hi all,
    I'm trying to interface a PDM microphone with T4, using the Audio System Design Tool.
    I linked the PDM input with the 'queue' class. The resulting code compiles for T3.6, but for T4 it produces an error.
    Here's the code:
    #include <SerialFlash.h>
    AudioInputPDM            pdm1;           //xy=109,145
    AudioRecordQueue         queue1;         //xy=273,143
    AudioConnection          patchCord1(pdm1, queue1);
    And here's the error:
    C:\...\Temp\arduino_build_881909\sketch\MicTest.in o.cpp.o: In function `AudioInputPDM::AudioInputPDM()':
    C:\...\arduino-1.8.10\hardware\teensy\avr\libraries\Audio/input_pdm.h:37: undefined reference to `AudioInputPDM::begin()'
    C:\...\AppData\Local\Temp\arduino_build_881909\ske tch\MicTest.ino.cpp.o: In function `AudioStream::AudioStream(unsigned char, audio_block_struct**)':
    C:\...\arduino-1.8.10\hardware\teensy\avr\cores\teensy4/AudioStream.h:130: undefined reference to `vtable for AudioInputPDM'
    I'm using Arduino 1.8.10 and Teensyduino 1.48.
    Is PDM support not yet available on T4? Or do I have something misconfigured?
    Aug 2019
    16
    Any luck?
    Quote Originally Posted by Sanworks View Post
    Hi all,
    Here's the code:
    My apologies for reviving this topic. Did you have any luck with Teensy 4.0 and the PDM library support?
    I am currently working on a project that involves a PDM preamplifier and I am a bit lost due to the lack of info regarding the connections and library usage.
    Cheers
    dzalf
    Jul 2020
    918
    I've been looking at PDM recently. No the audio library doesn't support T4 for PDM yet (if you look in the sources
    its clearly ifdef'd out for T4. It would need the low level code for configuring the I2S hardware to output a 2.8MHz
    clock ported to the T4 processor, and for DMA'ing in the data.
    I think this is best left to someone with the relevant knowledge to get round to, though I might have a go myself
    if I can find my way round the 3 thousand page datasheet without brain meltdown!
    Jul 2020
    918
    I have a pull-request for adding T4 support to AudioInputPDM: https://github.com/PaulStoffregen/Audio/pull/387
    You only need to patch one file for testing, input_pdm.cpp
    In the end the existing code for I2S was fairly easy to tailor to PDM by inspecting the differences for KINETISK version
    and adding the necessary cache-flush call.
    The processor overhead for PDM is much less objectionable on the T4, even at 150MHz, and it may work even at 24MHz
    (although I think running an FFT at the same time overloaded it).
    Jul 2020
    918
    BTW it strikes me that on the T4 you could move PDM to the secondary I2S pins to avoid conflicting with the audio shield,
    but I'm not sure how to reconfigure all the registers for this. Paul??
    23,999
    I'd like to ask everyone who wants me to work on this a question.
    Which PDM microphone or chip are you using?
    (hint: I'm more motivated by seeing photos...)
    Jul 2020
    918
    Thats a great question - whatever the Adafruit PDM module uses - they don't seem to say, although theres a
    good bet its the MP34DT01-M as that's referenced in a few places alongside that module, and it has the same
    left/right select control.
    I first checked it was functioning with a T3.2 then had a bash at using the T4 - and of course trying a few
    other approaches to decimation along the way (more on that at a later date perhaps).
    13,756
    AdaF NRF Sense unit uses : PDM Microphone sound sensor: MP34DT01-M - PDM sound sensor.
    And their adafruit-clue - uses the same Mic.
    They link to Arduino lib arduino.cc/en/Reference/PDM that mentions "such as the on board MP34DT05 on the Arduino Nano 33 BLE Sense : and this page says :
    The MP34DT05-A sensor on the Arduino Nano 33 BLE Sense can be accessed through the PDM library and the Arduino Sound library, which uses the PDM library in the background
    AdaF has general notes on other breakouts - where they don't name the part - like they are standard 3.3V taking a clock and returning a PWM value like bit stream: adafruit-pdm-microphone-breakout?view=all
    23,999
    Is anyone using a different PDM chip than MP34DT01-M or MP34DT05-A?
    13,756
    Quick search at Sparkfun and Pololu don't show they have any PDM's that pop up ...
    The only breakouts at Digikey are two Adafruit MP34DT01-M ( and other one ) , though they have many PDM,Digital mic chips.
    Jul 2020
    918
    And another observation I have - I'm not sure the PDM code has to be incompatible with I2S output on the same I2S unit, as the
    clocking is the same. I might have a look at making this work, so that it works more like I2S input, calling AudioOutputI2S::config_i2s()
    and then tweaking a few things.
    And having spent a few hours looking at the manual I might also have a stab and making PDM work on I2S2 unit on T4 too. Found
    it very confusing that the BCLK/LRCLK are driven differently on I2S1 and I2S2...
    Jul 2020
    918
    Thought I'd pop my RF spectrum analyzer on a PDM signal from one of these microphones to see what sort of
    noise shaping they have - 3 plots zooming in on the audio band, with full-scales of 5MHz, 2MHz and 20kHz
    [ The peak in the last plot is me whistling at the mic ]
    Interestingly the two peaks at half-Nyquist spread into a wide band if there's significant sound levels at the mic -
    the two peaks when its quiet suggest limit-cycles of some sort I think, which is what you'd expect from a sigma-delta
    modulator I guess.
    Anyway it shows pretty good shaping of the quantization noise out of the audio band.
    In fact its pretty quiet up to around 50--70kHz, suggesting a more relaxed cutoff for a decimation filter might
    be OK (if you don't mind bat calls aliasing down to the audible range).
    23,999
    I'll admit, I've sometimes wondered if the 512 tap FIR filter was really a good idea. I wrote the code more as a challenge to see if Teensy could implement such an extreme filter rather than a careful plan. The impulse response came from a free web-based filter tool, which may not be truly correct (the tool probably was never well tested for such long filters).
    Jul 2020
    918
    Well I've experimented with CIC cascades and multi-state decimation and don't seem to get any speed advantage, though
    some space advantage. CIC cascading can be optimized by table lookup it turns out, to about the same throughput as
    the existing 512 tap filter.
    BTW strongly recommend Pyrhon's scipy.signal package for digital filtering tinkering.
    Apr 2021
    4
    Dear Community,
    i get the same compiling error as the thread starter in first post.
    is there already a solution? If i read correctly the work is still going on? - is it?
    i am using a different chip ( not MP34DT01-M or MP34DT05-A) but the base problem is the pdm library with the T4.x, - right?
    I would be happy to receive the latest information.
    Many greetings.
    23,999
    Quote Originally Posted by Max1990 View Post
    Yes, there is a solution. All you need to do is use a recent beta version, because PDM support for Teensy 4.x was added after 1.53 was released.
    Get it here:
    https://forum.pjrc.com/threads/66357...no-1-54-Beta-7
    No, not really. The PDM input code we have now isn't expected to change much.
    But if you or anyone else wants to fiddle with the filter response, you could create a text file with your desired 512 tap impulse response and run the perl script (found in the code comments) to generate a different filter table. If someone happens to create a filter response that works better than the one we have now, I'd be happy to replace the existing table. But then again, what is considered "better" may not be so clear & easy to hear. The filter we have now seems to work pretty well. The memory consumed isn't a big issue on Teensy 4.
    The base problem is simply using a version of the software from before this code was adapted to work on Teensy 4.x.
    Admittedly, the normal ~3 month software release schedule has fallen far behind (currently about 9 months) during the pandemic & PJRC's labor shortage due to social distancing. In normal times, we would have released 1.55 by now. But the reality today is we still have 1.53 from last summer as the latest non-beta release.
    So to use PDM with Teensy 4.x, until 1.54 releases, you need to use a beta version to get PDM support.
    Can you tell us the part number? Is it IM69D130?
    Apr 2021
    4
    Get it here:
    Many thanks,
    with the 1.5.4#7 compiled well.
    should i connect T4 to Pin9 and Pin13 like the T3?
